text() generates warning in command line invocation
HJ
Hugo Jackson
Sat, Jul 21, 2018 10:09 PM
Looking for some help… have an OpenSCAD  (2018.03.17) program that works fine on my Mac but when I call it through the command line it generates the following warning:
Fontconfig warning: line 144: blank doesn't take any effect anymore. please remove it from your fonts.conf
And then the Activity monitor reports that OpenSCAD continues to grind away at ~95% CPU usage, but doesn’t ever finish.
Any thoughts?
Looking for some help… have an OpenSCAD (2018.03.17) program that works fine on my Mac but when I call it through the command line it generates the following warning: Fontconfig warning: line 144: blank doesn't take any effect anymore. please remove it from your fonts.conf And then the Activity monitor reports that OpenSCAD continues to grind away at ~95% CPU usage, but doesn’t ever finish. Any thoughts?
JL
Jean-Paul Louis
Sat, Jul 21, 2018 11:53 PM
Hugo,
Do you mind sharing the command line you are using in terminal?
I would like to try it on my MacBook pro running OS X 10.13.6 to see if I get the same result.
Jean-Paul
Any thoughts?
Hugo, Do you mind sharing the command line you are using in terminal? I would like to try it on my MacBook pro running OS X 10.13.6 to see if I get the same result. Jean-Paul > On Jul 21, 2018, at 6:09 PM, Hugo Jackson <hugo@apres.net> wrote: > > Looking for some help… have an OpenSCAD (2018.03.17) program that works fine on my Mac but when I call it through the command line it generates the following warning: > > Fontconfig warning: line 144: blank doesn't take any effect anymore. please remove it from your fonts.conf > > And then the Activity monitor reports that OpenSCAD continues to grind away at ~95% CPU usage, but doesn’t ever finish. > Any thoughts? > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
HJ
Hugo Jackson
Sun, Jul 22, 2018 12:01 AM
I reduced the program down to a few lines which is this…
textmsg = "test";
module text_hang() {
rotate([0,90,0])
linear_extrude(12)
text(text = textmsg, size = 10, halign = "center");
text_hang();
And it is invoked with…
/Applications/OpenSCAD.app/Contents/MacOS/OpenSCAD -o ~/Documents/OpenSCAD/test_hang.stl ~/Documents/OpenSCAD/test_hang.scad
I have determined that the program DOES finish running… eventually… somewhat non-intuitively (to me anyway) the program just takes a lot longer to execute in command line mode that program mode… so what do I know.
So I guess I’m really just reporting on the warning message.
On Jul 21, 2018, at 4:53 PM, Jean-Paul Louis louijp@yahoo.com wrote:
Hugo,
Jean-Paul
Any thoughts?
I reduced the program down to a few lines which is this… textmsg = "test"; module text_hang() { rotate([0,90,0]) linear_extrude(12) text(text = textmsg, size = 10, halign = "center"); } text_hang(); And it is invoked with… /Applications/OpenSCAD.app/Contents/MacOS/OpenSCAD -o ~/Documents/OpenSCAD/test_hang.stl ~/Documents/OpenSCAD/test_hang.scad I have determined that the program DOES finish running… eventually… somewhat non-intuitively (to me anyway) the program just takes a lot longer to execute in command line mode that program mode… so what do I know. So I guess I’m really just reporting on the warning message. > On Jul 21, 2018, at 4:53 PM, Jean-Paul Louis <louijp@yahoo.com> wrote: > > Hugo, > > Do you mind sharing the command line you are using in terminal? > > I would like to try it on my MacBook pro running OS X 10.13.6 to see if I get the same result. > > Jean-Paul > >> On Jul 21, 2018, at 6:09 PM, Hugo Jackson <hugo@apres.net> wrote: >> >> Looking for some help… have an OpenSCAD (2018.03.17) program that works fine on my Mac but when I call it through the command line it generates the following warning: >> >> Fontconfig warning: line 144: blank doesn't take any effect anymore. please remove it from your fonts.conf >> >> And then the Activity monitor reports that OpenSCAD continues to grind away at ~95% CPU usage, but doesn’t ever finish. >> Any thoughts? >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
Sun, Jul 22, 2018 12:14 AM
Later versions of the GUI do the Font update EVERY time you run it, which
'can take up to a couple of minutes', perhaps that is also happening via
command line?
Later versions of the GUI do the Font update EVERY time you run it, which 'can take up to a couple of minutes', perhaps that is also happening via command line? ----- Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- Sent from: http://forum.openscad.org/
