Is OpenSCAD to CNC possible?
RobWLakes
Mon, Sep 4, 2017 10:24 PM
OpenSCAD has been a brilliant tool to indulge my design/construct. or just
plain hack, yearnings. A big "Thank you" to the people who get under the
bonnet and improve it to the standard it is today.  Though its shortcomings
maybe many at the fringes of its performance, for every day user like me, I
find it just an amazing tool. However before 3-D Printing, one of the other
machines that have fascinated me for years was the 3-D Milling machines.
To that end I have bought and built a cheapish (~$290Au) aluminium engraving
machine.  While it is very basic in design, it has all the things that I
wanted to put together 20yrs ago, in a complete package.  It has an Arduino
UNO running GRBL , and  I have successfully had some dry runs of test
patterns through  LinuxCNC.
To cut this long story short, is there a way to use openSCAD as the design
tool to produce the GRBL file?  Or if anyone else is competent in OpenSCAD
and also CAD milling, what is a practical way to achieve some of the design
convenience in OpenSCAD in the other world of 3-D Milling? Is there a
preferred pathway? Any suggestions in the way of software, or online
tutorials, to get me started would be much appreciated.
Cheers, and thanks in advance, Rob
http://forum.openscad.org/file/t1180/IMG_20170611_112902.jpg
Partly built a month ago....
Rob W
Lake Tyers Beach,
Victoria, Australia
OpenSCAD has been a brilliant tool to indulge my design/construct. or just plain hack, yearnings. A big "Thank you" to the people who get under the bonnet and improve it to the standard it is today. Though its shortcomings maybe many at the fringes of its performance, for every day user like me, I find it just an amazing tool. However before 3-D Printing, one of the other machines that have fascinated me for years was the 3-D Milling machines. To that end I have bought and built a cheapish (~$290Au) aluminium engraving machine. While it is very basic in design, it has all the things that I wanted to put together 20yrs ago, in a complete package. It has an Arduino UNO running GRBL , and I have successfully had some dry runs of test patterns through LinuxCNC. To cut this long story short, is there a way to use openSCAD as the design tool to produce the GRBL file? Or if anyone else is competent in OpenSCAD and also CAD milling, what is a practical way to achieve some of the design convenience in OpenSCAD in the other world of 3-D Milling? Is there a preferred pathway? Any suggestions in the way of software, or online tutorials, to get me started would be much appreciated. Cheers, and thanks in advance, Rob <http://forum.openscad.org/file/t1180/IMG_20170611_112902.jpg> Partly built a month ago.... ----- Rob W Lake Tyers Beach, Victoria, Australia -- Sent from: http://forum.openscad.org/
Mon, Sep 4, 2017 10:35 PM
I use OpenSCAD with PyCAM to generate gcode that I feed to LinuxCNC to
drive my CNC router that is connected to a PC parallel port. It should work
with GRBL as well.
engraving
Rob W
Lake Tyers Beach,
Victoria, Australia
I use OpenSCAD with PyCAM to generate gcode that I feed to LinuxCNC to drive my CNC router that is connected to a PC parallel port. It should work with GRBL as well. On 4 September 2017 at 23:24, RobWLakes <rl.ward@bigpond.com> wrote: > OpenSCAD has been a brilliant tool to indulge my design/construct. or just > plain hack, yearnings. A big "Thank you" to the people who get under the > bonnet and improve it to the standard it is today. Though its shortcomings > maybe many at the fringes of its performance, for every day user like me, I > find it just an amazing tool. However before 3-D Printing, one of the other > machines that have fascinated me for years was the 3-D Milling machines. > > To that end I have bought and built a cheapish (~$290Au) aluminium > engraving > machine. While it is very basic in design, it has all the things that I > wanted to put together 20yrs ago, in a complete package. It has an Arduino > UNO running GRBL , and I have successfully had some dry runs of test > patterns through LinuxCNC. > > To cut this long story short, is there a way to use openSCAD as the design > tool to produce the GRBL file? Or if anyone else is competent in OpenSCAD > and also CAD milling, what is a practical way to achieve some of the design > convenience in OpenSCAD in the other world of 3-D Milling? Is there a > preferred pathway? Any suggestions in the way of software, or online > tutorials, to get me started would be much appreciated. > > Cheers, and thanks in advance, Rob > > <http://forum.openscad.org/file/t1180/IMG_20170611_112902.jpg> > Partly built a month ago.... > > > > ----- > Rob W > Lake Tyers Beach, > Victoria, Australia > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Rob Ward
Tue, Sep 5, 2017 12:01 AM
Excellent!! Thank you, I will give that a try.
Thank you for the prompt reply, this group is "Ace!".
Rob
 or just
 under the
 shortcomings
 like me, I
 the other
 machines.
 engraving
 that I
 an Arduino
 the design
 OpenSCAD
 the design
 <http://forum.openscad.org/file/t1180/IMG_20170611_112902.jpg>>
 Rob W
 Lake Tyers Beach,
 Victoria, Australia
Rob Ward
Lake Tyers Beach, 3909
Ubuntu Mate - A great OS https://ubuntu-mate.org/
Excellent!! Thank you, I will give that a try. Thank you for the prompt reply, this group is "Ace!". Rob On 05/09/17 08:35, nop head wrote: > I use OpenSCAD with PyCAM to generate gcode that I feed to LinuxCNC to > drive my CNC router that is connected to a PC parallel port. It should > work with GRBL as well. > > On 4 September 2017 at 23:24, RobWLakes <rl.ward@bigpond.com > <mailto:rl.ward@bigpond.com>> wrote: > > OpenSCAD has been a brilliant tool to indulge my design/construct. > or just > plain hack, yearnings. A big "Thank you" to the people who get > under the > bonnet and improve it to the standard it is today. Though its > shortcomings > maybe many at the fringes of its performance, for every day user > like me, I > find it just an amazing tool. However before 3-D Printing, one of > the other > machines that have fascinated me for years was the 3-D Milling > machines. > > To that end I have bought and built a cheapish (~$290Au) aluminium > engraving > machine. While it is very basic in design, it has all the things > that I > wanted to put together 20yrs ago, in a complete package. It has > an Arduino > UNO running GRBL , and I have successfully had some dry runs of test > patterns through LinuxCNC. > > To cut this long story short, is there a way to use openSCAD as > the design > tool to produce the GRBL file? Or if anyone else is competent in > OpenSCAD > and also CAD milling, what is a practical way to achieve some of > the design > convenience in OpenSCAD in the other world of 3-D Milling? Is there a > preferred pathway? Any suggestions in the way of software, or online > tutorials, to get me started would be much appreciated. > > Cheers, and thanks in advance, Rob > > <http://forum.openscad.org/file/t1180/IMG_20170611_112902.jpg > <http://forum.openscad.org/file/t1180/IMG_20170611_112902.jpg>> > Partly built a month ago.... > > > > ----- > Rob W > Lake Tyers Beach, > Victoria, Australia > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org <mailto:Discuss@lists.openscad.org> > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > <http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org> > > > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org -- *Rob Ward* Lake Tyers Beach, 3909 Lake Tyers Beach Website <http://www.laketyersbeach.net.au> Ubuntu Mate - A great OS <https://ubuntu-mate.org/>
Rob Ward
Tue, Sep 5, 2017 11:02 AM
https://github.com/SebKuzminsky/pycam/releases
This link is a more up to date version.  I had trouble all day to
install it, this one worked, Ver6 (on Ubuntu Mate 16.04.3 LTS)
Cheers yet to try it so let's see what it does.
Cheers, Rob
 or just
 under the
 shortcomings
 like me, I
 the other
 machines.
 engraving
 that I
 an Arduino
 the design
 OpenSCAD
 the design
 Rob W
 Lake Tyers Beach,
 Victoria, Australia
Rob Ward
https://github.com/SebKuzminsky/pycam/releases This link is a more up to date version. I had trouble all day to install it, this one worked, Ver6 (on Ubuntu Mate 16.04.3 LTS) Cheers yet to try it so let's see what it does. Cheers, Rob On 05/09/17 08:35, nop head wrote: > I use OpenSCAD with PyCAM to generate gcode that I feed to LinuxCNC to > drive my CNC router that is connected to a PC parallel port. It should > work with GRBL as well. > > On 4 September 2017 at 23:24, RobWLakes <rl.ward@bigpond.com > <mailto:rl.ward@bigpond.com>> wrote: > > OpenSCAD has been a brilliant tool to indulge my design/construct. > or just > plain hack, yearnings. A big "Thank you" to the people who get > under the > bonnet and improve it to the standard it is today. Though its > shortcomings > maybe many at the fringes of its performance, for every day user > like me, I > find it just an amazing tool. However before 3-D Printing, one of > the other > machines that have fascinated me for years was the 3-D Milling > machines. > > To that end I have bought and built a cheapish (~$290Au) aluminium > engraving > machine. While it is very basic in design, it has all the things > that I > wanted to put together 20yrs ago, in a complete package. It has > an Arduino > UNO running GRBL , and I have successfully had some dry runs of test > patterns through LinuxCNC. > > To cut this long story short, is there a way to use openSCAD as > the design > tool to produce the GRBL file? Or if anyone else is competent in > OpenSCAD > and also CAD milling, what is a practical way to achieve some of > the design > convenience in OpenSCAD in the other world of 3-D Milling? Is there a > preferred pathway? Any suggestions in the way of software, or online > tutorials, to get me started would be much appreciated. > > Cheers, and thanks in advance, Rob > > <http://forum.openscad.org/file/t1180/IMG_20170611_112902.jpg > <http://forum.openscad.org/file/t1180/IMG_20170611_112902.jpg>> > Partly built a month ago.... > > > > ----- > Rob W > Lake Tyers Beach, > Victoria, Australia > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org <mailto:Discuss@lists.openscad.org> > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > <http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org> > > > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org -- *Rob Ward* Lake Tyers Beach, 3909 Lake Tyers Beach Website <http://www.laketyersbeach.net.au> Ubuntu Mate - A great OS <https://ubuntu-mate.org/>
WA
William Adams
Tue, Sep 5, 2017 11:58 AM
Another option here is to export to a DXF and use a traditional CAM program
--- also the STL files which pyCAM accepts can be used by other 3D CAM
programs. List of options here:
https://www.shapeoko.com/wiki/index.php/CAM#3D and
https://www.shapeoko.com/wiki/index.php/Commercial_Software#3D_CAM
Cheers, Rob
with GRBL as well.
shortcomings
I
other
engraving
Arduino
design
Rob W
Lake Tyers Beach,
Victoria, Australia
Rob Ward
Another option here is to export to a DXF and use a traditional CAM program --- also the STL files which pyCAM accepts can be used by other 3D CAM programs. List of options here: https://www.shapeoko.com/wiki/index.php/CAM#3D and https://www.shapeoko.com/wiki/index.php/Commercial_Software#3D_CAM William On Tue, Sep 5, 2017 at 7:02 AM, Rob Ward <rl.ward@bigpond.com> wrote: > https://github.com/SebKuzminsky/pycam/releases > > This link is a more up to date version. I had trouble all day to install > it, this one worked, Ver6 (on Ubuntu Mate 16.04.3 LTS) > Cheers yet to try it so let's see what it does. > > Cheers, Rob > > On 05/09/17 08:35, nop head wrote: > > I use OpenSCAD with PyCAM to generate gcode that I feed to LinuxCNC to > drive my CNC router that is connected to a PC parallel port. It should work > with GRBL as well. > > On 4 September 2017 at 23:24, RobWLakes <rl.ward@bigpond.com> wrote: > >> OpenSCAD has been a brilliant tool to indulge my design/construct. or just >> plain hack, yearnings. A big "Thank you" to the people who get under the >> bonnet and improve it to the standard it is today. Though its >> shortcomings >> maybe many at the fringes of its performance, for every day user like me, >> I >> find it just an amazing tool. However before 3-D Printing, one of the >> other >> machines that have fascinated me for years was the 3-D Milling machines. >> >> To that end I have bought and built a cheapish (~$290Au) aluminium >> engraving >> machine. While it is very basic in design, it has all the things that I >> wanted to put together 20yrs ago, in a complete package. It has an >> Arduino >> UNO running GRBL , and I have successfully had some dry runs of test >> patterns through LinuxCNC. >> >> To cut this long story short, is there a way to use openSCAD as the design >> tool to produce the GRBL file? Or if anyone else is competent in OpenSCAD >> and also CAD milling, what is a practical way to achieve some of the >> design >> convenience in OpenSCAD in the other world of 3-D Milling? Is there a >> preferred pathway? Any suggestions in the way of software, or online >> tutorials, to get me started would be much appreciated. >> >> Cheers, and thanks in advance, Rob >> >> <http://forum.openscad.org/file/t1180/IMG_20170611_112902.jpg> >> Partly built a month ago.... >> >> >> >> ----- >> Rob W >> Lake Tyers Beach, >> Victoria, Australia >> -- >> Sent from: http://forum.openscad.org/ >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> > > > > _______________________________________________ > OpenSCAD mailing listDiscuss@lists.openscad.orghttp://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > -- > > *Rob Ward* > Lake Tyers Beach, 3909 > Lake Tyers Beach Website <http://www.laketyersbeach.net.au> > Ubuntu Mate - A great OS <https://ubuntu-mate.org/> > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
