OpenSCAD... quite a bit faster
Wed, Mar 9, 2022 1:33 AM
Have there been fast-csg changes to master since the Snap openscad-nightly,
still dated 13 Feb 2022? https://snapcraft.io/openscad-nightly
Yes, there's at least one bigger fix for an issue that could cause
missing parts.
If you want to make sure to always have the latest build, you can
use the "edge" channel. This one is built automatically.
Where can I find the "edge" channel?
> > Have there been fast-csg changes to master since the Snap openscad-nightly, > > still dated 13 Feb 2022? https://snapcraft.io/openscad-nightly > > Yes, there's at least one bigger fix for an issue that could cause > missing parts. > > If you want to make sure to always have the latest build, you can > use the "edge" channel. This one is built automatically. Where can I find the "edge" channel? -- This email has been checked for viruses by AVG. https://www.avg.com
Wed, Mar 9, 2022 8:22 AM
I only know the command line way, there might be others...
$ snap refresh openscad-nightly --edge
$ snap list
Name                      Version          Rev    Tracking
openscad                  2021.01          196    latest/stable
openscad-nightly          0+git.9667ab604  3242  latest/edge
Going back to the "stable" channel...
$ snap refresh openscad-nightly --stable
$ snap list
openscad-nightly          0+git.fef5275f9  3215  latest/stable
On 09.03.22 02:33, MichaelAtOz wrote: > Where can I find the "edge" channel? I only know the command line way, there might be others... $ snap refresh openscad-nightly --edge $ snap list Name Version Rev Tracking openscad 2021.01 196 latest/stable openscad-nightly 0+git.9667ab604 3242 latest/edge Going back to the "stable" channel... $ snap refresh openscad-nightly --stable $ snap list Name Version Rev Tracking openscad 2021.01 196 latest/stable openscad-nightly 0+git.fef5275f9 3215 latest/stable ciao, Torsten.
BE
Bob Ewart
Wed, Mar 9, 2022 1:12 PM
You can also go to the OpenSCAD downloads page
http://openscad.org/downloads.html.  See "Linux-Distribution Packages"
at the bottom of the page.  There are repositories for Debian, Ubuntu,
openSUSE, Fedora and Arch Linux.  Add the appropriate repository and
install openscad-nightly.  It will be kept up to date like all of the
other packages on your system.
Bob
$ snap list
$ snap list
You can also go to the OpenSCAD downloads page <http://openscad.org/downloads.html>.  See "Linux-Distribution Packages" at the bottom of the page.  There are repositories for Debian, Ubuntu, openSUSE, Fedora and Arch Linux.  Add the appropriate repository and install openscad-nightly.  It will be kept up to date like all of the other packages on your system. -- Bob On 3/9/22 03:22, Torsten Paul wrote: > On 09.03.22 02:33, MichaelAtOz wrote: >> Where can I find the "edge" channel? > > I only know the command line way, there might be others... > > $ snap refresh openscad-nightly --edge > > $ snap list > Name                       Version           Rev    Tracking > openscad                   2021.01           196    latest/stable > openscad-nightly           0+git.9667ab604   3242   latest/edge > > Going back to the "stable" channel... > > $ snap refresh openscad-nightly --stable > > $ snap list > Name                       Version           Rev    Tracking > openscad                   2021.01           196    latest/stable > openscad-nightly           0+git.fef5275f9   3215   latest/stable > > ciao, >   Torsten. > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
