RV
Roel Vanhout
Sun, Sep 25, 2022 12:47 PM
I'm looking for a way to get a list (e.g., CSV file with two columns) of
all OpenSCAD built-in as well as BOSL(2) modules, i.e. their name and
parameters. The reason for this is that 90% of my visits to the
documentation are for looking up the exact names and default values of
parameters, which I would like to instead do/show in my editor (vim). Many
moons ago I wrote something similar for PHP, and to this day I can show the
parameters of most PHP functions in my vim status bar by pressing
shift-ctrl-spacebar with my cursor within the braces of a PHP function.
For me to get this to work for OpenSCAD, I basically need a list of the
modules' names and their arguments. For PHP I seem to remember I had a
crude regex based script that looked through the PHP source code, where I
think some sort of annotation system was used, which was then also used for
the regular PHP documentation (this is 20+ years ago so it probably changed
by now, I haven't kept up as I haven't written PHP in 15 years). So I'm
wondering if there is something similar for OpenSCAD, or a way for me to
tap into the documentation building system (which I assume there is?) to
generate such a list? Thanks.
cheers
Roel
cheers
Roel
Michael Möller
Sun, Sep 25, 2022 1:22 PM
The cheat sheet (available in the menu) certainly has the "signature" for
the openscad functions.
Michael, fra mobilen
søn. 25. sep. 2022 14.47 skrev Roel Vanhout roel.vanhout@gmail.com:
cheers
Roel
søn. 25. sep. 2022 14.47 skrev Roel Vanhout <roel.vanhout@gmail.com>:
> Hi,
> cheers
> Roel
Sun, Sep 25, 2022 1:35 PM
cheers
Roel
The BOSL2 cheat sheet is at
https://github.com/revarbat/BOSL2/wiki/CheatSheet but if you wanted to do
something yourself you could scan the BOSL2 source files for "// Usage:"
and extract all the usage texts. The BOSL2 manual is entirely obtained
from comments in the BOSL2 code.
On Sun, Sep 25, 2022 at 8:48 AM Roel Vanhout <roel.vanhout@gmail.com> wrote:
> Hi,
> cheers
> Roel
RV
Roel Vanhout
Sun, Sep 25, 2022 1:45 PM
It does and with some manual scrubbing I guess I could produce my list from
its html - is the cheat sheet generated or made manually?
On Sun, Sep 25, 2022 at 3:23 PM Michael Möller private2michael@gmail.com
cheers
Roel
On Sun, Sep 25, 2022 at 3:23 PM Michael Möller <private2michael@gmail.com>
>> Hi,
>> cheers
>> Roel
Mon, Sep 26, 2022 2:03 AM
All BOSL2 docs are generated using the Python module openscad_docsgen which reads specially formatted comments in the library's .scad source files. You can use this library to parse these comments so that you can programmatically use them.
https://pypi.org/project/openscad-docsgen/
On Sep 25, 2022, at 6:45 AM, Roel Vanhout roel.vanhout@gmail.com wrote:
It does and with some manual scrubbing I guess I could produce my list from its html - is the cheat sheet generated or made manually?
On Sun, Sep 25, 2022 at 3:23 PM Michael Möller <private2michael@gmail.com mailto:private2michael@gmail.com> wrote:
The cheat sheet (available in the menu) certainly has the "signature" for the openscad functions.
søn. 25. sep. 2022 14.47 skrev Roel Vanhout <roel.vanhout@gmail.com mailto:roel.vanhout@gmail.com>:
I'm looking for a way to get a list (e.g., CSV file with two columns) of all OpenSCAD built-in as well as BOSL(2) modules, i.e. their name and parameters. The reason for this is that 90% of my visits to the documentation are for looking up the exact names and default values of parameters, which I would like to instead do/show in my editor (vim). Many moons ago I wrote something similar for PHP, and to this day I can show the parameters of most PHP functions in my vim status bar by pressing shift-ctrl-spacebar with my cursor within the braces of a PHP function.
For me to get this to work for OpenSCAD, I basically need a list of the modules' names and their arguments. For PHP I seem to remember I had a crude regex based script that looked through the PHP source code, where I think some sort of annotation system was used, which was then also used for the regular PHP documentation (this is 20+ years ago so it probably changed by now, I haven't kept up as I haven't written PHP in 15 years). So I'm wondering if there is something similar for OpenSCAD, or a way for me to tap into the documentation building system (which I assume there is?) to generate such a list? Thanks.
cheers
Roel
All BOSL2 docs are generated using the Python module `openscad_docsgen` which reads specially formatted comments in the library's .scad source files. You can use this library to parse these comments so that you can programmatically use them.
- Revar
> On Sun, Sep 25, 2022 at 3:23 PM Michael Möller <private2michael@gmail.com <mailto:private2michael@gmail.com>> wrote:
> søn. 25. sep. 2022 14.47 skrev Roel Vanhout <roel.vanhout@gmail.com <mailto:roel.vanhout@gmail.com>>:
> Hi,
> cheers
> Roel
> To unsubscribe send an email to discuss-leave@lists.openscad.org <mailto:discuss-leave@lists.openscad.org>
RV
Roel Vanhout
Sun, Oct 2, 2022 9:49 AM
Thank you, this is much more convenient than anything I could have hoped
for.
regards
cheers
Roel
for.
regards
> - Revar
>>> Hi,
>>> cheers
>>> Roel
