I having issues running OpenSCAD on Windows 7.
The problems are OS caused and I want to get some "happy ballance".
I am doing stuff that seems to be calculation intensive but Windows goes to
sleep and nothing is done during sleep.
I know I can set the computer to "never sleep" but I'm wondering if there is
some better middle ground like "if application/process X is running let it
have what it wants" By that I mean the OS could turn the screen off (I
don't need a display while it is calculating) and if it isn't swapping to
disk let the disk spin down to an idle.
What do other people on Windows do? I would prefer to garner some power
savings by letting some resources go idle.
View this message in context: http://forum.openscad.org/Tips-for-OpenSCAD-on-Windows-7-tp18083.html
DanS wrote
"if application/process X is running let it have what it wants"
Probably but it would not be straight forward.
By that I mean the OS could turn the screen off (I don't need a display
while it is calculating) and if it isn't swapping to disk let the disk
'Control Panel/Power Options/Change Plan Settings/Change Advanced Power
Options' lets you set individual options for hard disc, display, sleep and
other things.
I don't have much power saving ATM, but I tend to do display off first, disc
off shortly thereafter, sleep a lot later (but off if I'm in a process heavy
state). ATM, I manually hibernate via the start menu when I'm not going to
use it. (tho hibernate v's sleep is due to a error waking from sleep, but
hibernate saves more power)
View this message in context: http://forum.openscad.org/Tips-for-OpenSCAD-on-Windows-7-tp18083p18087.html
