Easy way to get the area area of a polygon?
E
Experimentalist
Mon, Apr 11, 2016 9:04 PM
Hi
Since a polygon is essentially made up of triangles I presume this is not
too hard. Anyone got a solution? I don't want to waste valuable time
reinventing the wheel.
Thanks
Ex.
View this message in context: http://forum.openscad.org/Easy-way-to-get-the-area-area-of-a-polygon-tp17045.html
Hi Since a polygon is essentially made up of triangles I presume this is not too hard. Anyone got a solution? I don't want to waste valuable time reinventing the wheel. Thanks Ex. -- View this message in context: http://forum.openscad.org/Easy-way-to-get-the-area-area-of-a-polygon-tp17045.html Sent from the OpenSCAD mailing list archive at Nabble.com.
F
fred_dot_u
Mon, Apr 11, 2016 9:27 PM
I can't provide verification of this particular program, but it purports to
do as you require:
http://codecanyon.net/item/3d-surface-area-calculator/10457510
At US$11.00 it would be a small gamble.
View this message in context: http://forum.openscad.org/Easy-way-to-get-the-area-of-a-polygon-tp17045p17048.html
I can't provide verification of this particular program, but it purports to do as you require: http://codecanyon.net/item/3d-surface-area-calculator/10457510 <http://codecanyon.net/item/3d-surface-area-calculator/10457510> At US$11.00 it would be a small gamble. -- View this message in context: http://forum.openscad.org/Easy-way-to-get-the-area-of-a-polygon-tp17045p17048.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Tue, Apr 12, 2016 2:41 AM
Well, first you triangulate the polygon using the code posted to the recent
"Simple Polygon Triangulation" thread, then you add up the area of each
triangle?
On 11 April 2016 at 17:04, Experimentalist experimentalist@aaawesome.co.uk
Hi
Thanks
Ex.
Well, first you triangulate the polygon using the code posted to the recent "Simple Polygon Triangulation" thread, then you add up the area of each triangle? On 11 April 2016 at 17:04, Experimentalist <experimentalist@aaawesome.co.uk> wrote: > Hi > > Since a polygon is essentially made up of triangles I presume this is not > too hard. Anyone got a solution? I don't want to waste valuable time > reinventing the wheel. > > Thanks > Ex. > > > > -- > View this message in context: > http://forum.openscad.org/Easy-way-to-get-the-area-area-of-a-polygon-tp17045.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > >
KS
Kenneth Sloan
Tue, Apr 12, 2016 3:01 AM
It is absolutely NOT NECESSARY to triangulate in order to compute area.  You can walk the perimeter and compute the area of the polygon.  Google “Newman’s Scheme”, or directly apply either Green’s Theorem or Stokes’s Theorem, depending on your training.
That was the short, enigmatic answer (Google is your friend).  The long answer is:
a) pick a point in the plane - any point.  Call it O. [Hint: [0,0] works best]
b) for each edge in the polygon, construct the triangle O,v[i], v[i+1 mod n]
where n is the number of vertices and the numbering begins with 0
and the edge goes from v[i] to v[i+1 mod n]
c) compute the SIGNED area of this triangle and accumulate the sum of the SIGNED areas
d) the total SIGNED area will give the area of the polygon and the SIGN will tell you
if the polygon is correctly oriented.
A quick and dirty first implementation might stop here.  To make it faster:
e) for extra credit, re-arrange the terms to eliminate O [that’s why I suggested that [0,0] works best].  You will arrive at a computation that looks something like:
 AREA = 0.5 * SUM(v[i] CROSS v[i+1 mod n])
where:
the representation of the point v[i] is interpreted as a the representation of a
vector from O to v[i] (no, points and vectors are not the same, but SOME computations
can pretend that they are)
vertices are numbered 0..n-1
I have a beautiful proof-by-diagram of this, but it does not fit in ASCII format.
If you want to do Volumes, substitute triangular faces of the polyhedron for the edges of the polygon.  Use the scalar triple product instead of cross product, and divide by 6 instead of 2.
Proof left as an exercise for the reader.
Green and Stokes showed that you can compute properties of the area by walking around the perimeter.  Their followers proved that one follows from the other, and vice versa.  Newman did the algebra and optimized the computation in the context of computer graphics.
Newman’s scheme dates to AT LEAST 1965.  Green and Stokes were much earlier.
Kenneth Sloan
KennethRSloan@gmail.com mailto:KennethRSloan@gmail.com
Vision is the art of seeing what is invisible to others.
On 11 April 2016 at 17:04, Experimentalist <experimentalist@aaawesome.co.uk mailto:experimentalist@aaawesome.co.uk> wrote:
Hi
Thanks
Ex.
View this message in context: http://forum.openscad.org/Easy-way-to-get-the-area-area-of-a-polygon-tp17045.html http://forum.openscad.org/Easy-way-to-get-the-area-area-of-a-polygon-tp17045.html
It is absolutely NOT NECESSARY to triangulate in order to compute area. You can walk the perimeter and compute the area of the polygon. Google “Newman’s Scheme”, or directly apply either Green’s Theorem or Stokes’s Theorem, depending on your training. That was the short, enigmatic answer (Google is your friend). The long answer is: a) pick a point in the plane - any point. Call it O. [Hint: [0,0] works best] b) for each edge in the polygon, construct the triangle O,v[i], v[i+1 mod n] where n is the number of vertices and the numbering begins with 0 and the edge goes from v[i] to v[i+1 mod n] c) compute the SIGNED area of this triangle and accumulate the sum of the SIGNED areas d) the total SIGNED area will give the area of the polygon and the SIGN will tell you if the polygon is correctly oriented. A quick and dirty first implementation might stop here. To make it faster: e) for extra credit, re-arrange the terms to eliminate O [that’s why I suggested that [0,0] works best]. You will arrive at a computation that looks something like: AREA = 0.5 * SUM(v[i] CROSS v[i+1 mod n]) where: the representation of the point v[i] is interpreted as a the representation of a vector from O to v[i] (no, points and vectors are not the same, but SOME computations can pretend that they are) vertices are numbered 0..n-1 I have a beautiful proof-by-diagram of this, but it does not fit in ASCII format. If you want to do Volumes, substitute triangular faces of the polyhedron for the edges of the polygon. Use the scalar triple product instead of cross product, and divide by 6 instead of 2. Proof left as an exercise for the reader. Green and Stokes showed that you can compute properties of the area by walking around the perimeter. Their followers proved that one follows from the other, and vice versa. Newman did the algebra and optimized the computation in the context of computer graphics. Newman’s scheme dates to AT LEAST 1965. Green and Stokes were much earlier. -- Kenneth Sloan KennethRSloan@gmail.com <mailto:KennethRSloan@gmail.com> Vision is the art of seeing what is invisible to others. > On Apr 11, 2016, at 21:41 , doug moen <doug@moens.org> wrote: > > Well, first you triangulate the polygon using the code posted to the recent "Simple Polygon Triangulation" thread, then you add up the area of each triangle? > > On 11 April 2016 at 17:04, Experimentalist <experimentalist@aaawesome.co.uk <mailto:experimentalist@aaawesome.co.uk>> wrote: > Hi > > Since a polygon is essentially made up of triangles I presume this is not > too hard. Anyone got a solution? I don't want to waste valuable time > reinventing the wheel. > > Thanks > Ex. > > > > -- > View this message in context: http://forum.openscad.org/Easy-way-to-get-the-area-area-of-a-polygon-tp17045.html <http://forum.openscad.org/Easy-way-to-get-the-area-area-of-a-polygon-tp17045.html> > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org <mailto:Discuss@lists.openscad.org> > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org <http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org> > > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
Tue, Apr 12, 2016 4:30 AM
Nice solution! If I undertand it well the AREA evaluated by the expression
in e) is a vector. And the scalar area will be its norm.
2016-04-12 0:01 GMT-03:00 Kenneth Sloan kennethrsloan@gmail.com:
answer is:
best]
n]
SIGNED areas
will tell you
where:
representation of a
SOME computations
format.
earlier.
Kenneth Sloan
each triangle?
Hi
Thanks
Ex.
http://nabble.com.
Nice solution! If I undertand it well the AREA evaluated by the expression in e) is a vector. And the scalar area will be its norm. 2016-04-12 0:01 GMT-03:00 Kenneth Sloan <kennethrsloan@gmail.com>: > It is absolutely NOT NECESSARY to triangulate in order to compute area. > You can walk the perimeter and compute the area of the polygon. Google > “Newman’s Scheme”, or directly apply either Green’s Theorem or Stokes’s > Theorem, depending on your training. > > That was the short, enigmatic answer (Google is your friend). The long > answer is: > > a) pick a point in the plane - any point. Call it O. [Hint: [0,0] works > best] > b) for each edge in the polygon, construct the triangle O,v[i], v[i+1 mod > n] > where n is the number of vertices and the numbering begins with 0 > and the edge goes from v[i] to v[i+1 mod n] > c) compute the SIGNED area of this triangle and accumulate the sum of the > SIGNED areas > d) the total SIGNED area will give the area of the polygon and the SIGN > will tell you > if the polygon is correctly oriented. > > A quick and dirty first implementation might stop here. To make it faster: > > e) for extra credit, re-arrange the terms to eliminate O [that’s why I > suggested that [0,0] works best]. You will arrive at a computation that > looks something like: > > AREA = 0.5 * SUM(v[i] CROSS v[i+1 mod n]) > > where: > the representation of the point v[i] is interpreted as a the > representation of a > vector from O to v[i] (no, points and vectors are not the same, but > SOME computations > can pretend that they are) > vertices are numbered 0..n-1 > > I have a beautiful proof-by-diagram of this, but it does not fit in ASCII > format. > > If you want to do Volumes, substitute triangular faces of the polyhedron > for the edges of the polygon. Use the scalar triple product instead of > cross product, and divide by 6 instead of 2. > > Proof left as an exercise for the reader. > > Green and Stokes showed that you can compute properties of the area by > walking around the perimeter. Their followers proved that one follows > from the other, and vice versa. Newman did the algebra and optimized the > computation in the context of computer graphics. > > Newman’s scheme dates to AT LEAST 1965. Green and Stokes were much > earlier. > > -- > Kenneth Sloan > KennethRSloan@gmail.com > Vision is the art of seeing what is invisible to others. > > > > > On Apr 11, 2016, at 21:41 , doug moen <doug@moens.org> wrote: > > Well, first you triangulate the polygon using the code posted to the > recent "Simple Polygon Triangulation" thread, then you add up the area of > each triangle? > > On 11 April 2016 at 17:04, Experimentalist < > experimentalist@aaawesome.co.uk> wrote: > >> Hi >> >> Since a polygon is essentially made up of triangles I presume this is not >> too hard. Anyone got a solution? I don't want to waste valuable time >> reinventing the wheel. >> >> Thanks >> Ex. >> >> >> >> -- >> View this message in context: >> http://forum.openscad.org/Easy-way-to-get-the-area-area-of-a-polygon-tp17045.html >> Sent from the OpenSCAD mailing list archive at Nabble.com >> <http://nabble.com>. >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> >> >> > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
KS
Kenneth Sloan
Tue, Apr 12, 2016 4:43 AM
If the polygon is in a 2D plane, then the cross product produces a scalar.  (At least, that’s the lie they teach to engineers; you may prefer to think of it as a vector in the z direction).  If the polygon lies in 3-space (but, one hopes, is planar), then, yes - the cross product produces a vector.
The cross-product of two 3D vectors is a vector which has a length twice the area of the triangle defined by the two input vectors.  The direction of the cross product is the surface normal.
The accumulated sums of all the cross-products produced by creating triangles from O and the successive vertices of the polygon is thus a vector with a length twice the area of the polygon (if the polygon is planar) and a direction perpendicular to the plane.
For extra credit: what is the interpretation of the length and direction of the computed vector when the vertices of the “polygon” do not lie in a plane?
Answer (I’m not cruel…): the direction is perpendicular to a “best-fit” plane through the wrinkled “polygon”, and the length is twice the area of the projection of the “polygon” onto that best-fit plane.
So…if you have wrinkled polygons and you want the area of the wrinkled surface…then you do have to triangulate.  Question: in this case, is the answer unique?
Kenneth Sloan
2016-04-12 0:01 GMT-03:00 Kenneth Sloan <kennethrsloan@gmail.com mailto:kennethrsloan@gmail.com>:
where:
Kenneth Sloan
On Apr 11, 2016, at 21:41 , doug moen <doug@moens.org mailto:doug@moens.org> wrote:
Hi
Thanks
Ex.
Sent from the OpenSCAD mailing list archive at Nabble.com http://nabble.com/.
If the polygon is in a 2D plane, then the cross product produces a scalar. (At least, that’s the lie they teach to engineers; you may prefer to think of it as a vector in the z direction). If the polygon lies in 3-space (but, one hopes, is planar), then, yes - the cross product produces a vector. The cross-product of two 3D vectors is a vector which has a length twice the area of the triangle defined by the two input vectors. The direction of the cross product is the surface normal. The accumulated sums of all the cross-products produced by creating triangles from O and the successive vertices of the polygon is thus a vector with a length twice the area of the polygon (if the polygon is planar) and a direction perpendicular to the plane. For extra credit: what is the interpretation of the length and direction of the computed vector when the vertices of the “polygon” do not lie in a plane? Answer (I’m not cruel…): the direction is perpendicular to a “best-fit” plane through the wrinkled “polygon”, and the length is twice the area of the projection of the “polygon” onto that best-fit plane. So…if you have wrinkled polygons and you want the area of the wrinkled surface…then you *do* have to triangulate. Question: in this case, is the answer unique? -- Kenneth Sloan KennethRSloan@gmail.com <mailto:KennethRSloan@gmail.com> Vision is the art of seeing what is invisible to others. > On Apr 11, 2016, at 23:30 , Ronaldo Persiano <rcmpersiano@gmail.com> wrote: > > Nice solution! If I undertand it well the AREA evaluated by the expression in e) is a vector. And the scalar area will be its norm. > > 2016-04-12 0:01 GMT-03:00 Kenneth Sloan <kennethrsloan@gmail.com <mailto:kennethrsloan@gmail.com>>: > It is absolutely NOT NECESSARY to triangulate in order to compute area. You can walk the perimeter and compute the area of the polygon. Google “Newman’s Scheme”, or directly apply either Green’s Theorem or Stokes’s Theorem, depending on your training. > > That was the short, enigmatic answer (Google is your friend). The long answer is: > > a) pick a point in the plane - any point. Call it O. [Hint: [0,0] works best] > b) for each edge in the polygon, construct the triangle O,v[i], v[i+1 mod n] > where n is the number of vertices and the numbering begins with 0 > and the edge goes from v[i] to v[i+1 mod n] > c) compute the SIGNED area of this triangle and accumulate the sum of the SIGNED areas > d) the total SIGNED area will give the area of the polygon and the SIGN will tell you > if the polygon is correctly oriented. > > A quick and dirty first implementation might stop here. To make it faster: > > e) for extra credit, re-arrange the terms to eliminate O [that’s why I suggested that [0,0] works best]. You will arrive at a computation that looks something like: > > AREA = 0.5 * SUM(v[i] CROSS v[i+1 mod n]) > > where: > the representation of the point v[i] is interpreted as a the representation of a > vector from O to v[i] (no, points and vectors are not the same, but SOME computations > can pretend that they are) > vertices are numbered 0..n-1 > > I have a beautiful proof-by-diagram of this, but it does not fit in ASCII format. > > If you want to do Volumes, substitute triangular faces of the polyhedron for the edges of the polygon. Use the scalar triple product instead of cross product, and divide by 6 instead of 2. > > Proof left as an exercise for the reader. > > Green and Stokes showed that you can compute properties of the area by walking around the perimeter. Their followers proved that one follows from the other, and vice versa. Newman did the algebra and optimized the computation in the context of computer graphics. > > Newman’s scheme dates to AT LEAST 1965. Green and Stokes were much earlier. > > -- > Kenneth Sloan > KennethRSloan@gmail.com <mailto:KennethRSloan@gmail.com> > Vision is the art of seeing what is invisible to others. > > > > >> On Apr 11, 2016, at 21:41 , doug moen <doug@moens.org <mailto:doug@moens.org>> wrote: >> >> Well, first you triangulate the polygon using the code posted to the recent "Simple Polygon Triangulation" thread, then you add up the area of each triangle? >> >> On 11 April 2016 at 17:04, Experimentalist <experimentalist@aaawesome.co.uk <mailto:experimentalist@aaawesome.co.uk>> wrote: >> Hi >> >> Since a polygon is essentially made up of triangles I presume this is not >> too hard. Anyone got a solution? I don't want to waste valuable time >> reinventing the wheel. >> >> Thanks >> Ex. >> >> >> >> -- >> View this message in context: http://forum.openscad.org/Easy-way-to-get-the-area-area-of-a-polygon-tp17045.html <http://forum.openscad.org/Easy-way-to-get-the-area-area-of-a-polygon-tp17045.html> >> Sent from the OpenSCAD mailing list archive at Nabble.com <http://nabble.com/>. >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org <mailto:Discuss@lists.openscad.org> >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org <http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org> >> >> >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org <mailto:Discuss@lists.openscad.org> >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org <http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org> > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org <mailto:Discuss@lists.openscad.org> > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org <http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org> > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
Ronaldo
Tue, Apr 12, 2016 5:11 AM
It should be noted that all this is true for simple polygons.
function area(p) = abs( sum_list( [ for(i=[0:len(p)-1]) cross2D( p[i],
p[(i+1)%len(p)] ) ] ) )/2;
function sum_list(v, i=0, sum=0) = i==len(v) ? sum : sum_list(v, i+1,
sum+v[i] );
function cross2D(p, q) = p[0]*q[1] - p[1]*q[0];
p = 10*[ [1,0], [2,0], [2,1], [1,1] ];
q = 10*[ [1,20], [2,21], [2,20], [1,21] ];
polygon(p);
polygon(q);
echo(area_p=area(p));
echo(area_q=area(q));
View this message in context: http://forum.openscad.org/Easy-way-to-get-the-area-of-a-polygon-tp17045p17058.html
It should be noted that all this is true for simple polygons. > function area(p) = abs( sum_list( [ for(i=[0:len(p)-1]) cross2D( p[i], > p[(i+1)%len(p)] ) ] ) )/2; > > function sum_list(v, i=0, sum=0) = i==len(v) ? sum : sum_list(v, i+1, > sum+v[i] ); > > function cross2D(p, q) = p[0]*q[1] - p[1]*q[0]; > > > p = 10*[ [1,0], [2,0], [2,1], [1,1] ]; > q = 10*[ [1,20], [2,21], [2,20], [1,21] ]; > polygon(p); > polygon(q); > echo(area_p=area(p)); > echo(area_q=area(q)); -- View this message in context: http://forum.openscad.org/Easy-way-to-get-the-area-of-a-polygon-tp17045p17058.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Tue, Apr 12, 2016 5:53 AM
There’s also the example that comes with OpenSCAD: https://github.com/openscad/openscad/blob/master/examples/Functions/polygon_areas.scad
There’s also the example that comes with OpenSCAD: https://github.com/openscad/openscad/blob/master/examples/Functions/polygon_areas.scad -Marius
Tue, Apr 12, 2016 2:09 PM
Thanks, Kenneth. I translated your algorithm into this:
function area(vs) =
let (n = len(vs))
abs(0.5 * sum([for (i=[0:n-1]) cross(vs[i], vs[(i+1)%n])]));
function sum(v,i=0) =
i < len(v) ? v[i] + sum(v,i+1) : 0;
I used abs() to convert the signed area into an absolute value, since the
polygon() module doesn't care about the winding order of the vertices.
This turns out to be the same as Marius's solution, except that it returns
an absolute value, and also, the division by 2 happens at the end, instead
of once for each vertex.
I ran some tests, and it mostly works as expected. Degenerate polygons work
(area==0).
Self-intersecting polygons do not work, which is inconsistent with the
polygon() primitive. So the area won't match what polygon() draws on the
screen in this case.
Here's that last test case:
//self intersecting quad
weird = [
[0,0],
[0,1],
[1,0],
[1,1],
echo(area(weird)); // 0
polygon(weird);
answer is:
best]
n]
SIGNED areas
will tell you
where:
representation of a
SOME computations
format.
earlier.
Kenneth Sloan
each triangle?
Hi
Thanks
Ex.
http://nabble.com.
Thanks, Kenneth. I translated your algorithm into this: function area(vs) = let (n = len(vs)) abs(0.5 * sum([for (i=[0:n-1]) cross(vs[i], vs[(i+1)%n])])); function sum(v,i=0) = i < len(v) ? v[i] + sum(v,i+1) : 0; I used abs() to convert the signed area into an absolute value, since the polygon() module doesn't care about the winding order of the vertices. This turns out to be the same as Marius's solution, except that it returns an absolute value, and also, the division by 2 happens at the end, instead of once for each vertex. I ran some tests, and it mostly works as expected. Degenerate polygons work (area==0). Self-intersecting polygons do not work, which is inconsistent with the polygon() primitive. So the area won't match what polygon() draws on the screen in this case. Here's that last test case: //self intersecting quad weird = [ [0,0], [0,1], [1,0], [1,1], ]; echo(area(weird)); // 0 polygon(weird); On 11 April 2016 at 23:01, Kenneth Sloan <kennethrsloan@gmail.com> wrote: > It is absolutely NOT NECESSARY to triangulate in order to compute area. > You can walk the perimeter and compute the area of the polygon. Google > “Newman’s Scheme”, or directly apply either Green’s Theorem or Stokes’s > Theorem, depending on your training. > > That was the short, enigmatic answer (Google is your friend). The long > answer is: > > a) pick a point in the plane - any point. Call it O. [Hint: [0,0] works > best] > b) for each edge in the polygon, construct the triangle O,v[i], v[i+1 mod > n] > where n is the number of vertices and the numbering begins with 0 > and the edge goes from v[i] to v[i+1 mod n] > c) compute the SIGNED area of this triangle and accumulate the sum of the > SIGNED areas > d) the total SIGNED area will give the area of the polygon and the SIGN > will tell you > if the polygon is correctly oriented. > > A quick and dirty first implementation might stop here. To make it faster: > > e) for extra credit, re-arrange the terms to eliminate O [that’s why I > suggested that [0,0] works best]. You will arrive at a computation that > looks something like: > > AREA = 0.5 * SUM(v[i] CROSS v[i+1 mod n]) > > where: > the representation of the point v[i] is interpreted as a the > representation of a > vector from O to v[i] (no, points and vectors are not the same, but > SOME computations > can pretend that they are) > vertices are numbered 0..n-1 > > I have a beautiful proof-by-diagram of this, but it does not fit in ASCII > format. > > If you want to do Volumes, substitute triangular faces of the polyhedron > for the edges of the polygon. Use the scalar triple product instead of > cross product, and divide by 6 instead of 2. > > Proof left as an exercise for the reader. > > Green and Stokes showed that you can compute properties of the area by > walking around the perimeter. Their followers proved that one follows > from the other, and vice versa. Newman did the algebra and optimized the > computation in the context of computer graphics. > > Newman’s scheme dates to AT LEAST 1965. Green and Stokes were much > earlier. > > -- > Kenneth Sloan > KennethRSloan@gmail.com > Vision is the art of seeing what is invisible to others. > > > > > On Apr 11, 2016, at 21:41 , doug moen <doug@moens.org> wrote: > > Well, first you triangulate the polygon using the code posted to the > recent "Simple Polygon Triangulation" thread, then you add up the area of > each triangle? > > On 11 April 2016 at 17:04, Experimentalist < > experimentalist@aaawesome.co.uk> wrote: > >> Hi >> >> Since a polygon is essentially made up of triangles I presume this is not >> too hard. Anyone got a solution? I don't want to waste valuable time >> reinventing the wheel. >> >> Thanks >> Ex. >> >> >> >> -- >> View this message in context: >> http://forum.openscad.org/Easy-way-to-get-the-area-area-of-a-polygon-tp17045.html >> Sent from the OpenSCAD mailing list archive at Nabble.com >> <http://nabble.com>. >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> >> >> > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
Ronaldo
Tue, Apr 12, 2016 3:29 PM
To calculate area or even to fill a self-intersecting polygons is ambiguous.
The drawing of a self-intersecting polygon done by primitive polygon() is
just one of the alternatives. Consider an extrusion of the polygon:
p = [ [0,0], [7,0], [7,7], [3,7], [3,3], [10,3], [10,10], [0,10] ];
polygon(p);
which has a hole in it. If you process that extrusion with slic3r and
Simplify3D you will get rather different results. Each one choose its own
interpretation of the hole of polygon(). Slic3r does preserve the hole,
Simplify3D fill it. And nobody can argue that one of them is wrong.
View this message in context: http://forum.openscad.org/Easy-way-to-get-the-area-of-a-polygon-tp17045p17081.html
doug.moen wrote > Self-intersecting polygons do not work, which is inconsistent with the > polygon() primitive. So the area won't match what polygon() draws on the > screen in this case. To calculate area or even to fill a self-intersecting polygons is ambiguous. The drawing of a self-intersecting polygon done by primitive polygon() is just one of the alternatives. Consider an extrusion of the polygon: > p = [ [0,0], [7,0], [7,7], [3,7], [3,3], [10,3], [10,10], [0,10] ]; > polygon(p); which has a hole in it. If you process that extrusion with slic3r and Simplify3D you will get rather different results. Each one choose its own interpretation of the hole of polygon(). Slic3r does preserve the hole, Simplify3D fill it. And nobody can argue that one of them is wrong. -- View this message in context: http://forum.openscad.org/Easy-way-to-get-the-area-of-a-polygon-tp17045p17081.html Sent from the OpenSCAD mailing list archive at Nabble.com.
