Are function calls and expressions cached like geometry? I am interested in
possibilities to exploit caching for some speed up. So my question is to
what extent is what Cached at different levels.
In my case I call the same function with the same parameters from different
parts of a recursion.
View this message in context: http://forum.openscad.org/What-is-Cached-tp21015.html
I am pretty sure functions aren't cached at the moment as they run quite
fast compared to the geometry in a normal OpenSCAD script.
in
At the moment, no, but OpenSCAD is designed to be able to exploit such referential transparency and hence cache expression results.
A good way to cache expression results is to implement compiler
optimizations such as common subexpression elimination, and lifting of
invariant expressions. The net result is that during runtime, there are
fewer evaluations of an expression that returns the same result each time.
This would be my recommendation.
Another way to cache expression results might be, at runtime, to hash a
function name with its arguments and do a lookup in a hash table to see if
the result has already been computed. But, this doesn't decrease the number
of times we attempt to evaluate the expression, and it adds additional
runtime overhead to the evaluation of the expression. So it is less likely
to be a win.
Haskell and some other functional languages use lazy evaluation. An
expression is compiled into a thunk, which is passed around at run time.
The first time that the thunk is referenced in a value context, it is
executed, and then the thunk object is overwritten with the resulting
value. This approach also introduce a run-time overhead. It can speed up
some programs, if a lot of expensive thunks never get evaluated, but it can
slow down other programs.
OpenSCAD is not 100% referentially transparent. If a function F directly or
indirectly calls rands, then calls to F aren't referentially transparent,
and that inhibits the ability to do these optimizations. rands should be
deprecated and replaced by a referentially transparent random number
facility based on hashing.
