V
vulcan_@mac.com
Sat, Sep 20, 2025 1:03 AM
I cannot reproduce the bug with “Save A Copy ..” that is reported in issue #6183 but i would like a small change in its operation …
I have always liked to have “_copy“ appended to an existing file name in the File Dialog when doing Save A Copy, so i have added code in TabManager.cc to do just that ..
I think.
Compiling in Windows is a challenge I have not yet mastered so I cannot test the code and i am not sure i am using the features of Qt correctly so .. feedback requested on
https://github.com/bitbasher/openscad-bit/blob/bitbasher-bug-fixes/src/gui/TabManager.cc
lines starting at 668, please.
I cannot reproduce the bug with “Save A Copy ..” that is reported in [issue #6183](https://github.com/openscad/openscad/issues/6183) but i would like a small change in its operation …
I think.
V
vulcan_@mac.com
Sat, Sep 20, 2025 1:06 AM
and .. would making a PR be a normal way to ask for feedback? I had started to write one up but thought better of it and came here
Sat, Sep 20, 2025 1:17 AM
Yes, PR is a lot better.
But for GUI changes specifically, the crucial part is that is should be tested and verified manually, as nobody else is likely to build and run and test the code on your behalf.
Doing this under Windows can be tricky. If you have access to a macOS or Linux machine, this should be a bit more streamlined for now.
On Sep 19, 2025, at 21:06, vulcan_--- via Discuss discuss@lists.openscad.org wrote:
> On Sep 19, 2025, at 21:06, vulcan_--- via Discuss <discuss@lists.openscad.org> wrote:
FH
Father Horton
Sat, Sep 20, 2025 1:38 AM
Use WSL. I have built OpenSCAD that way.
On Fri, Sep 19, 2025 at 8:17 PM Marius Kintel via Discuss <
> -Marius
Sat, Sep 20, 2025 2:37 AM
I think the MSYS2 build process is now fairly straightforward. I don't
remember having significant trouble the last time I started from
scratch; I think I just ran the commands the instructions told me to run.
It doesn't build a "real" Windows executable - it depends on a number of
MSYS2 libraries - but it's a good start.
And if you're patient, if you file a PR the CI build will make you an
installer. It just takes half an hour or so, versus maybe 3-4m on my
not-that-spectacular desktop.
GB
Glenn Butcher
Sat, Sep 20, 2025 3:03 AM
MSYS2 executables are real windows .exe files. That they depend on .dll library files not in the c:\windows\system32 directory is no different than an executable built with Microsoft tools.
On September 19, 2025 4:37:44 PM HST, Jordan Brown via Discuss discuss@lists.openscad.org wrote:
Sent from my Android device with K-9 Mail. Please excuse my brevity.
On September 19, 2025 4:37:44 PM HST, Jordan Brown via Discuss <discuss@lists.openscad.org> wrote:
Sat, Sep 20, 2025 3:20 AM
Sure. I don't know how deep the dependency tree is or how many
libraries you'd have to copy, but if you copy enough it'll work.
My point, on which I was perhaps unclear, is that the executable that
results is not the same as the one that comes out of the production
build. A production openscad.exe does not appear to have any DLL
dependencies other than those in \Windows\System32; it appears that you
can copy only that openscad.exe to a different place, and it will
still work.
Perhaps there is a way to get the MSYS2 build to statically link the
libraries it uses. I don't know. The default MSYS2 build does dynamic
linking.
can copy *only* that openscad.exe to a different place, and it will
still work.
linking.
GB
Glenn Butcher
Sat, Sep 20, 2025 5:53 AM
True, MSYS2 library packages tend to be .dll files. When I want to make a Windows installer of a software, I'll use the Linux-based mxe cross-compiler. It builds an environment of all static- compiled libraries. I'd surmise openscad releases are made the same way.
On September 19, 2025 5:20:17 PM HST, Jordan Brown openscad@jordan.maileater.net wrote:
still work.
linking.
On September 19, 2025 5:20:17 PM HST, Jordan Brown <openscad@jordan.maileater.net> wrote:
>still work.
>linking.
V
vulcan_@mac.com
Sat, Sep 20, 2025 8:08 AM
i like that .. being the lazy soul that i am .. where do i find the installer file to download ?
i am about to start hunting for it .. but GitHub is really good at hiding stuff when
you are looking for things ..
i am about to start hunting for it .. but GitHub is _really_ good at hiding stuff when\
Sat, Sep 20, 2025 5:30 PM
I don’t do it very often so I don’t know where it is exactly. I believe it’s under the CI build in the list of checks, and it’s under “artifacts”.
