When I use the version_num(), I get a exponent type number.
Not at all what I expected, but that's ok. I figured out another way to get
what I really want, but it is strange.
Consider the following code:
function fzs2(x) = len(str(x)) < 2 ? str("0",x) : str(x);
//function fzs3(x) = len(str(x)) < 3 ? str("00",x) : str(x);
//function fzs4(x) = len(str(x)) < 4 ? str("000",x) : str(x);
//function fzs5(x) = len(str(x)) < 5 ? str("0000",x) : str(x);
echo(version()); // [2016,11,6]
echo(str(version()[0],
fzs2(version()[1]),
fzs2(version()[2]))); // "20161106" which is what I want.
I thought, ok: this works in this special case.
Then I got to thinking about the printf statement in C for instance.
Where "%.4d" would print out any integer with leading zero's filled in to
the width of the number.
So, I tried defining the following functions, and of course they only work
for special cases.
Like what if I do fzs3(12) for instance? it comes back "0012" and not "012"
like in the printf case. But of course, fzs3(3) would be fine.
So, is there any way to do this generally? without being really messy?
Just wondering.
Regards,
Jerry
Extra Ham Operator: K7AZJ
Registered Linux User: 275424
Try a recursive version of your function.
v = version();
n = 2;
echo(v); // [2016,11,6]
echo(str(
fzs(4, v[0]),
fzs(n, v[1]),
fzs(n, v[2])
function fzs(n=1, x) = len(str(x)) < n ? fzs(n, str("0",x)) : str(x);
View this message in context: http://forum.openscad.org/generalized-zero-fill-on-numbers-tp19916p19918.html
v = version();
n = 2;
echo(str(
fzs(4, v[0]),
fzs(n, v[1]),
fzs(n, v[2])
Technically, you could do that, but if you wanted to do it slightly more
efficiently you would use tail recursion:
It doesn't really matter in this case as x is likely to be small, but it is
just a good habit to get into. See Recursive Functions
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/User-Defined_Functions_and_Modules#Recursive_functions
for more information.
View this message in context: http://forum.openscad.org/generalized-zero-fill-on-numbers-tp19916p19959.html
adrian wrote
v = version();
n = 2;
echo(str(
fzs(4, v[0]),
fzs(n, v[1]),
fzs(n, v[2])
is just a good habit to get into. See
Recursive Functions
I usually prefer the form you suggest but both of them are eligible to tail
recursion elimination as noted in the reference you mentioned.
View this message in context: http://forum.openscad.org/generalized-zero-fill-on-numbers-tp19916p19966.html
tail recursion elimination as noted in the reference you mentioned.
Huh. Strange. I must have been a zombie when I posted that. :)
View this message in context: http://forum.openscad.org/generalized-zero-fill-on-numbers-tp19916p19975.html
