The cutting cylinders need to be longer than the object they cut, not the
precise right size, or you'll have problems with your model. Just make them
silly long.
OpenSCAD mailing list-2 wrote
AdrianV, Ray West, Troberg
Thanks for all your suggestions! :-) I now understand at least two new
ways of reaching my goal; hull, linear_extrude and mirror. Just need to
focus on the maths now. The vertical offset was left over from some tests
I did and shouldn't have been in the original code but I've put it in to
the Hull based model now, added an additional horizontal spacing between
the vertical cylinder centres (to allow swing room for the arm) and am now
trying to work out the maths to ensure that the cylinders that cut the
holes are the right length. Yes, I could make them silly long so they
definitely cut right through but its all part of the challenge. Thanks,
all, for your ideas.
Chris
On Tue, 20 Apr 2021 at 08:36, <
discuss-request@.openscad
> wrote:
Send Discuss mailing list submissions to
discuss@.openscad
To subscribe or unsubscribe via email, send a message with subject or
body 'help' to
You can reach the person managing the list at
discuss-owner@.openscad
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Discuss digest..."
Today's Topics:
1. Tangential join/infill two parallel vertical cylindrical tubes.
(Chris Johnson)
2. Re: Tangential join/infill two parallel vertical cylindrical tubes.
(adrianv)
3. Re: Tangential join/infill two parallel vertical cylindrical tubes.
(Ray West)
4. Re: Tangential join/infill two parallel vertical cylindrical tubes.
(Troberg)
5. Meassuerments workarround (Karl Exler)
Message: 1
Date: Mon, 19 Apr 2021 23:49:30 +0100
cjohnsonuk@
Subject: [OpenSCAD] Tangential join/infill two parallel vertical
cylindrical tubes.
To:
discuss@.openscad
Message-ID:
CAEC-mOHVaTRPgwY00+Pv+92swrAv+uRCgFW4SbXign8LPno5vg@.gmail
Content-Type: multipart/alternative;
boundary="000000000000b02fc605c05b2694"
I have 2 parallel vertical cylinders with different diameters that are
adjacent and touching. I want to fill the space 'between' the cylinders
to
join them securely. I did think about creating a polygon block that I
join
with the two cylinders before taking the inner cylinders away to make a
straight edge join but I thought this is a simple enough model to learn
how
to use the roundanything library to create a fill with a radius of my
choosing. However , being a noob, Not sure where to start.
back story: The larger cylinder fits over my monitor stand. The smaller
Cylinder is for an anglepoise arm for a webcam/ video light. I just need
to be able to join them nicely so that they don't break apart.
Here's what I've got so far.:
include <Round-Anything/MinkowskiRound.scad>;
$fn=10;
br=32;
sr=12.3;
bw=5;
sw=4;
height=12;
boundingEnvelope=[50,50,50];
OR=0.7;
IR=1;
enable=1;
minkowskiRound(OR, IR, enable, boundingEnvelope) {
union(){
translate([0,0,-10]){
cylinder (height,br+bw,br+bw,center=true);
cylinder (height+2,br,br,center=true);
translate([br+sr+sw+bw,0,0]){
cylinder (height,sr+sw,sr+sw,center=true);
cylinder (height+2,sr,sr,center=true);
But I just get a spinning circle on my Mac.
not sure how the bounding envelope works or how long I should expect to
wait for a result.
Any help appreciated:
Chris Johnson
If you do a 2d drawing of the extrusion profile, and extrude, you have
no problem wrt the length of the hole. The example I previously posted,
a separation value can be added, and modify each translation value for
x in the modules (and also the 'wedge polygon). If you are fussy about
the tangent, then you could remove (or not bother) the 'filler' module,
and its references, and replace the code after the '$fn=80;' by
hull(){
linear_extrude(height)
skin();
translate([0,0,-height])linear_extrude(height*3)holes();
you need longer holes in 3d if you want to be sure that' it knows the
holes go right through', and making them three times longer and
translating back one length, is the easiest.
not the precise right size, or you'll have problems with your model.
Just make them silly long.
two new
need to
some tests
in to
between
and am now
they
Thanks,
Chris
On Tue, 20 Apr 2021 at 08:36, <[hidden email]
</user/SendEmail.jtp?type=email&email=discuss-request%40.openscad>>
[hidden email]
</user/SendEmail.jtp?type=email&email=discuss%40.openscad>
subject or
body 'help' to
[hidden email]
[hidden email]
</user/SendEmail.jtp?type=email&email=discuss-owner%40.openscad>
Today's Topics:
tubes.
(Chris Johnson)
cylindrical tubes.
(adrianv)
cylindrical tubes.
(Ray West)
cylindrical tubes.
(Troberg)
Message: 1
</user/SendEmail.jtp?type=email&email=cjohnsonuk%40>>
cylindrical tubes.
To: [hidden email]
Message-ID:
[hidden email]
</user/SendEmail.jtp?type=email&email=CAEC-mOHVaTRPgwY00%2BPv%2B92swrAv%2BuRCgFW4SbXign8LPno5vg%40.gmail>>
that are
cylinders to
that I join
make a
to learn how
of my
smaller
just need
$fn=10;
br=32;
sr=12.3;
bw=5;
sw=4;
height=12;
OR=0.7;
IR=1;
enable=1;
union(){
expect to
wait for a result.
Chris Johnson
