On 4 March 2017 at 15:23, dnivoG dnivogamrahs@gmail.com wrote:
Hi, I have just started with OpenSCAD and was looking into this issue with
Amarjeet. After playing around with the code and following along with what
happens upon pressing F6 and the cancel button, I have discovered (or just
implied) that although the slot corresponding to the cancel button on the
progress widget only sets true, the value of bool wascancelled; it is
somehow able to stop proceedings before the function:
evaluator.evaluateGeometry() finishes doing its job.
Once this function actually finishes, then the cancel button does nothing it
seems even on consecutive presses of F6. But if on the first press of F6,
the cancel button is pressed before the evaluator.evaluateGeometry()
function returns from its call, then the process is somehow stopped printing
in accordance to the following catch block in the CGALWorker::work()
function:
catch (const ProgressCancelExcetion &e) {
PRINT("Rendering Cancelled.");
My enquiry is that how is this exception generated by a simple assignment of
true to the wascancelled variable in the progressWidget object.
I also intent to raise the same query. It is crucial from our point of
view as we are kind of stuck at this point.
Amarjeet Singh
https://amarjeetkapoor1.wordpress.com
https://github.com/amarjeetkapoor1
https://bitbucket.org/amarjeetkapoor
"The journey of a thousand commit begins with a single init"
Seethe Throw in
https://github.com/openscad/openscad/blob/4af51a7443e5f6e8fb234beadc8128261854ae68/src/mainwin.cc#L764
View this message in context: http://forum.openscad.org/Should-have-an-option-to-ask-to-render-when-pressing-F6-tp20486p20911.html
On 15 March 2017 at 10:22, MichaelAtOz oz.at.michael@gmail.com wrote:
Seethe Throw in
Thanks.
Like in case of CSG, we have also used the node.progress_report() function
in GeometryEvaluator::visit (
https://github.com/openscad/openscad/blob/master/src/GeometryEvaluator.cc#L524
) function that essentially raises the exception upon the press of the
cancel button.
Amarjeet Singh
Amarjeet Singh
