There are times that I accidentally press F6 and I have to wait an inordinate
amount of time for it to complete the render as the cancel doesn't work well
enough to be useful. It would be nice if there was an option to ask the
user, "Are you sure you want to render?"
View this message in context: http://forum.openscad.org/Should-have-an-option-to-ask-to-render-when-pressing-F6-tp20486.html
There are 'hotkey' utilities out there that can intercept keystrokes and do
what you want.
For Windows I use autohothey https://www.autohotkey.com/ .
Yes
Are you sure you meant to say yes? (type YES to confirm)
YES GOD DAMN YOU
Render cancelled
View this message in context: http://forum.openscad.org/Should-have-an-option-to-ask-to-render-when-pressing-F6-tp20486p20487.html
Well, this is what I think.
I really don't want the program to ask me if I really want to do something.
This annoys me.
BUT, I don't think the cancel render button (the x) works at all.
If we fix that, then all would be well.
I know from my old programming days, if you do some really cpu intensive
calculations, that if you don't check for the presence of a cancel variable
once in a while, then there is no way it can be cancelled. So, what would
be needed is to check every nook and cranny of the render code, to see
where it would be necessary to check that cancel variable and do the right
thing.
Jerry
Extra Ham Operator: K7AZJ
Registered Linux User: 275424
On Sat, Feb 18, 2017 at 9:47 PM, MichaelAtOz oz.at.michael@gmail.com
what you want.
Yes
YES GOD DAMN YOU
Render cancelled
Adding cancel points to CGAL would require making a private copy of CGAL
,hacking it, then reapplying those hacks when new releases of CGAL come
out. It's a big complex library. I'm assuming we don't do that now, and it
seems undesirable.
We could also do the rendering in a separate thread, and abandon that
thread if cancel is pressed. That seems more achievable.
something. This annoys me.
thing.
Jerry
do
what you want.
Yes
YES GOD DAMN YOU
Render cancelled
Jerry:
I thought he wanted an OPTION to add this feature/question. If the rest
of us can turn the option off, I don't see what is wrong with his
suggestion.
intensive calculations, that if you don't check for the presence of a
cancel variable once in a while, then there is no way it can be
cancelled. So, what would be needed is to check every nook and cranny
of the render code, to see where it would be necessary to check that
cancel variable and do the right thing.
Jerry
/The most exciting phrase to hear in science - the one that heralds
new discoveries - is not "Eureka!" but "That's funny...".
/- Isaac. Asimov
On Sat, Feb 18, 2017 at 9:47 PM, MichaelAtOz <oz.at.michael@gmail.com
keystrokes and do
what you want.
For Windows I use autohothey <https://www.autohotkey.com/> .
Yes
YES GOD DAMN YOU
Render cancelled
Admin - PM me if you need anything, or if I've done something
stupid...
Unless specifically shown otherwise above, my contribution is in
the Public Domain; to the extent possible under law, I have waived
all copyright and related or neighbouring rights to this work.
Obviously inclusion of works of previous authors is not included
in the above.
http://www.ourfairdeal.org/ time is running out!
<http://forum.openscad.org/Should-have-an-option-to-ask-to-render-when-pressing-F6-tp20486p20487.html>
Checked by AVG - www.avg.com http://www.avg.com/email-signature
Version: 2016.0.7998 / Virus Database: 4756/13975 - Release Date: 02/19/17
Yup. Just an option.
Yes, I do know about AHK. I use it all the time, however, because the cancel
is broken, the user should be given the option to not start a render if it
says invoked by accident. And this should be in the program, not as an
external workaround.
View this message in context: http://forum.openscad.org/Should-have-an-option-to-ask-to-render-when-pressing-F6-tp20486p20502.html
Jon:
I didn't see that. Ok. Option ok. Turn it off by default ok.
Doug:
Didn't know OpenSCAD used a separate lib for CGAL. Separate thread that is
cancellable is better.
cancel
seems undesirable.
This strongly depends on how the library works. If you call it adding
objects and that at the end you call "now_render_it ()" then your
argument holds.
But if WE maintain the upper level loop that implements the time
consuming work, then of course we can step out of that loop easily
when cancel is pressed.
But this is of cousr something that can always be done. (.... at least
once: if you abort a rendering, I'm not sure the internal state is clean
enough to ever be able to restart it again....)
Rogier: yes, that's it. I now remember a discussion by the dev team about
how CGAL is not thread safe. It is something they are working on. There is
also an open CGAL bug to add callbacks to better support progress bars.
My understanding is that we have a cancel operation, but cancellation is
deferred while executing a CGAL CSG operation, which can take hours. And
that's hard to fix given CGALs limitations, especially lack of thread
safety.
it
seems undesirable.
argument holds.
We could also do the rendering in a separate thread, and abandon that thread if cancel is pressed. That seems more achievable.
We already perform rendering in a separate thread: https://github.com/openscad/openscad/blob/master/src/cgalworker.cc
While we can abandon this thread, it would still continue to use resources and block any other CGAL operation until the thread ends. I’m not too excited about that idea.
I’m not aware of any safe way to kill a thread, but that could be a worthwhile investigation.
