Just discovered that functions and modules can be defined locally within a
module. After searching the documentation and forum, can't determine if this
is an officially supported feature.
Question: Is this a feature of the language or might it go away at some
point?
...very useful!
RAS
It's widely used, so won't be going anywhere.
What?
You mean I can do a:
module mypart(){
module mysubpart(){
//Do stuff
mysubpart();
Mysubpart wouldn't be visible outside mypart?
That would be amazingly useful, and should definitely be documented!
Yes you can do that. Also mysubpart() can access the variables in mypart().
On Thu, 10 Jan 2019 at 07:26, Troberg troberg.anders@gmail.com wrote:
What?
module mypart(){
module mysubpart(){
//Do stuff
mysubpart();
Now mentioned in the wiki
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/User-Defined_Functions_and_Modules
