Tue, Oct 18, 2016 9:18 PM
On the other hand, until it has been further tested, I am very shy about
guaranteeing the code will work everywhere.
I just finished implementing this functionality myself. Here are some
things I would include in a thorough set of unit tests:
- builtin functions like
sin can be referenced as function values
- "closures" work correctly. If a function references a non-local variable
X, then X retains its value within the body of the function, even if the
function value outlives the scope of X.
- recursively defined functions don't cause a storage leak. This is a
problem when you are using reference counting, and you implement closures
in "the obvious way": recursive functions lead to a reference cycle, which
causes a storage leak. It took me a while to figure out how to fix this.
Doug.
On 18 October 2016 at 01:37, otto otto@123phase.com wrote:
Thanks for kind words and encouragement.
RE:
Also there's always the concern of breaking scripts, so
syntax changes are slower than other changes.
The changes are small.
I am nearly sure all old scripts will work with this syntax addition.
Regards
Otto
On Mon, 17 Oct 2016 23:56:04 +0200
Torsten Paul Torsten.Paul@gmx.de wrote:
On 10/17/2016 10:26 PM, otto wrote:
I am somewhat concerned that my syntax will be passed
by on the next newer and better version of OpenScad and
will be obsolete.
Trying this out will help to get a feeling of how it works
and maybe find potential issues, that's very useful.
For integration we should try finding a way that is
compatible with the ideas for a future language version.
It's likely going to be quite some time until a new
language version will happen, still making the task
unnecessary difficult is not a good idea.
It seems that there is very little work going on at the
moment to expand the syntax. That speaks loads about the
excellent quality of the current syntax and code, since
it is clearly being used widely.
I can only speak for myself, but the reason for very little
going on is totally to blame on lack of spare time.
This is only for the sake of making it easy to download
an compile reliably. I am unfamiliar with github and the
ethics of cooperation on the open source site, so forgive
me and inform me if this is the wrong approach to getting
new code into the world and tested.
Working from github certainly makes things easier, I'll
try to build some special Windows snapshots for people
who just want to give it a try. Might take a couple of
days though...
If you want to chat a bit more interactively, you can
find Marius (nickname kintel) and me (nickname teepee)
quite often in the #openscad IRC channel on freenode.
Just say hello and hang around a bit, someone will
notice eventually.
http://webchat.freenode.net/?channels=openscad
Small note on git/github usage, it will probably help to
work on changes in a separate branch instead of directly
using master. It's usually better to merge things in
smaller changes that belong to a single topic (via pull
requests). If everything is just committed to master,
it's much more complicated as everything is mixed together.
Who else is working on the OpenScad C++/parser code here
and what are they doing?
* builtin functions like `sin` can be referenced as function values
* "closures" work correctly. If a function references a non-local variable
* recursively defined functions don't cause a storage leak. This is a
Doug.
> RE:
> Regards
> Otto
> > > will be obsolete.
> > days though...
> > notice eventually.
> > I'm not aware of bigger changes going on in the parser,
> > I think the latest bigger change was about better line
> > number tracking and that is in master now.
> > ciao,
> > Torsten.
> > OpenSCAD mailing list
> > Discuss@lists.openscad.org
> > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
runsun
Tue, Oct 18, 2016 9:35 PM
There is no need for lambda at all. It is only syntactic sugar and since
nobody can agree on the syntax it is only ever sweet for a subset of
people.
I disagree. There are places where a lambda is better fitted. For
example, a temporary, quick handler like that in array.map( x=> x+2 ).
The need of making a named function for this purpose actually makes
the code more complicated and harder to write.
Personally, I don't mind what syntax to use. As long as the feature is
there, I'll just adopt to it. Besides, nothing can please everybody.
The important thing is to have it available for people who want it. For
those who don't, then simply don't use it. I don't think it's gonna hurt.
$ Runsun Pan, PhD $ libs: doctest , faces ( git ), offline doc ( git ), runscad.py ( 2 , git ), synwrite ( 2 ); $ tips: hash ( 2 ), matrix ( 2 , 3 ), sweep ( 2 , 3 ), var ( 2 ), lerp , animation ( gif , prodVid , animlib ), precision ( 2 ), xl-control , type , rounded polygon , chfont , tailRecur ( 2, 3 ), isosphere ( 2 ), area , vol/center , RGB , CurvedImg , tests ( 2 ); $ Apps: rollApp , blockscad , openjscad , on AWS ( pdf )
View this message in context: http://forum.openscad.org/Convert-from-object-to-polygon-polyhedron-tp18522p18769.html
> people.
runsun
Tue, Oct 18, 2016 9:36 PM
In terms of programming language popularity, it's really a tossup. I'm
using -> for a couple of reasons.
- The → symbol is what's used in mathematics to describe functions, eg
f
: x → x².
- There are already too many operators that contain the = character (=,
==, <=, >=), and all of these operators have some connection to the
concept of equality. The => symbol looks too much like these other
operators.
Good points.
View this message in context: http://forum.openscad.org/Convert-from-object-to-polygon-polyhedron-tp18522p18770.html
> f
> : x → x².
> operators.
Good points.
Tue, Oct 18, 2016 10:52 PM
people.
How is it hard or complicated to write a named function add2(x) = x + 2; ?
Anybody that knows how to write an OpenScad function can do it and the
result is more readable, it is just a bit more verbose, but not much.
It means OpenSCAD code becomes a little harder to read for people that have
not come across lambda before. Its syntax becomes more complex but there
isn't anything new that can be done with it. It becomes a slightly bigger
language to learn.
It also means OpenSCAD needs more maintenance as its code gets a bit bigger
and there needs to be a more test cases. Fine for indirect functions
because they add power but lambda doesn't. It is just a slight shortcut
that saves you thinking up a name. Unless some optimisation is done it
leads to code duplication because once a named function is written it can
be used multiple times.
> > people.
language to learn.
GW
G. Wade Johnson
Wed, Oct 19, 2016 3:33 AM
and since nobody can agree on the syntax it is only ever sweet
for a subset of people.
). The need of making a named function for this purpose actually
makes the code more complicated and harder to write.
2; ?
No harder than it would be to require that arithmetic expressions can
only be written in functions.
Just like it can be handy to have an arithmetic expression in-line,
sometimes having a function in-line is clearer than the alternative.
G. Wade
is there, I'll just adopt to it. Besides, nothing can please
everybody. The important thing is to have it available for people
who want it. For those who don't, then simply don't use it. I don't
that have not come across lambda before. Its syntax becomes more
complex but there isn't anything new that can be done with it. It
becomes a slightly bigger language to learn.
bigger and there needs to be a more test cases. Fine for indirect
functions because they add power but lambda doesn't. It is just a
slight shortcut that saves you thinking up a name. Unless some
optimisation is done it leads to code duplication because once a
named function is written it can be used multiple times.
$ Apps: rollApp , blockscad , openjscad , on AWS ( pdf ) --
You write code as if the person who will maintain your code is a violent
psychopath who knows where you live. -- John F. Woods
On Tue, 18 Oct 2016 23:52:33 +0100
> 2; ?
G. Wade
runsun
Wed, Oct 19, 2016 4:04 AM
Well, when you write the code up to the point of "arr.map(...", you have
to leave the code and move to another place to write "function add2(x) = x +
2;",
then move back to complete it.
With lambda, you finish the code right there, don't have to switch places.
This is the same for code reader. When a reader reads the code to that
point, he/she has to first search and locate that function, then switch to
there to understand it, then switch back to continue. That's a lot of
distractions for such a simple task.
This is what I call brain twists, an unnecessary detour or distraction
to your coding focus. IMO, a good language should reduce these sorts of
"brain twists" as much as possible.
Taking python/javascript as example. To get the last item in an array,
you do 'arr[-1]' in python. It is straight forward and, as the "-" indicates
a "count from reversed direction", it feels natural. But in javascript,
you have to use other approaches, like 'arr[arr.length-1]', or
'arr.slice(-1)[0]'.
Yes, it's "just a little bit verbose", but it is an unnecessary "brain
twist"
that can be avoided.
Besides, if a language is designed with this "just a little bit verbose"
mentality,
then all the little bits finally adds up and results in a verbosity that's
never be
"just a little".
Python is designed with less brain twist that's why it's considered more
natural
and one of the easiest to learn for beginners.
have
language to learn.
bigger
The above statements you made here applies to ANY new feature, thus are
not valid arguments when discussing a specific feature.
View this message in context: http://forum.openscad.org/Convert-from-object-to-polygon-polyhedron-tp18522p18773.html
2;",
This is what I call *brain twists*, an unnecessary detour or distraction
"*brain twists*" as much as possible.
'arr.slice(-1)[0]'.
twist"
mentality,
never be
"just a little".
natural
> have
> language to learn.
> bigger
Wed, Oct 19, 2016 1:03 PM
operators.
Most importantly, I WOULD confuse => and >= . (i.e. I might write =>
where >= was intended, less likely the other way around).
> operators.
*-- BitWizard writes Linux device drivers for any device you may have! --*
LV
Lucas Vinicius Hartmann
Wed, Oct 19, 2016 1:44 PM
The → symbol is what's used in mathematics to describe functions, eg f :
x → x².
I am not really sure, but If I remember correctly the usage of the arrow in
math is not exactly that. It describes a property of the function, not the
function itself.
The arrow is used pointing to a SET that contains all possible answers for
the function, but does not specify what is the answer for a partigular
input. Basically it is equivalent to the return type of a function
prototype in C/C++.
If, for instance, we have a cubic function given by
f(x) = xxx
Then f(x) may return any real number, so the result set is all real
numbers.
f(x) -> R (Imagine the stylish R for real numbers here)
If f2(x) was a square function, then only positive real numbers could be
returned, so...
f2(x) -> R+
That said, the usage of arrows in openscad or programming languages is up
to the developers. :-)
2016-10-18 17:51 GMT-03:00 doug moen <doug@moens.org>:
> x → x².
function itself.
prototype in C/C++.
f(x) = x*x*x
numbers.
returned, so...
f2(x) -> R+
Thu, Oct 20, 2016 4:08 PM
x → x².
in math is not exactly that. It describes a property of the function, not
the function itself.
prototype in C/C++.
f(x) = xxx
numbers.
returned, so...
f2(x) -> R+
In my high school algebra text book, the → is used exactly as I have
described. Here's a quote from an exercise:
In f : x → x², x ∈ R, what is the image of 2?
Citation:
http://www.mathhelp.com/how_to/functions/function_and_arrow_notation/
The → is *also* used when describing the domain and range of a function, eg
f : R→R.
Citation: http://mathworld.wolfram.com/Function.html
So I think → notation for functions is common and well understood in high
school classrooms.
On 19 October 2016 at 09:44, Lucas Vinicius Hartmann <
>> x → x².
> prototype in C/C++.
> f(x) = x*x*x
> numbers.
> returned, so...
> f2(x) -> R+
O
otto
Fri, Oct 21, 2016 1:21 AM
There are several symbols commonly used to express a mapping, see:
http://mathinsight.org/function_notation
and
The simple arrow is a statement about a range and a domain, it does
not define the function. It looks something like this --> In TeX
(or LaTeX) use the symbol \rightarrow.
In order to define a function sometimes the arrow symbol has a vertical
mark at the beginning, something like this |--> In TeX use the symbol
\mapsto.
The \rightarrow alone should not be used to define a function in a math
textbook, even at high school level, since it is not common usage. If
one wants to define a function using an arrow, the \mapsto is the
correct symbol. A much more common way to define a function is the
f(x)=x*x type usage both in languages and math books.
The statement:
answers for the function, but does not specify what is the answer
for a partigular input.
is correct.
We are not writing mathematics with openscad. We are programming, and
any new syntax should follow rules established in older programming
languages and that are in common usage in order to make our new language
more learnable and easier to maintain. From my point of view defining a
function is best done with a syntax ... f(x)=x*x .... type
expression.
Python:
def f(x):
return x*x
C/C++:
<return type> f(x){ return x*x; }
scheme:
(define f (lambda (x) (* x x)))
ruby:
def f(x)
return x*x
end
My takeaway from this is that most programmers and users just
learning this language, will expect a function definition, even in a new
language, to contain a part naming the function followed by
parenthesis, followed by an argument list. This
is true of all of the languages mentioned, so unless there is some
really compelling reason to use a different form of syntax, that is
that provides a dramatic increase in either the power of the language or
its ease of use, I think we should stick to the current
notation. All of the above are easy and similar to openscads current
technique:
openscad:
function f(x)=x*x;
If openscad is a first programming language, as it will be for
some, learning a traditional style syntax will allow skills to be more
easily applied in future systems. I particularly dislike the arrow
syntax because of its easy confusion with the C dereferencing operator
Doug Moens proposal at:
https://github.com/doug-moen/openscad2
Contains a number of excellent ideas and represents the only document
that I could find at this point that presents a clear vision of one
direction in which OpenScad can grow.
In particular I agree with the following:
OpenSCAD2 is a backwards compatible redesign of OpenSCAD. The main
goals are expressive power and ease of use.
Everything is a first class value (including functions, modules,
shapes, and objects).
I have some reservations about the following:
- Single unified namespace (instead of separate namespaces for
variables, functions and modules).
---This would break some older
programs. I think that we can begin to unify the name spaces and
simply depreciate the older syntax. Doug proposes anonymous functions
be written function(<arglist>) expr
Given a function call such as x(z), we could check the old name space
for a function with the name "z"; if it is found we execute the
function "z". If it is not found we check the variable namespace for
a variable with the name "z", if it is not found, it is an error. If
it is found we check the contents of the "z" variable in the function
namespace. The values assigned to anonymous functions cannot be
created with the old function type definition in our new system. This
is how the system using the "@" syntax I wrote works. The issue is that
a new, anonymous function that has been assigned a new name that
conflicts with an old name will never be executed. That is one reason
why I prefer to explicitly dereference variables in function calls. I
guess we could allow both explicit and implicit dereferencing and
attempt to depreciate the old function definition technique, but I am
afraid that that would lead to confusion and difficulty finding errors
in new code. Old code would work as expected.
Simple, consistent scoping rules eliminate a source of confusion.
---Agree
OpenSCAD reports errors in more situations where something goes
wrong. This makes bugs easier to diagnose.
---Agree Openscad should also issue more warnings. "x=3; ... x=4;"
should generate a warning. Would break
anything already out there if we made the construct illegal?
Backwards compatibility mode for old scripts that rely on 3
namespaces and old scoping rules.
---Old rules should be the default mode. Any other modes need massive
justification in my opinion.
New syntax for function & module definitions, use and include,
required to support new semantics while preserving backwards
compatibility.
---Old syntax must continue to work.
Objects result from treating scripts as first class values, and add a
lot of new expressive power.
---Openscad should be extended to support objects explicitly and allow
them to be passed back and forth in the main name space. We do not
have to abandon the multiple name spaces in order to achieve this.
I see a major need for the following:
The adoption and implementation of anonymous function syntax. The
major issue here is adoption and syntax. We know this can be
implemented in hours, not days.
Making an anonymous module in which we can explicitly assign the
module to a variable and dereference the module when we wish to have it
rendered. (working on it when I have time).
The ability to render a module to a polygon/polyhedron set
consisting of its points and faces as is used in the call to
polyhedron. The rendering would not be part of the top level geometry
but would simply return the list of points and faces.
I see a minor need for the following:
Native affine functions: I use a list of a (3X3) matrix and a 3
vector to represent an affine transform. In CGAL they provide some
nice affine functions and routines. I have implemented the inverse
affine and some others in my affine.scad library, but making these a
native type would allow the use of the * binary operator to combine
transforms and transform vectors and would make the operations faster.
Extension of the hull function to accept a set of points instead of
requiring objects containing both points and faces.
(working on it when I have time.)
A long term goal:
A better integration between opescad and cgal that would allow for
some of the more exotic cgal libraries to be compiled from CGAL and
imported into openscad. How to implement this is not clear. A general
technique of including or using compiled code with new functionality
would be great. One of the great things about python is that this is
an implemented feature.
All of the above should be achievable.
Regards
Otto
On Thu, 20 Oct 2016 12:08:53 -0400
eg f : x → x².
arrow in math is not exactly that. It describes a property of the
function, not the function itself.
for a partigular input. Basically it is equivalent to the return
type of a function prototype in C/C++.
f(x) = xxx
numbers.
could be returned, so...
f2(x) -> R+
is up to the developers. :-)
and
\mapsto.
The statement:
is correct.
expression.
Python:
def f(x):
return x*x
C/C++:
scheme:
ruby:
def f(x)
return x*x
end
technique:
openscad:
function f(x)=x*x;
1. OpenSCAD2 is a backwards compatible redesign of OpenSCAD. The main
2. Everything is a first class value (including functions, modules,
3. Single unified namespace (instead of separate namespaces for
4. Simple, consistent scoping rules eliminate a source of confusion.
---Agree
5. OpenSCAD reports errors in more situations where something goes
6. Backwards compatibility mode for old scripts that rely on 3
7. New syntax for function & module definitions, use and include,
compatibility.
1. The adoption and implementation of anonymous function syntax. The
2. Making an anonymous module in which we can explicitly assign the
3. The ability to render a module to a polygon/polyhedron set
1. Native affine functions: I use a list of a (3X3) matrix and a 3
2. Extension of the hull function to accept a set of points instead of
A long term goal:
Regards
Otto
> Citation:
> function, eg f : R→R.
> high school classrooms.
> >> eg f : x → x².
> > f(x) = x*x*x
> > numbers.
> > f2(x) -> R+
