[OpenSCAD] Re: SolidWorks & OpenSCAD interoperability
The FreeCAD OpenSCAD workbench and the Alternate importer
https://github.com/KeithSloan/OpenSCAD_Alt_Import
Work by either importing a CSG file or creating a CSG from a SCAD file
under the covers, for the later the workbench needs to be
told where to find the OpenSCAD executable.
As the CSG file is a minimum scripting language to create CSG objects
the FreeCAD import parses the file with a python
library for Lex/Yacc, FreeCAD objects are then created for the language
statements, so for Cube a FreeCAD box is create etc.
i.e. Brep representation.
You can then export as STEP which can then be imported into SolidWorks,
use FreeCAD Path Workbench etc.
The two OpenSCAD statements that cannot be handled directly in this
manner are Hull and Minkowski as there
is no direct Brep equivalent. When the parser finds such statements on
the stack it converts the relevant objects on the stack
to a Mesh form and calls the OpenSCAD executable to perform the Hull or
Minkowski request and output a Mesh/STL file
that the importer then deals with as a Mesh. So if you are wanting to
design models in OpenSCAD for use in Solidworks
try and avoid Hull and Minkowski.
The Alternate importer tries to handle certain Hull and Minkowski
requests, so two parallel cylinders. Minkowski requests
where one object is a sphere as used to create a fillet but otherwise
drops back to handling them the same way as the
standard importer.
I have suggested that more could be done if the OpenSCAD language could
be expanded to add user information to a CSG file.
i.e. So that an OpenSCAD macro/library could add extra info to the CSG
file that the importer could deal with but Paul Torsen
did not warm to the idea. For example if such an enhancement was
implemented by OpenSCAD a library that implemented
a thread in OpenSCAD could also output to the CSG file, info about the
thread before executing its OpenSCAD statements
and again after, to indicate it had ended. The FreeCAD importer could
detect the request to create a thread, use the FreeCAD
thread making facility and ignore any subseqent CSG statement till it
got to the one indicating the end of thread request,
It is also possible to load and edit OpenSCAD scripts directly in the
FreeCAD workbench (probably only workable with
smallish scripts). A Google GSOC project was suggested to improve it see
https://github.com/opencax/GSoC/issues/62
but nobody took up the idea.
========== Art & Ceramics ===========
https://www.instagram.com/ksloan1952/
Bingo.
I used the OpenSCAD Workbench in FreeCAD, loaded my SCAD file, and generated a STEP file. The guys at job shop loved it, and now they think I'm a wizard. They can do everything as usual within SolidWorks.
There are two problems that I will encounter, as you alluded to.
First problem is with threads. I generate my own polyhedron().
Second problem is bevel gear teeth. I also generate by own polyhedron().
To get around this, they have requested that for the thread I include the major diameter for screws, and minor diameter for threaded hole. They then "cut it" using their tool.
For teeth, they requested that I include the shape that is pre-tooth-cuts. This also makes sense. So for example my bevel gears have spherical-shaped stumps, so I need to just give them the spherical shell before the teeth are cut. Maybe I can add some markings or indents that show more clearly where the teeth start.
Results of using FreeCAD in combination with OpenSCAD look very promising. I won't abandon OpenSCAD. Absolutely wonderful tool it is.
------- Original Message -------
On Wednesday, November 16th, 2022 at 2:56 AM, Keith Sloan keith@sloan-home.co.uk wrote:
standard importer.
Thanks for your work.
I tried this simple file with 1 polyhedron.
It seems to take a longtime and not loading element.
Can you suggest how to convert this
standard importer.
