cura screw up?
Gene Heskett
Sat, Jun 19, 2021 8:01 PM
On Saturday 19 June 2021 13:37:02 lar3ry wrote:
Gene Heskett wrote
See my other post, Terrypin. I think its fixed, the problem never
was visible even in curas previews, only showing up on the build
plate. It was a combo of the wrong driver, and an stl that was
vertically centered with 6mm below the plate and 6mm above.
Check to see if Cura has a "Lie flat" button. Slic3r and Prusa Slicer
both have it. That way, it doesn't matter where the stl thinks it is
vertically, or even it it's tilted. It will plop it down to Z=0, and
show you what corrections it made when you look at the 'Rotate"
setting.
Cura has all that. And the next print that was in progress, cleaned up of
all the stringing, about .1mm too big. Pretty good for a SWAG.  Making
the next one with 30% more infill in gyroid pattern, .1mm smaller, which
will also improve the wall strength a teeny amount.  Then it might be
time to rig it on the motor, add some plastic lube on the bb's and drive
it for a day to see what if anything breaks.  Added a mm to the
retraction got rid of most of the stringing. At 2mm high its a whole lot
cleaner a print. If it doesn't plug up. It is still using retractions by
the thousands.  And I still don't have a side fan, its hot enough to
burn a finger but not running. I've sent a msg to the vendor but no
reply as yet. PETG doesn't want it, but this is the starter PLA.
Thanks lar3ry.
Cheers, Gene Heskett
-Ed Howdershelt (Author)
On Saturday 19 June 2021 13:37:02 lar3ry wrote: > Gene Heskett wrote > > > See my other post, Terrypin. I think its fixed, the problem never > > was visible even in curas previews, only showing up on the build > > plate. It was a combo of the wrong driver, and an stl that was > > vertically centered with 6mm below the plate and 6mm above. > > Check to see if Cura has a "Lie flat" button. Slic3r and Prusa Slicer > both have it. That way, it doesn't matter where the stl thinks it is > vertically, or even it it's tilted. It will plop it down to Z=0, and > show you what corrections it made when you look at the 'Rotate" > setting. > Cura has all that. And the next print that was in progress, cleaned up of all the stringing, about .1mm too big. Pretty good for a SWAG. Making the next one with 30% more infill in gyroid pattern, .1mm smaller, which will also improve the wall strength a teeny amount. Then it might be time to rig it on the motor, add some plastic lube on the bb's and drive it for a day to see what if anything breaks. Added a mm to the retraction got rid of most of the stringing. At 2mm high its a whole lot cleaner a print. If it doesn't plug up. It is still using retractions by the thousands. And I still don't have a side fan, its hot enough to burn a finger but not running. I've sent a msg to the vendor but no reply as yet. PETG doesn't want it, but this is the starter PLA. Thanks lar3ry. Cheers, Gene Heskett -- "There are four boxes to be used in defense of liberty: soap, ballot, jury, and ammo. Please use in that order." -Ed Howdershelt (Author) If we desire respect for the law, we must first make the law respectable. - Louis D. Brandeis Genes Web page <http://geneslinuxbox.net:6309/gene>
Terrypin
Sat, Jun 19, 2021 9:08 PM
Thanks, that’s one possible cause I’d never have dreamt of! Plausible
reasoning though.
However, that image was received by several here. Highlighting difficulty of
gathering practical evidence. Bit like “Can you hear me at the back of the
class?”
Thanks, that’s one possible cause I’d never have dreamt of! Plausible reasoning though. However, that image was received by several here. Highlighting difficulty of gathering practical evidence. Bit like “Can you hear me at the back of the class?” -- Sent from: http://forum.openscad.org/
Gene Heskett
Sat, Jun 19, 2021 10:03 PM
reasoning though.
Well, as an old (86) Iowa born farm kid, we'd call that question about as
useless as the teats on a boar hog. :)  You will either get a yes
because they did hear you, or silence because they didn't.
On Saturday 19 June 2021 17:08:04 Terrypin wrote: > Thanks, that’s one possible cause I’d never have dreamt of! Plausible > reasoning though. > > However, that image was received by several here. Highlighting > difficulty of gathering practical evidence. Bit like “Can you hear me > at the back of the class?” Well, as an old (86) Iowa born farm kid, we'd call that question about as useless as the teats on a boar hog. :) You will either get a yes because they did hear you, or silence because they didn't. > > -- > Sent from: http://forum.openscad.org/ Cheers, Gene Heskett -- "There are four boxes to be used in defense of liberty: soap, ballot, jury, and ammo. Please use in that order." -Ed Howdershelt (Author) If we desire respect for the law, we must first make the law respectable. - Louis D. Brandeis Genes Web page <http://geneslinuxbox.net:6309/gene>
