Hi all,
what’s wrong with my simple code?
Preview is generated successfully, but rendering fails with message:
ERROR: The given mesh is not closed! Unable to convert to CGAL_Nef_Polyhedron.
My code:
module ring(d,b,r)
intersection()
union(){
rotate_extrude(convexity = 10,$fn = 100)
translate([d/2, 0, 0])
circle(r = r,$fn=100);
cylinder(d=d+r*2, h=b, center=true,$fn = 100);
ring(60,40,30);
I am using current version: OpenSCAD Version: 2021.01 (under Windows)
Many thanks, Richard
p.s. Preview screenshot:
translate([60/2, 0, 0]) circle(r = 30,$fn=100);
results in an object starting at 0. you cannot rotate_extrude that.
