I am getting this error from a fairly simple polyhedron when CGAL operates
on it. It looks fine in the thrown together view and I think the code used
to work in older versions of OpenSCAD. I don't remember seeing this error
before but I could be wrong about that.
violation! Expr: ss_circle.has_on(sp) File:
/opt/mxe/usr/x86_64-w64-mingw32.static.posix/include/CGAL/Nef_3/polygon_mesh_to_nef_3.h
Line: 263
If I export it as an STL before involving CGAL and import it I can use it
with CGAL. So whatever the problem is STL export cleans it up.
polyhedron(points =
[[0, 10, 0], [10, 0, 0], [0, -10, 0], [-10, 0, 0], [0, 10, 100],
[9.80581, 0, 98.0388], [0, -10, 100], [-9.80581, 0, 101.961], [30, 10,
150], [38.5749, 0, 144.855], [30, -10, 150], [21.4251, 0, 155.145]],
faces = [[3, 2, 1, 0], [0, 1, 5, 4], [4, 5, 9, 8], [1, 2, 6, 5], [5, 6,
10, 9], [2, 3, 7, 6], [6, 7, 11, 10], [3, 0, 4, 7], [7, 4, 8, 11], [8, 9,
10, 11]]);
Perhaps it doesn't like quads because they will be triangles when read from
STL.
On 2017.1.20 it renders without any probs
Will it union with a unit cube though?
sorry forgot to tell this. Yes!
Thanks. So looks like a regression then as I am on Windows snapshot version
2017.11.12 (git 7cb1e93).
Seems to be this as my library info shows CGAL 4.10:
https://github.com/openscad/openscad/issues/2139
version 2017.11.12 (git 7cb1e93).
On Dec 3, 2017, at 7:09 AM, nop head nop.head@gmail.com wrote:
Seems to be this as my library info shows CGAL 4.10: https://github.com/openscad/openscad/issues/2139
That sounds likely; CGAL used to have a precondition check for planar faces, but they removed this in CGAL-4.10, causing the polyhedron builder to fail later in the process if given slightly non-planar polygons (note: I guess most polygons are technically non-planar when specified using floating point numbers).
Since we don’t know exactly what CGAL accepts, we catch the exceptions thrown from CGAL and rebuild the polyhedron using triangles if it fails.
..but we don’t yet know exactly what exceptions are caused by non-planar input..
I converted my quads to triangles and forced my end caps to be exactly
planer polygons and it works. So the latest Windows snapshot was released
with this regression.The test suite appears to catch it so it appears not
to have been tested.
input..
On Dec 3, 2017, at 1:31 PM, nop head nop.head@gmail.com wrote:
I converted my quads to triangles and forced my end caps to be exactly planer polygons and it works. So the latest Windows snapshot was released with this regression.The test suite appears to catch it so it appears not to have been tested.
We don’t test productions builds, and we don’t currently run tests on Windows, so anything triggered by 3rd party libraries rely on Travis CI being run against those libraries.
Can you reproduce this using the test suite locally?
I can try when I get home. I am in Tenerife at the moment. I don't have the
dev setup on this laptop. It uses a hell of lot of disk space.
