When I run this I just see a solid 6x6x6 inch cube. Why is it not hollowed
out?
I'm on Ubuntu 14.04 and version 2014.01.29 (from the ppa).
itomm = 25.4; // conversion factor from inches to mm
length = 6 * itomm; // x
width = 6 * itomm; // y
height = 6 * itomm; // z
thickness = .35 * itomm; // thickness of the walls
module hollow_box(xlen, ylen, zlen, thikness) {
cube([xlen, ylen, zlen]);
translate([thikness, thikness, thikness]) {
cube(xlen-2thikness, ylen-2thikness, zlen+100);
hollow_box(length, width, height, thickness); // x, y, z
View this message in context: http://forum.openscad.org/Can-t-get-difference-to-work-tp17218.html
You forgot the brackets [] in the second cube statement
lmcc
Sent: Thursday, April 28, 2016 8:49 PM
Subject: [OpenSCAD] Can't get difference() to work
hollowed out?
Thank you. It works now.
View this message in context: http://forum.openscad.org/Can-t-get-difference-to-work-tp17218p17220.html
