Top view after render
http://forum.openscad.org/file/n15824/2D_-Z_top.jpg
Side view - note negative Z
http://forum.openscad.org/file/n15824/2D_-Z_Right.jpg
Angled views, make it look like it is not aligned to the axis
http://forum.openscad.org/file/n15824/2D_-Z_angle_same.jpg
http://forum.openscad.org/file/n15824/2D_-Z_angle_opposite.jpg
Is this fixable?
View this message in context: http://forum.openscad.org/2D-view-negative-Z-tp15824.html
I just translated it to look OK... for the wiki
http://forum.openscad.org/file/n15825/Rotate_extrude_wiki_2D_B.jpg
View this message in context: http://forum.openscad.org/2D-view-negative-Z-tp15824p15825.html
Is this fixable?
This seems paradoxical, or perhaps not? The problem relates to the value
of the non-existent z coordinate in a 2d [x,y] coordinate system?
I think 2d coordinates on OpenSCAD are slightly (just slightly)
scizophrenic. 2d shapes are sometimes drawn/interpreted/used for a value
of z != 0, showing that it really has a z value as in your example.
When you rotate a 2d shape around for example the y-axis to give the
coordinates z != 0, strange things start to happen. First, it makes a
lot of sense:
rotate([0,-45]) translate([15,0])circle(5);
http://arnholm.org/tmp/openscad/circle2d_rotated.png
Now you have a 2d circle placed in 3d space where the points on the
circumference of the circle have different z-coordinates in the global
system. It is also drawn correctly with a small unit thickness in the
direction perpendicular to the transformed local 2d coordinate system.
It is the local coordinate system of the circle that is 2d, not its
placement or orientation in 3d space. The display this in OpenSCAD
appears to support this understanding.
But try this "extrude1":
module extrude1()
color("green")
linear_extrude(height=10)
rotate([0,-45])
extrude1();
For some reason, the (unstated) projection of the rotated circle down to
the global coordinate system x-y plane is now taken as the starting
point of an extrusion in global z direction. This is where the thing is
(slightly) scizophrenic, the circle has and it hasn't values for its
z-coordinates, and the direction of its thickness/direction of extrusion
has changed.
One could perhaps argue that a more consistent behaviour would be for
the above to cause the same result as this "extrude2":
module circle3d(r=1,dx=1,ry=1)
rotate([0,ry]) translate([15,0])
linear_extrude(height=0.001) circle(r);
module extrude2()
color("red")
hull(){
circle3d(r=5,dx=15,ry=-45);
translate([0,0,10])
extrude2();
That is, it is more consistent if you insist that linear_extrude
operates only in z of the global 3d coordinate system. However, it is
equally logical to expect that linear_extrude extrudes in the
perpendicular direction of its 2d input, just like the original unit
thickness drawing was hinting. After all the purpose in life of
linear_extrude is to convert from 2d shapes to 3d solids. Therefore,
accepting that transformed 2d shapes can exist in 3d space with
coordinates z!=0, you might as well have expected the first extrusion to
give a result equivalent to this:
module extrude3()
color("blue") rotate([0,-45])
translate([15,0]) circle(r=5);
extrude3();
http://arnholm.org/tmp/openscad/extrusion_confusion.png
If you understand these inconsistencies, it is manageable. However, the
behaviour of extrude1() is really unreasonable in my mind. I think it
would have been more consistent and logical if extrude1() gave the same
result as extrude3(), i.e. the extrusion was in the direction of the
original drawn unit thickness of the transformed 2d circle, starting
from the placement of the circle in 3d space.
If you understand these inconsistencies it isn't a big problem, but I
can imagine new users being very much confused by them.
square(); produces a square below the XY plane with F6, so I think there is
a bug drawing 2D objects on top of all the schizophrenia.
Is this fixable?
scizophrenic. 2d shapes are sometimes drawn/interpreted/used for a value of
coordinates z != 0, strange things start to happen. First, it makes a lot
of sense:
direction perpendicular to the transformed local 2d coordinate system. It
is the local coordinate system of the circle that is 2d, not its placement
or orientation in 3d space. The display this in OpenSCAD appears to support
this understanding.
module extrude1()
color("green")
rotate([0,-45])
extrude1();
the global coordinate system x-y plane is now taken as the starting point
has changed.
One could perhaps argue that a more consistent behaviour would be for the
module extrude2()
color("red")
hull(){
translate([0,0,10])
extrude2();
That is, it is more consistent if you insist that linear_extrude operates
only in z of the global 3d coordinate system. However, it is equally
logical to expect that linear_extrude extrudes in the perpendicular
direction of its 2d input, just like the original unit thickness drawing
was hinting. After all the purpose in life of linear_extrude is to convert
from 2d shapes to 3d solids. Therefore, accepting that transformed 2d
shapes can exist in 3d space with coordinates z!=0, you might as well have
expected the first extrusion to give a result equivalent to this:
module extrude3()
extrude3();
original drawn unit thickness of the transformed 2d circle, starting from
If you understand these inconsistencies it isn't a big problem, but I can
there is a bug drawing 2D objects on top of all the schizophrenia.
Yes, that one:
https://github.com/openscad/openscad/issues/1202
Yes, that one:
Right, let’s just change it :)
