It's aliiiiive!
First attempt at search simplification (passes regressions) is here:
https://github.com/openscad/openscad/pull/1318
See the "Files Changed" report for how I've simplified the usage:
https://github.com/openscad/openscad/pull/1318/files
I updated the example023.scad to wrap the built-in search() in a
user-defined search_vector_one() function to take advantage of simple
[for(i=...)] list building:
function search_vector_one(vec,table,col=0) = [for(i=[0:len(vec)-1])
search(vec[i],table,col)[0]];
https://github.com/clothbot/openscad/blob/search_simplify/examples/Old/example023.scad
I used the same search_vector_one() function in text-search-test.scad to
make it "just work":
The two "search-tests-unicode.scad" and "search-tests.scad" have been
significantly modified to reflect the simplified search behaviour.
https://github.com/clothbot/openscad/blob/search_simplify/testdata/scad/misc/search-tests.scad
As outlined in the comment here:
https://github.com/clothbot/openscad/blob/search_simplify/src/func.cc#L667
--snip--
Pattern:
"search" "(" match_value "," string_or_vector_or_table
("," index_col_num )?
match_value : ( Value::NUMBER | Value::STRING );
string_or_vector_or_table : ( Value::STRING | "[" Value ("," Value)* "]" |
"[" ("[" Value ("," Value)* "]")+ "]" );
index_col_num : int;
--end-snip--
A string 'match_value' searches for full-string matches.
All matches are returned every time
the no-matches condition returns 'undef' instead of an empty vector '[]'
Assigning any vector to 'match_value' throws a WARNING and return 'undef'
Thoughts? Comments?
Speak now or fix it yourself.?. ;-)
Andrew.
View this message in context: http://forum.openscad.org/Digging-into-search-tp12421p12442.html
Wow, Andrew, that was quick !!
Without going over the links in details, here is my quick view:
It looks great. The removal of iteration over match_value and the
num_returns_per_match is very significant.
One note:
match_value doesn't have to exclude lists. You just treat it as a value and
don't iterate over it. This way, it can be used to search points like you
wish.
In fact, since it is "a value", there's no need to enforce any type
constraint on match_value. It could be anything even boolean or even undef.
Thus, there is no need for the warning sign. It wouldn't be too hard to
check why a search doesn't return indices as expected.
Certainly, if match_value=vector is allowed, we have to think about how to
deal with this:
search( ["abc",1], [ ["abc",1], [ ["abc",1],2 ], ["ghi",3] ...] )
Will it give [0] ? [1]? [0,1] ?
This can be controlled by index_col_num, for example,
index_col_num = 0 ==> [1] (match the column #0 )
index_col_num = -1 ==> [0] (means, no selection of column, so match the
whole item, in this case, ["abc",1], and return [0] )
Lastly, a side note:
Since search( ) now seems to allow flat list (which I believe was not
original design for), what it does is returning index:
search( "def", ["abc",1,"def",2,"ghi",3] )
and a step-short to serve the purpose of hash-like feature, because this
will fail :
search( "def", ["abc","def","def",2,"ghi",3] )
It returns 1, the index of value of key "abc", but not 2, the index of key
"def".
Unless a new argument, every, is introduced. every=1 (default), every=2:
allows for key search in a list of key-value pairs. Its addition depends on
how you feel how important this "key-value pairs" is and if this search()
wants to play that role.
BTW: I have a whole set of test cases for search(). Once it is merged into
the nightly, I can try them out.
'undef'
Thoughts? Comments?
Andrew.
$ Runsun Pan, PhD
$ -- OpenScad_DocTest: doc and unit test ( Github , Thingiverse )
View this message in context: http://forum.openscad.org/Digging-into-search-tp12421p12443.html
Hi Rusun,
Very briefly, vector and string 'index' counting starts at 0, not 1.
list1= ["abc",1,"def",2,"ghi",3]
search( "def", list1 )
...will return '[2]' because list1[2]=="def"; list1[0]=="abc"
list2=["abc","def","def",2,"ghi",3]
search( "def", list2 )
...will now return '[1,2]' because list2[1]=="def" and list2[2]=="def";
list2[0]=="abc"
In my simplified search, all matches are always returned. It is now up to
the user to decide how many/few to filter off and by what
mechanism/algorithm.
I think that yes, I'll eventually add list/vector support to match_value,
however it will be considerably more involved to implement than the simple
'atomic' data structures.
Support search for an N-dimension vector match could be fun+useful:
Picking my battles. :-)
Andrew.
View this message in context: http://forum.openscad.org/Digging-into-search-tp12421p12444.html
Ok. I think I've bugged you enough. Whatever you decide, I think it's in a
good direction :) :)
$ Runsun Pan, PhD
View this message in context: http://forum.openscad.org/Digging-into-search-tp12421p12445.html
I think you missed the point @runsun.
"Very briefly, vector and string 'index' counting starts at 0, not 1. "
This explains why you had so much difficulty understanding it.
search("a",[ "d", "c", "b", "a"); // returns [3]
0 1 2 3
__
View this message in context: http://forum.openscad.org/Digging-into-search-tp12421p12451.html
@ Michael, I didn't explain too much in details about the context, I guess
that's why you (and Andrew) misunderstood.
The reason that I have this argument,
search( "def", [ "abc","def","def",1 ] )
will cause confusion is that, the whole discussion stems from a discussion
on other thread about hash parameter mapping. This includes the example you
gave using lookup.
Then search() was mentioned. Search() was not designed for this type of
key-value mapping, but I tried to use it that way, by applying search() on a
flat list as above. Note that all examples on the doc about search() are
either against strings :
search( ... "abcdef")
or against list of vectors:
search( ... [["abc",1],["def",2] ...])
but not flat list.
So if search() is to be use as a key-value type mapping against a flat list
like I like it to be, it has to be able to find every other item to map,
that is,
search( "def", ["abc", "def", "def", 1] )
def has to map item 0, that is "abc", and skip item 1 (which is a value
associates to item 0), then item 2, that is "def".
In this case, it should have returned [2]. Or, if return all, [1,2].
But, like I said, search() can't do that, and when set to return only one
item, it will return [1], but not [2], which is not what I want. So using
search() in a key-value mapping manner will fail.
This can be solved if search() can match every other item (see my previous
post).
But I understand that this is probably just my way of using it, so I leave
the decision to Andrew. It would probably make it too complicated, anyway.
So this is not the problem of mistaking the base indexing. Guess I was just
too lazy to explain the entire context. :( :(
0 1 2 3
__
$ Runsun Pan, PhD
View this message in context: http://forum.openscad.org/Digging-into-search-tp12421p12452.html
