JS
Jon S
Wed, Oct 14, 2026 2:02 AM
Hi all,
Is there a page where “problems occur in Windows with OpenSCAD” are listed? The current difficulty is importing .scad modules and the direction of the slash marks. Please point me to where I might get answers.
Thanks, JonS
Hi all,
Thanks, JonS
WF
William F. Adams
Wed, Oct 14, 2026 2:16 AM
On Tuesday, October 13, 2026 at 10:02:16 PM EDT, OpenSCAD general discussion Mailing-list discuss@lists.openscad.org wrote:
I would be very surprised if these were actual problems with the application (there are a lot of Windows users).
More likely, it's a problem with your code --- could you share that here?
Also, it may help to review the documentation:
https://en.wikibooks.org/wiki/OpenSCAD_Tutorial
-- Sphinx of black quartz, judge my vow.https://designinto3d.com/
On Tuesday, October 13, 2026 at 10:02:16 PM EDT, OpenSCAD general discussion Mailing-list <discuss@lists.openscad.org> wrote:
Wed, Oct 14, 2026 2:32 AM
answers.
You say "importing" .scad modules, but... OpenSCAD has no import
operation that is applicable to .scad files.
For the language constructs, it has "include" and "use".
For all purposes (as far as we know), OpenSCAD accepts either forward
slashes (/) or backslashes ().
However, note that if you are using the file path in an OpenSCAD string
- as, for instance, in an import() operation - like many languages,
backslashes are magic and if you want to use a backslash you must double it.
For instance: import("myfolder\mydrawing.svg");
That requirement does not apply to "include" or "use", because their
arguments are not OpenSCAD strings.
> answers.
slashes (/) or backslashes (\).
For instance: import("myfolder\\mydrawing.svg");
That requirement does *not* apply to "include" or "use", because their
Wed, Oct 14, 2026 2:49 AM
string - as, for instance, in an import() operation - like many
languages, backslashes are magic and if you want to use a backslash
you must double it.
As a result, it's usually simpler to use forward slashes on all
platforms, including Windows. As a side benefit, if the paths are
relative it makes the OpenSCAD program be portable between platforms.
> you must double it.
RV
Roel Vanhout
Wed, Oct 14, 2026 6:03 AM
I don't know what symptoms you're seeing, but I ran into an issue a
few weeks ago where mixing forward and backward slashes caused a crash
of OpenSCAD. But, this could not be reliably reproduced in isolation,
even though it happened enough in my automatic testing that it became
very annoying. In the end, the crash could be reliably triggered using
a network or UNC path. The issue is a regression stemming from
switching from Boost's filesystem implementation to std::filesystem;
MingW/gcc didn't have proper support for UNC paths (still doesn't
afaict). I submitted a patch 2nd of September (
https://github.com/openscad/openscad/pull/7004 ). I still don't know
why the mixing of forward and backward slashes would sometimes trigger
this same issue, but I do know that I haven't seen a crash since.
cheers
Roel
On Wed, Oct 14, 2026 at 4:02 AM Jon S via Discuss
Hi all,
Thanks, JonS
cheers
Roel
> Hi all,
> Thanks, JonS
Wed, Oct 14, 2026 3:20 PM
When you say "a crash", do you mean an erroneous error - that is, an
error that should not have occurred - or do you mean that the operating
system terminated the application - what UNIX would call a core dump?
RV
Roel Vanhout
Wed, Oct 14, 2026 4:37 PM
When you say "a crash", do you mean an erroneous error - that is, an error
that should not have occurred - or do you mean that the operating system
Yes a true crash in the technical sense of the word. I mean, at least it
give me a dialog with some nondescript error message like 'illegal
exception' or 'unknown error' or something - I don't remember the text, but
it only had an 'ok' button and upon clicking that the program terminated.
On Wed, Oct 14, 2026, 17:20 Jordan Brown <openscad@jordan.maileater.net>
Wed, Oct 14, 2026 4:47 PM
an error that should not have occurred - or do you mean that the
operating system terminated the application - what UNIX would call
a core dump?
it give me a dialog with some nondescript error message like 'illegal
text, but it only had an 'ok' button and upon clicking that the
program terminated.
Huh. Thanks. I know that there are problems in the vicinity of UNC
paths (and, for that matter, paths that specify drive names), but I'm
surprised by an actual crash.
> a core dump?
> program terminated.
