Hi everyone,
I am using OpenSCAD to generate a 2-dimensional vector that I wish to
treat as a heightmap. If I had the data in a file, I could load it using
'surface' and to produce exactly what I want, because surface fills in
the areas between the height points to produce a continuous form.
How do I do the same thing directly from my vector?
I feel that there must be a way but today I am not seeing it, short of
processing the vector to construct a polyhedron ... surely there must be
an easier way?
Thanks,
Steve
On 2/14/2024 9:47 AM, Steve Lelievre via Discuss wrote:
Hi everyone,
using 'surface' and to produce exactly what I want, because surface
fills in the areas between the height points to produce a continuous
form.
be an easier way?
Right now, it's "process the vector to produce a polyhedron". I tried a
bit to extend surface() to process arrays, but ran into some
data-representation problems and haven't gotten back to it.
Here's a module I wrote a while back. Call it like
"sfc([[0,2,1],[2,1,0],[1,2,2]], [10,10,1]);"
The randomness toward the end is to break up visual patterns that form
if each cell is always triangulated in the same direction. The size
parameter controls the X and Y size, and the Z size of the "base".
module sfc(a, sz) {
function dataIndex(x, y) = dataBase + x*ny + y;
nx = len(a);
ny = len(a[0]);
corners = 0;
dataBase = corners + 4;
pts = [
[0, 0, -sz.z],
[nx-1, 0, -sz.z],
[nx-1, ny-1, -sz.z],
[0, ny-1, -sz.z],
for (x = [0:nx-1])
for (y = [0:ny-1])
[ x, y, a[x][y] ]
faces = [
[ corners+0, corners+1, corners+2 ],
[ corners+0, corners+2, corners+3 ],
each for (x=[0:nx-1]) dataIndex(x,0),
corners+1,
corners+0,
each for (y=[0:ny-1]) dataIndex(nx-1,y),
corners+2,
corners+1,
each for (x=[nx-1:-1:0]) dataIndex(x,ny-1),
corners+3,
corners+2,
each for (y=[ny-1:-1:0]) dataIndex(0,y),
corners+0,
corners+3,
each for (x=[0:nx-2], y=[0:ny-2])
if (rands(0,1,1)[0]>0.5) [
[ dataIndex(x+1, y), dataIndex(x, y), dataIndex(x, y+1) ],
[ dataIndex(x+1, y+1), dataIndex(x+1, y), dataIndex(x, y+1) ],
] else [
[ dataIndex(x+1, y), dataIndex(x, y), dataIndex(x+1, y+1) ],
[ dataIndex(x+1, y+1), dataIndex(x, y), dataIndex(x, y+1) ],
scale([sz.x/(nx-1),sz.y/(ny-1),1])
polyhedron(pts, faces);
Thanks, that is useful.
Steve
a bit to extend surface() to process arrays, but ran into some
In BOSL2 I’d use the heightfield() module.
-Revar
On Feb 14, 2024, at 11:13 AM, Steve Lelievre via Discuss <discuss@lists.openscad.org> wrote:
Steve
Right now, it's "process the vector to produce a polyhedron". I tried a bit to extend surface() to process arrays, but ran into some data-representation problems and haven't gotten back to it.
