Hi all,
I need to calculate a summary from array elements.
In detail, the position of an object to print depends on the size of object
before.
I know already, I cannot calculate with simple variable, so I tried to use
array for result.
The problem is, I cannot reference the array x_pos[i-1], when calculating
x_pos[i]:
module gen_slots(dim)
n = len(dim);
x_pos = [for(i = [0 : n-1]) (i==0)? 0 : x_pos[i-1]+5+dim[i-1] ]; //
<---problem here
echo(x_pos);
for (i = [0 : n-1])
translate([ x_pos[i], 2, 0 ])
cube([dim[i],dim[i],2],center= false);
In C I would write:
void gen_slots(dim)
x_pos = 0;
for ( int i = 0; i < len(dim); ++i )
x_pos += 5+dim[i];
echo(x_pos);
How can I do this in OpenScad?
Maybe not the most optimized way, but a simple solution
is using a function to calculate the sum of the first
x entries of an array.
dim = [10, 8, 2, 25, 5];
function partial_sum(v, n, r = 0) = n <= 0
? r + v[0]
: partial_sum(v, n - 1, r + v[n]);
n = len(dim);
x_pos = [for(i = [0:n-1]) partial_sum(dim, i)];
echo(x_pos); // ECHO: [10, 18, 20, 45, 50]
Or use a library like https://github.com/thehans/funcutils
which provides lots of additional options based on the
new features. That will need a development snapshot version
though.
