Libraries and namespaces
IO
Ian Oliver
Sat, Jun 10, 2017 2:16 PM
I have (hopefully!) just got to the bottom of some odd errors that came
and went depending on exactly which parts of my model was building, and
also (oddly) whether building on Windows on Linux, though I do have
different versions of OpenSCAD on them.
It turns out that one of the Spline libraries I am using has its own
functions called transform and vec3, which clash with those in the
scad-utils transformations (etc.) libraries. Of course, their clash was
enough to trigger a warning about begin:end being the wrong way around
being deprecated but this warning doesn't have a line number just to
make life interesting.
Change the order of the use <> statements and this error would go away,
but other things relying on the "correct" version of transform would
blown up.
Is there any way to detect this and protect against it?
I have (hopefully!) just got to the bottom of some odd errors that came and went depending on exactly which parts of my model was building, and also (oddly) whether building on Windows on Linux, though I do have different versions of OpenSCAD on them. It turns out that one of the Spline libraries I am using has its own functions called transform and vec3, which clash with those in the scad-utils transformations (etc.) libraries. Of course, their clash was enough to trigger a warning about begin:end being the wrong way around being deprecated but this warning doesn't have a line number just to make life interesting. Change the order of the use <> statements and this error would go away, but other things relying on the "correct" version of transform would blown up. Is there any way to detect this and protect against it?
C
caterpillar
Sun, Jun 11, 2017 1:05 AM
When name collisions happen, one way I take to workaround the problem is
defining a module and include (or use) the .scad in it. For example:
module your_design() {
module one_part() {
include <a.scad>;
module the_other_part() {
    include <b.scad>;
one_part();
the_other_part();
The scope of xxx.scad will be constrained in the defined module. It's not a
perfect solution but works in some situations.
http://openhome.cc
View this message in context: http://forum.openscad.org/Libraries-and-namespaces-tp21672p21675.html
When name collisions happen, one way I take to workaround the problem is defining a module and include (or use) the .scad in it. For example: module your_design() { module one_part() { include <a.scad>; //.... } module the_other_part() { include <b.scad>; //.... } one_part(); the_other_part(); ... } The scope of xxx.scad will be constrained in the defined module. It's not a perfect solution but works in some situations. ----- http://openhome.cc -- View this message in context: http://forum.openscad.org/Libraries-and-namespaces-tp21672p21675.html Sent from the OpenSCAD mailing list archive at Nabble.com.
IO
Ian Oliver
Sun, Jun 11, 2017 3:07 AM
Thanks for the extra info on scoping (a complex topic that the online
docs don't explain well enough for my simple brain) and it could be
handy for me.
Sadly, I was wanting to use the spline library in exactly the same
stretch of code as where I use the transformations. Oddly, the splines
vec3d, transform and project didn't seem to fail in all cases, so I need
to peer at code and run some tests to understand why, but I've currently
prefixed their names in the spline library.
I'd love a mode where you can get warnings (with line numbers, please!)
when constants, modules or functions are redefined as even working out
why I was getting lots of warnings (without line numbers!) took me some
time.
On 2017-06-10 18:05, caterpillar wrote: > The scope of xxx.scad will be constrained in the defined module. It's not a > perfect solution but works in some situations. Thanks for the extra info on scoping (a complex topic that the online docs don't explain well enough for my simple brain) and it could be handy for me. Sadly, I was wanting to use the spline library in exactly the same stretch of code as where I use the transformations. Oddly, the splines vec3d, transform and project didn't seem to fail in all cases, so I need to peer at code and run some tests to understand why, but I've currently prefixed their names in the spline library. I'd love a mode where you can get warnings (with line numbers, please!) when constants, modules or functions are redefined as even working out why I was getting lots of warnings (without line numbers!) took me some time.
Sun, Jun 11, 2017 3:30 AM
time.
https://github.com/openscad/openscad/issues/1936
https://github.com/openscad/openscad/issues/1843
We need some more developers to get to such things...
View this message in context: http://forum.openscad.org/Libraries-and-namespaces-tp21672p21677.html
Gadgetmind wrote > I'd love a mode where you can get warnings (with line numbers, please!) > when constants, modules or functions are redefined as even working out > why I was getting lots of warnings (without line numbers!) took me some > time. https://github.com/openscad/openscad/issues/1936 https://github.com/openscad/openscad/issues/1843 We need some more developers to get to such things... ----- Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- View this message in context: http://forum.openscad.org/Libraries-and-namespaces-tp21672p21677.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Jerry Davis
Sun, Jun 11, 2017 1:27 PM
I would presume that the spline libraries are .scad code.
Why not just rename everywhere in those library files, transform ->
stransform, vec3 -> svec3. And then change your code to use stransform and
svec3.
Without actual knowledge of the code involved, that is how I would try to
manage it. I could be wrong, but it would be my first try.
Extra Ham Operator: K7AZJ
Registered Linux User: 275424
- Isaac. Asimov
On Sat, Jun 10, 2017 at 7:16 AM, Ian Oliver <lists@foxhill.co.uk> wrote: > It turns out that one of the Spline libraries I am using has its own > functions called transform and vec3, which clash with those in the > scad-utils transformations (etc.) libraries I would presume that the spline libraries are .scad code. Why not just rename everywhere in those library files, transform -> stransform, vec3 -> svec3. And then change your code to use stransform and svec3. Without actual knowledge of the code involved, that is how I would try to manage it. I could be wrong, but it would be my first try. -- Extra Ham Operator: K7AZJ Registered Linux User: 275424 Raspberry Pi and Openscad developer *The most exciting phrase to hear in science - the one that heralds new discoveries - is not "Eureka!" but "That's funny...".*- Isaac. Asimov
IO
Ian Oliver
Sun, Jun 11, 2017 4:57 PM
and svec3.
That's exactly what I did, complete with the imaginative "s" prefix, and
the fix took about 20 seconds. However, this was preceded by over an
hour of hunting and fishing to actually work out where in my 1k lines of
scad across half a dozen lines of code and pulling in many libraries the
issue lay.
On 2017-06-11 06:27, Jerry Davis wrote: > Why not just rename everywhere in those library files, transform -> > stransform, vec3 -> svec3. And then change your code to use stransform > and svec3. That's exactly what I did, complete with the imaginative "s" prefix, and the fix took about 20 seconds. However, this was preceded by over an hour of hunting and fishing to actually work out where in my 1k lines of scad across half a dozen lines of code and pulling in many libraries the issue lay.
Jerry Davis
Mon, Jun 12, 2017 1:16 AM
grep and sed or grep and vi are useful.
- Isaac. Asimov
svec3.
lay.
grep and sed or grep and vi are useful. -- Extra Ham Operator: K7AZJ Registered Linux User: 275424 Raspberry Pi and Openscad developer *The most exciting phrase to hear in science - the one that heralds new discoveries - is not "Eureka!" but "That's funny...".*- Isaac. Asimov On Sun, Jun 11, 2017 at 9:57 AM, Ian Oliver <lists@foxhill.co.uk> wrote: > On 2017-06-11 06:27, Jerry Davis wrote: > >> Why not just rename everywhere in those library files, transform -> >> stransform, vec3 -> svec3. And then change your code to use stransform and >> svec3. >> > > That's exactly what I did, complete with the imaginative "s" prefix, and > the fix took about 20 seconds. However, this was preceded by over an hour > of hunting and fishing to actually work out where in my 1k lines of scad > across half a dozen lines of code and pulling in many libraries the issue > lay. > > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
