CentOS6.9 Help getting a newer release installed.
macdarren
Wed, Dec 27, 2017 10:13 PM
I am wondering is their a distribution via yum or other method of running a
later version of Openscad on my CentOS6.9 machine?
I am by no means a Linux Guru, but I can work my way through basic command
line stuff.
I'd like some simple instructions to get a recent version running....I
followed some stuff I could online a while back but it was rather old.
I currently have a 2014 version or Openscad but would like to update so my
linux machine will be more compatible with the my much later Macintosh
systems using newer releases.
Thanks
Darren
I am wondering is their a distribution via yum or other method of running a later version of Openscad on my CentOS6.9 machine? I am by no means a Linux Guru, but I can work my way through basic command line stuff. I'd like some simple instructions to get a recent version running....I followed some stuff I could online a while back but it was rather old. I currently have a 2014 version or Openscad but would like to update so my linux machine will be more compatible with the my much later Macintosh systems using newer releases. Thanks Darren -- Sent from: http://forum.openscad.org/
Jamie Bainbridge
Wed, Dec 27, 2017 10:33 PM
A quick Google search for "openscad EL6" turns up this:
http://blog.chrysocome.net/2014/01/openscad-for-centos-6.html
However I would try run the latest nightly AppImage first:
http://www.openscad.org/downloads.html#snapshots
AppImage is just one file, you make it executable and run it.
That might work or it might not, EL6 may have a glibc which is too old
to use that AppImage. If you get some error in the terminal like
"GLIBC_2_XX" then you can't run that AppImage.
If your aim is to run recent desktop software, it's probably time you
got rid of old EL6 and used something more modern instead. EL7 can run
the OpenSCAD nightly AppImage, as can Ubuntu 16.04 LTS.
Jamie
line stuff.
Thanks
Darren
A quick Google search for "openscad EL6" turns up this: http://blog.chrysocome.net/2014/01/openscad-for-centos-6.html However I would try run the latest nightly AppImage first: http://www.openscad.org/downloads.html#snapshots AppImage is just one file, you make it executable and run it. That might work or it might not, EL6 may have a glibc which is too old to use that AppImage. If you get some error in the terminal like "GLIBC_2_XX" then you can't run that AppImage. If your aim is to run recent desktop software, it's probably time you got rid of old EL6 and used something more modern instead. EL7 can run the OpenSCAD nightly AppImage, as can Ubuntu 16.04 LTS. Jamie On 28 December 2017 at 08:13, macdarren <macdarren@mac.com> wrote: > I am wondering is their a distribution via yum or other method of running a > later version of Openscad on my CentOS6.9 machine? > > I am by no means a Linux Guru, but I can work my way through basic command > line stuff. > > I'd like some simple instructions to get a recent version running....I > followed some stuff I could online a while back but it was rather old. > > I currently have a 2014 version or Openscad but would like to update so my > linux machine will be more compatible with the my much later Macintosh > systems using newer releases. > > Thanks > Darren > > > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
CC
Chris Camacho
Wed, Dec 27, 2017 10:35 PM
grabbing it from github and running qmake / make isn't a terrible trial
there are some scripts to grab dependencies but they didn't work with
Void Linux, but you can always incrementally install missing stuff till
the qmake / make process works...
git clone https://github.com/openscad/openscad.git
https://github.com/openscad/openscad#compilation
obviously your mileage may vary but given a concrete issue with a github
build I'm sure if not me then others here can get you going...
line stuff.
Thanks
Darren
grabbing it from github and running qmake / make isn't a terrible trial there are some scripts to grab dependencies but they didn't work with Void Linux, but you can always incrementally install missing stuff till the qmake / make process works... git clone https://github.com/openscad/openscad.git https://github.com/openscad/openscad#compilation obviously your mileage may vary but given a concrete issue with a github build I'm sure if not me then others here can get you going... On 27/12/17 22:13, macdarren wrote: > I am wondering is their a distribution via yum or other method of running a > later version of Openscad on my CentOS6.9 machine? > > I am by no means a Linux Guru, but I can work my way through basic command > line stuff. > > I'd like some simple instructions to get a recent version running....I > followed some stuff I could online a while back but it was rather old. > > I currently have a 2014 version or Openscad but would like to update so my > linux machine will be more compatible with the my much later Macintosh > systems using newer releases. > > Thanks > Darren > > > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
