Hi Ron,
That is what I've been doing. For certain more or less standard items,
like pocketing holes on a grid, flanges, etc., I've created programs to
create the gcode directly. The user (me) sets the diameters, tool
sizes, speeds, whatever, and ends up with the gcode text file, which is
fed directly into the milling machine. This was written in c#, but I got
fed up with the complexity introduced by microsoft, poor help, and
annual updates of visual studio.
I recently came across openscad, seeing a model on thingiverse, pulled
it apart, and wrote a little program that solved a problem that I had
been puzzling over for years (just a mental exercise, nothing more).
Once I know the limits of scad, I may try and interface it to a gui, so
that I do not have to poke around in the scad file if i just want to
change a few values. I've not got as far as thinking much about that,
and I expect that has already been done. I'm not sure if an openscad
program can be packaged up/compiled/whatever, so that a user can't
modify it.
Thanks,
Best wishes,
Ray
On 27/07/2020 16:56, Ron Wheeler via Discuss wrote:
It sounds like a rethinking of the design process to take advantage of
parametric CAD might be a time-saving exercise.
Using functions and loops to create complex shapes and fill patterns
might be easier compared to fixing disjointed polygons.
Would it make any sense to generate a large fill pattern and import
only the outline and then use a boolean function to trim the fill to
only be retained inside the polygon.
https://openhome.cc/eGossip/OpenSCAD/BooleanOperationsHull.html
https://www.openscad.org/cheatsheet/snapshot.html
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/CSG_Modelling#intersection
Never tested this and others might point out flaws in my logic.
I hope that this helps.
On 2020-07-27 11:04 a.m., Ray West wrote:
Hi Carsten,
On 27/07/2020 15:17, arnholm@arnholm.org wrote:
Hatch filling would not help I think.
I can hatch fill a shape. If it is not complete, the hatch leaks out.
By judicious resizing, and placing sections of the shape on the
screen, it can hatch to boundary and to screen edge, so can narrow
down the region of the gap/s. It can be quicker than zooming in and
micro stepping around the boundary. Also, it can hatch fill as a
boundary is drawn, and then remove the hatching, leaving a watertight
boundary. All a bit clunky, but it gets the job done.
A number of my dxf files are not shapes, just lines, tool paths and
the like. I guess they won't load either.
Ron Wheeler
Artifact Software
438-345-3369
I am not sure why you would want to send an OpenSCAD model to a customer
unless you want them to modify it.
I would think that you would just send the output not the model.
I have only done 3D printing and for that I output the stl file which is
read in by another software (Cura) that figures out the actual paths of
the extruder which are fed to the 3D printer.
http://forum.openscad.org/Is-OpenSCAD-to-CNC-possible-td22175.html might
get you started.
A bit of Google searching might get you a viable tool chain to go from
model to metal.
As you can see, you can get a lot of help here as well.
Ron
On 2020-07-27 12:58 p.m., Ray West wrote:
Hi Ron,
to create the gcode directly. The user (me) sets the diameters, tool
is fed directly into the milling machine. This was written in c#, but
I got fed up with the complexity introduced by microsoft, poor help,
and annual updates of visual studio.
so that I do not have to poke around in the scad file if i just want
to change a few values. I've not got as far as thinking much about
that, and I expect that has already been done. I'm not sure if an
openscad program can be packaged up/compiled/whatever, so that a user
can't modify it.
Thanks,
Best wishes,
Ray
of parametric CAD might be a time-saving exercise.
Hi Carsten,
out. By judicious resizing, and placing sections of the shape on the
watertight boundary. All a bit clunky, but it gets the job done.
Ron Wheeler
Artifact Software
438-345-3369
Ron Wheeler
Artifact Software
438-345-3369
Hi Ron,
I do not want to send an open scad to a customer, unless I know they can
safely modify it. I am hoping to use open scad as a part of a solution.
Since the cnc software can read in stl files, and produce Gcode from
them (similar to, but not the same as Cura) then openscad can be used to
produce them. With a gui front end to scad, then it can replace my
existing method of programmatically generating Gcode. Fwiw, 6 years ago
I was programmatically generating gcode for 3d printing, using a purpose
built hotend in a bridgeport type mill as the printer. It was very slow,
but the resolution was excellent! I've recently looked again at filament
3d printing - the progress in the last 6 years has been quite
impressive, but it is still a slow process for larger items. There are
limitations in machining from an stl file, generally little control in
path direction, etc., but quite doable for some items where utmost
precision is not required.
Best wishes,
Ray
customer unless you want them to modify it.
is read in by another software (Cura) that figures out the actual
paths of the extruder which are fed to the 3D printer.
might get you started.
model to metal.
Ron
Hi Ron,
items, like pocketing holes on a grid, flanges, etc., I've created
programs to create the gcode directly. The user (me) sets the
diameters, tool sizes, speeds, whatever, and ends up with the gcode
text file, which is fed directly into the milling machine. This was
written in c#, but I got fed up with the complexity introduced by
microsoft, poor help, and annual updates of visual studio.
pulled it apart, and wrote a little program that solved a problem
that I had been puzzling over for years (just a mental exercise,
nothing more). Once I know the limits of scad, I may try and
interface it to a gui, so that I do not have to poke around in the
scad file if i just want to change a few values. I've not got as far
as thinking much about that, and I expect that has already been done.
I'm not sure if an openscad program can be packaged
up/compiled/whatever, so that a user can't modify it.
Thanks,
Best wishes,
Ray
Hi Carsten,
the screen, it can hatch to boundary and to screen edge, so can
narrow down the region of the gap/s. It can be quicker than zooming
in and micro stepping around the boundary. Also, it can hatch fill
as a boundary is drawn, and then remove the hatching, leaving a
Ron Wheeler
Artifact Software
438-345-3369
Ron Wheeler
Artifact Software
438-345-3369
I first started doing openscad because of the Thingiverse customiser.
The ability to give the customer to adjust some parameters is rather
awesome, really
On Mon, Jul 27, 2020 at 3:06 PM Ray West raywest@raywest.com wrote:
Hi Ron,
I do not want to send an open scad to a customer, unless I know they can safely modify it. I am hoping to use open scad as a part of a solution. Since the cnc software can read in stl files, and produce Gcode from them (similar to, but not the same as Cura) then openscad can be used to produce them. With a gui front end to scad, then it can replace my existing method of programmatically generating Gcode. Fwiw, 6 years ago I was programmatically generating gcode for 3d printing, using a purpose built hotend in a bridgeport type mill as the printer. It was very slow, but the resolution was excellent! I've recently looked again at filament 3d printing - the progress in the last 6 years has been quite impressive, but it is still a slow process for larger items. There are limitations in machining from an stl file, generally little control in path direction, etc., but quite doable for some items where utmost precision is not required.
Best wishes,
Ray
I am not sure why you would want to send an OpenSCAD model to a customer unless you want them to modify it.
I have only done 3D printing and for that I output the stl file which is read in by another software (Cura) that figures out the actual paths of the extruder which are fed to the 3D printer.
http://forum.openscad.org/Is-OpenSCAD-to-CNC-possible-td22175.html might get you started.
A bit of Google searching might get you a viable tool chain to go from model to metal.
Ron
Hi Ron,
That is what I've been doing. For certain more or less standard items, like pocketing holes on a grid, flanges, etc., I've created programs to create the gcode directly. The user (me) sets the diameters, tool sizes, speeds, whatever, and ends up with the gcode text file, which is fed directly into the milling machine. This was written in c#, but I got fed up with the complexity introduced by microsoft, poor help, and annual updates of visual studio.
I recently came across openscad, seeing a model on thingiverse, pulled it apart, and wrote a little program that solved a problem that I had been puzzling over for years (just a mental exercise, nothing more). Once I know the limits of scad, I may try and interface it to a gui, so that I do not have to poke around in the scad file if i just want to change a few values. I've not got as far as thinking much about that, and I expect that has already been done. I'm not sure if an openscad program can be packaged up/compiled/whatever, so that a user can't modify it.
Thanks,
Best wishes,
Ray
It sounds like a rethinking of the design process to take advantage of parametric CAD might be a time-saving exercise.
Using functions and loops to create complex shapes and fill patterns might be easier compared to fixing disjointed polygons.
Would it make any sense to generate a large fill pattern and import only the outline and then use a boolean function to trim the fill to only be retained inside the polygon.
Hi Carsten,
I can hatch fill a shape. If it is not complete, the hatch leaks out. By judicious resizing, and placing sections of the shape on the screen, it can hatch to boundary and to screen edge, so can narrow down the region of the gap/s. It can be quicker than zooming in and micro stepping around the boundary. Also, it can hatch fill as a boundary is drawn, and then remove the hatching, leaving a watertight boundary. All a bit clunky, but it gets the job done.
A number of my dxf files are not shapes, just lines, tool paths and the like. I guess they won't load either.
Ron Wheeler
Artifact Software
438-345-3369
Ron Wheeler
Artifact Software
438-345-3369
Without knowing the type of models that you are generating, it is hard
to be sure that my suggestions are worthwhile.
Given that caveat and my willingness to be embarrassed by people who
actually know what they are doing, I will make the following comments.
It would seem that in some cases, it may be possible to produce OpenSCAD
scripts that would allow customers to enter some parameters and have the
scripts generate the ultimate object.
In some cases, the customer would not have to touch the lower level
scripts and in the best cases, the customer would only have to set some
number of parameters and invoke your scripts to produce the object that
they desire. OpenSCAD would allow them to visualize the object and take
any relevant measurements to verify that their parameters are generating
the correct model.
I think that some of the responses to this thread give ideas that are
worth pursuing about the process to take an OpenSCAD model and run it
through other programs that create the correct tool paths and CNC
instructions to produce the desired output.
This seems to the ignorant (me), that worrying about tool paths and
other CNC concerns can be left to the end of the process.
My opinion is that CNC is a more complex problem than 3D printing but
paths, directions and tool choices are all decisions that people have
been able to make for many years and it is not impossible for software
to make the same choices.
The first step may be to produce a sufficiently accurate model about
what you want to make and later on worry about how to make it.
If this can be done, customers are going to be much more productive by
focusing on what they know and leaving the technical details to the tool
chain.
My ignorance gives a certain amount of confidence regarding possible
solutions, but regardless, I hope that this helps.
Ron
On 2020-07-27 3:06 p.m., Ray West wrote:
Hi Ron,
Best wishes,
Ray
Ron
Hi Ron,
Thanks,
Best wishes,
Ray
Hi Carsten,
job done.
Ron Wheeler
Artifact Software
438-345-3369
Ron Wheeler
Artifact Software
438-345-3369
Ron Wheeler
Artifact Software
438-345-3369
Hi Ron,
Any suggestion is worthwhile. If it doesn't help me, it may well help
someone else. Not much point in lurking on fora. If everyone did that,
it would be very dull. High end cnc machining (which I am in no way
involved in) is far, far more involved than 3dprinting, although high
end 3d printing (Renishaw for turbine blades, etc) has some complexity.
I do not have paying business customers, having given up my day job some
years ago. I have customers, in the sense they use what I supply them,
and they come and dig my garden in return, say. A far better method.
Best wishes,
Ray
OpenSCAD scripts that would allow customers to enter some parameters
and have the scripts generate the ultimate object.
some number of parameters and invoke your scripts to produce the
object that they desire. OpenSCAD would allow them to visualize the
object and take any relevant measurements to verify that their
parameters are generating the correct model.
tool chain.
Ron
Hi Ron,
Best wishes,
Ray
Ron
Hi Ron,
Thanks,
Best wishes,
Ray
Hi Carsten,
job done.
Ron Wheeler
Artifact Software
438-345-3369
Ron Wheeler
Artifact Software
438-345-3369
Ron Wheeler
Artifact Software
438-345-3369
