Turns out that there is a web site that will allow you to measure STL
files. You drop the file onto the site and click Measure It Now, after
which you can either rotate the model around (by dragging) or if you
click two points, it will tell you the distance between the points. Not
sure how often I will use it, but others might want to
https://products.aspose.app/3d/measurement/stl
I found a bunch of command line tools for measuring and manipulating STL
files, which may be useful to people. I added some missing functionality to
the project, as it originally only supported binary STL, so I added in
support for converting between binary and ascii, as well as a simple
utility for centring an stl (either at 0, 0, 0 or at 0, 0, bottom face zero)
https://github.com/AllwineDesigns/stl_cmd.git
