So https://github.com/adrianschlatter/threadlib is a thread library that
applies "higbee" ends over a specified angle. That doesn't help a ton.
What I want to know is what is the optimal thread form, perhaps for
different situations if it varies based on situation. That is, if an
abruptly terminated thread is usually best then that should be the
default. If there is a case for a longer taper then make that an easy
alternative, and explain to users, who won't have a clue about any of this
stuff, how they should decide when to select one or the other.
Clearly there's a great deal of confusion about this topic, because it
seems like nobody posting here knows the answer, or even has a case for one
answer or another backed by some kind of justification.
On Tue, Feb 21, 2023 at 7:52 AM Roger Whiteley via Discuss <
Cc:
Bcc:
Date: Tue, 21 Feb 2023 12:52:18 +0000
Subject: [OpenSCAD] Thread ends
The vast majority of machine threads on screws are made on thread rolling
machines with multiple rolling dies around the screw being formed in the
centre.
This makes the thread form stronger through the flow of metal between the
dies, applying work hardening to materials that work harden and deforming
the metal crystal structure to align with the crests and roots of the
thread profile.
Very quick and cheap, about five seconds per screw/bolt including forming
the head - hex/torx/pozi.
ACME and buttress thread forms are machined, either with an automatic
lathe or milled on a multi axis CNC.
I have an OpenSCAD thread library that finishes the end off as discussed
in the thread. But it’s not part of the BOSL library. I’ll dig out a link
later.
From: Roger Whiteley via Discuss discuss@lists.openscad.org
Cc: Roger Whiteley roger.whiteley@me.com
Bcc:
> ---------- Forwarded message ----------
> From: Roger Whiteley <roger.whiteley@me.com>
> Cc:
> Bcc:
> centre.
> thread profile.
> later.
> Roger.
> From: Roger Whiteley via Discuss <discuss@lists.openscad.org>
> Cc: Roger Whiteley <roger.whiteley@me.com>
> Bcc:
