Windows cross compilation
B
buttim
Wed, Mar 8, 2017 10:24 AM
Yes, it says
Editor enhancements, fitrst commit
Add more commits by pushing to the editor-enhancements branch on
buttim/openscad.
This branch has no conflicts with the base branch
Merging can be performed automatically.
...sorry for the typo in the commit comment
Have I done something wrong?
View this message in context: http://forum.openscad.org/Windows-cross-compilation-tp20413p20802.html
Yes, it says / Editor enhancements, fitrst commit Add more commits by pushing to the editor-enhancements branch on buttim/openscad. This branch has no conflicts with the base branch Merging can be performed automatically. / ...sorry for the typo in the commit comment Have I done something wrong? -- View this message in context: http://forum.openscad.org/Windows-cross-compilation-tp20413p20802.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Wed, Mar 8, 2017 1:50 PM
Something is strange. I see https://github.com/buttim/openscad
which is somehow missing the link to the original repository.
Normally the github clone should retain the upstream link, e.g.
if you look at my repo https://github.com/t-paul/openscad it has
that small "forked from openscad/openscad" in the upper left
corner.
I guess due to that missing link to the original repo, the
pull request ended up in your own repo instead of the one
hosted in the openscad account.
I'm not sure if there's a simple fix for this. It might be
easiest to delete that repo on github and clone it again
via the web interface - should be really just a single click
on the "Fork" button on the top right corner on the main
repo: https://github.com/openscad/openscad
Something is strange. I see https://github.com/buttim/openscad which is somehow missing the link to the original repository. Normally the github clone should retain the upstream link, e.g. if you look at my repo https://github.com/t-paul/openscad it has that small "forked from openscad/openscad" in the upper left corner. I guess due to that missing link to the original repo, the pull request ended up in your own repo instead of the one hosted in the openscad account. I'm not sure if there's a simple fix for this. It might be easiest to delete that repo on github and clone it again via the web interface - should be really just a single click on the "Fork" button on the top right corner on the main repo: https://github.com/openscad/openscad ciao, Torsten.
B
buttim
Wed, Mar 8, 2017 2:43 PM
I probably cloned and not forked the original project.
I did it over again, let me know if it sounds better
View this message in context: http://forum.openscad.org/Windows-cross-compilation-tp20413p20804.html
I probably cloned and not forked the original project. I did it over again, let me know if it sounds better -- View this message in context: http://forum.openscad.org/Windows-cross-compilation-tp20413p20804.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Wed, Mar 8, 2017 3:59 PM
Yes, I saw the notification on IRC. It's now listed
in https://github.com/openscad/openscad/pull/1967
I can try building the Windows snapshot from that
pull request.
Von: buttim <maurizio.butti@gmail.com> > I probably cloned and not forked the original project. > I did it over again, let me know if it sounds better > Yes, I saw the notification on IRC. It's now listed in https://github.com/openscad/openscad/pull/1967 I can try building the Windows snapshot from that pull request. ciao, Torsten.
B
buttim
Thu, Mar 9, 2017 2:11 PM
I noticed on GitHub the message "All checks have failed" regarding continuous
integration
What does that mean?
View this message in context: http://forum.openscad.org/Windows-cross-compilation-tp20413p20828.html
I noticed on GitHub the message "All checks have failed" regarding continuous integration What does that mean? -- View this message in context: http://forum.openscad.org/Windows-cross-compilation-tp20413p20828.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Thu, Mar 9, 2017 3:30 PM
If you click on "Details" you see that two Linux builds were successful but
the OSX build timed out during the tests. The tests it did run were
successful. This is often the case because it seems to be much slower than
the other two and it is marginal whether it completes or not, so I think
you can ignore it.
continuous
integration
If you click on "Details" you see that two Linux builds were successful but the OSX build timed out during the tests. The tests it did run were successful. This is often the case because it seems to be much slower than the other two and it is marginal whether it completes or not, so I think you can ignore it. On 9 March 2017 at 14:11, buttim <maurizio.butti@gmail.com> wrote: > I noticed on GitHub the message "All checks have failed" regarding > continuous > integration > What does that mean? > > > > -- > View this message in context: http://forum.openscad.org/ > Windows-cross-compilation-tp20413p20828.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
B
buttim
Thu, Mar 9, 2017 3:35 PM
Great. Is the resulting (Windows) executables available for download
somewhere?
View this message in context: http://forum.openscad.org/Windows-cross-compilation-tp20413p20831.html
Great. Is the resulting (Windows) executables available for download somewhere? -- View this message in context: http://forum.openscad.org/Windows-cross-compilation-tp20413p20831.html Sent from the OpenSCAD mailing list archive at Nabble.com.
N
nophead
Thu, Mar 9, 2017 3:40 PM
Not until somebody makes one and uploads it.
View this message in context: http://forum.openscad.org/Windows-cross-compilation-tp20413p20833.html
Not until somebody makes one and uploads it. -- View this message in context: http://forum.openscad.org/Windows-cross-compilation-tp20413p20833.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Thu, Mar 9, 2017 3:41 PM
download somewhere?
No, that needs to be built on our separate build server and
that's currently still triggered manually.
I'll try to get that running later today. The binaries will
show up in at http://files.openscad.org/snapshots/
Von: buttim <maurizio.butti@gmail.com> > Great. Is the resulting (Windows) executables available for > download somewhere? > No, that needs to be built on our separate build server and that's currently still triggered manually. I'll try to get that running later today. The binaries will show up in at http://files.openscad.org/snapshots/ ciao, Torsten.
Thu, Mar 9, 2017 10:09 PM
Got a compile error, probably caused by a recent change, so
I'm trying to upgrade MXE on the build server. That will
need half a day to compile...
On 03/09/2017 04:41 PM, Torsten Paul wrote: > I'll try to get that running later today. The binaries will > show up in at http://files.openscad.org/snapshots/ > Got a compile error, probably caused by a recent change, so I'm trying to upgrade MXE on the build server. That will need half a day to compile... ciao, Torsten.
