New matrix functions:
New modules:
New Parameters:
Improved Performance:
What a wonderful Artwork Perfect to fiddle with. If this has a positive
meaning THX
OpenSCAD has matrix multiplication built in. E.g. ma * mb.
meaning THX
You might mean things like [1,2,3]*[4,5,6].
Matrices passed into m_multiply have the data structure [[1,2,3],[4,5,6]]
required by multmatrix.
I didn't know it!!!! Thank you very much!!!!
Your first examples are vectors and I think it does the dot product in that
case but if you pass matrices as your second example it does matrix
multiplication as long as the dimensions are compatible. In you case 4 x 4
will work fine.
Yes, you are right. I soon found that 4 x 4 will work fine so I deleted my
origin reply :p
Thank you very much again. It helps a lot!
