Snapshot continuous preview
PK
Peter Kriens
Thu, May 22, 2025 3:24 PM
I recently downloaded the latest snapshot of OpenSCAD for MacOS. In this snapshot, the preview is continuously enabled which is really awful. It does not even wait a few seconds so when your typing you get lots of errors and sometimes it hangs which requires aborting the app.
This would work if the rendering was done in the background and would stop when you type a next character. This would also allow canceling a render which would prevent many 'Quit Application' operations for me.
The way it works now is imho quite bad. Is there a way to disable it? I can't find it in the preferences?
Kind regards,
Peter Kriens
I recently downloaded the latest snapshot of OpenSCAD for MacOS. In this snapshot, the preview is continuously enabled which is really awful. It does not even wait a few seconds so when your typing you get lots of errors and sometimes it hangs which requires aborting the app. This would work if the rendering was done in the background and would stop when you type a next character. This would also allow canceling a render which would prevent many 'Quit Application' operations for me. The way it works now is imho quite bad. Is there a way to disable it? I can't find it in the preferences? Kind regards, Peter Kriens
Thu, May 22, 2025 4:35 PM
It's a bug.  It should be fixed in builds starting on May 16, issue
#5795 https://github.com/openscad/openscad/issues/5795, PR#5901
https://github.com/openscad/openscad/pull/5901.
Workaround by turning off Design / Automatic Reload and Preview.
It's a bug.  It should be fixed in builds starting on May 16, issue #5795 <https://github.com/openscad/openscad/issues/5795>, PR#5901 <https://github.com/openscad/openscad/pull/5901>. Workaround by turning off Design / Automatic Reload and Preview.
PK
Peter Kriens
Thu, May 22, 2025 4:43 PM
Thanks, I'll check it out.
On Thu 22 May 2025 at 18:35, Jordan Brown openscad@jordan.maileater.net
Thanks, I'll check it out. On Thu 22 May 2025 at 18:35, Jordan Brown <openscad@jordan.maileater.net> wrote: > It's a bug. It should be fixed in builds starting on May 16, issue #5795 > <https://github.com/openscad/openscad/issues/5795>, PR#5901 > <https://github.com/openscad/openscad/pull/5901>. > > Workaround by turning off Design / Automatic Reload and Preview. > >
John David
Fri, May 23, 2025 5:10 PM
Cool.  Me too.  This has been driving me NUTS!  Not to say it takes much ;-)
On Thu, May 22, 2025 at 12:43 PM Peter Kriens via Discuss <
Cool. Me too. This has been driving me NUTS! Not to say it takes much ;-) On Thu, May 22, 2025 at 12:43 PM Peter Kriens via Discuss < discuss@lists.openscad.org> wrote: > Thanks, I'll check it out. > > On Thu 22 May 2025 at 18:35, Jordan Brown <openscad@jordan.maileater.net> > wrote: > >> It's a bug. It should be fixed in builds starting on May 16, issue #5795 >> <https://github.com/openscad/openscad/issues/5795>, PR#5901 >> <https://github.com/openscad/openscad/pull/5901>. >> >> Workaround by turning off Design / Automatic Reload and Preview. >> >> _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
