Nop Head,I disagree with you, 0/0 is not defined, so it is not a number.Undef or Nan are both acceptable.
Jean-PaulAC9GH
Sent from my Verizon Wireless 4G LTE smartphone
-------- Original message --------
Date: 2015/10/24 8:08 PM (GMT-05:00)
Subject: Re: [OpenSCAD] Software bug
I am not sure undef and nan are the same. If I don't define x but use it then it is undefined. x = 0/0 is different because x is defined but mathematically not a number.
On 24 October 2015 at 23:37, Andrew Plumb andrew@plumb.org wrote:
If you were trying to test “2^(1/0)” then the function you want is pow(2,1/0).
echo( exp(1/0) );-> infecho( pow(2,1/0) );-> inf
Andrew.
On Oct 24, 2015, at 5:39 PM, doug moen doug@moens.org wrote:
exp(x) is a function that takes exactly one argument. It's probably using generic code to return undef if the number of arguments is incorrect. Which is fine.
undef and NaN play exactly the same role in the language. Rather than debate when to return undef and when to return nan in a bunch of different cases, I'd rather just unify them into a single value.
On 24 October 2015 at 17:29, don bright hmbright@fastmail.com wrote:
The manual has been updated.
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Mathematical_Functions#Infinitudes_and_NaNs
Interesting note.... OpenSCAD seems to return 'undef' for exp(2,1/0) but it is probably intended to be returning NaN....
On Sat, Oct 24, 2015, at 06:55 AM, nop head wrote:
atan(90) is not infinite, it is close to 90 degrees as is the atan of any large number. It approaches 90 asymptotically.
tan(90) is definitely infinite, so inf is correct.
echo(atan(tan(90))); gives 90 as it should.
Only 0/0 is undefined and that does give nan.
On 24 October 2015 at 05:13, doug moen doug@moens.org wrote:
The IEEE floating point standard says that 2/0 is inf, and that's the standard we are following. While your argument for NaN is mathematically correct, at least where real numbers or exact arithmetic is concerned, floating point computation doesn't have the same behaviour as real number arithmetic. For example, it has underflow, where a sufficiently small positive result is represented by 0, and a sufficiently small negative result is represented by -0, which is different from 0 in IEEE floats. So the floating point number 0 sometimes represents a true 0, and it sometimes represents a very small positive real number. So the IEEE float standards committee decided to define 1/0 as inf and -1/0 as -inf, and this results in useful behaviour, making it easier to write floating point code, in a lot of cases. And yes, this is a compromise, since it's not the right behaviour in all cases.
On 23 October 2015 at 23:37, wolf wv99999@gmail.com wrote:
echo(2/0, atan(2/0), atan(90));
returns
ECHO: inf, 90, 89.3634
The proper response for a division by zero should be not-a-number (NaN),
since that division may result in any number. Consider sin(0)/0=0, which is
a valid expression since the limit for xapproaching zero exists.
atan(2/0) should result in undefined, and atan(90) should result in inf,
since the respective Taylor series does not converge and no value can be
computed.
By the way, is there a means to properly display a formula like
binom{limit}{x rightarrow 0} {sin( x)} over {x} = 0
when posting?
View this message in context: http://forum.openscad.org/Software-bug-tp14194.html
IEEE 754 does lay down rules on how to deal with situations that High-School
mathematics does not cover, such as division-by-zero in a context of
finite calculation accuracy (My training in High-School maths always
assumed infinite accuracy). To quote
https://www.cs.berkeley.edu/~wkahan/ieee754status/IEEE754.PDF :
"Exception: DIVIDE by ZERO
This is a misnomer perpetrated for historical reasons. A better name for
this exception is
"Infinite result computed Exactly from Finite operands."
An example is 3.0/0.0, for which IEEE 754 specifies an Infinity as the
default result." Unquote.
This 30 page paper discusses what to report in case of an over- or
underflow, the range of opinions that (have) exist(ed) on the action to be
taken and how unequally this has been implemented historically. Interesting
reading.
Unequal implementation over different hardware is what I experienced, and
reported as a bug. Let's stick to IEEE754.
Wolf
View this message in context: http://forum.openscad.org/Software-bug-tp14194p14211.html
On 25 October 2015 at 03:17, louijp louijp@yahoo.com wrote:
Nop Head,
It is defined in the programming sense. It has been given a value that is
undefined in the mathematical sense represented by nan. That is different
to using a variable that has never been assigned.
Jean-Paul
AC9GH
pow(2,1/0).
echo( exp(1/0) );
-> inf
echo( pow(2,1/0) );
-> inf
Andrew.
is fine.
returns
is
computed.
when posting?
I think the compiler should report a fatal error message if there is a
reference to an unassigned variable.
Right now, we only report a warning for this. I've seen 4 or 5 forum posts
where people can't understand what their program is doing in this
situation. The warning is there, but they kind of skim over that and go to
the forum for help. There's also a couple pages in the manual about the
horribly unintuitive behaviour that results when you include a file and you
also have references to unassigned variables. Just make it an error and
this source of confusion will go away.
On Sunday, 25 October 2015, nop head nop.head@gmail.com wrote:
On 25 October 2015 at 03:17, louijp <louijp@yahoo.com
javascript:_e(%7B%7D,'cvml','louijp@yahoo.com');> wrote:
Nop Head,
Jean-Paul
AC9GH
javascript:_e(%7B%7D,'cvml','nop.head@gmail.com');>
To: OpenSCAD general discussion <discuss@lists.openscad.org
javascript:_e(%7B%7D,'cvml','discuss@lists.openscad.org');>
On 24 October 2015 at 23:37, Andrew Plumb <andrew@plumb.org
pow(2,1/0).
echo( exp(1/0) );
-> inf
echo( pow(2,1/0) );
-> inf
Andrew.
On Oct 24, 2015, at 5:39 PM, doug moen <doug@moens.org
Which is fine.
On 24 October 2015 at 17:29, don bright <hmbright@fastmail.com
On 24 October 2015 at 05:13, doug moen <doug@moens.org
On 23 October 2015 at 23:37, wolf <wv99999@gmail.com
returns
which is
computed.
when posting?
javascript:_e(%7B%7D,'cvml','Discuss@lists.openscad.org');
The problem is backwards compatibility. I have things like this at the
moment:
exploded = $exploded == undef ? 0 : $exploded; // 1 for exploded view
Nop Head,
Jean-Paul
AC9GH
pow(2,1/0).
echo( exp(1/0) );
-> inf
echo( pow(2,1/0) );
-> inf
Andrew.
Which is fine.
returns
(NaN),
which is
inf,
be
computed.
when posting?
