Hello,
I just bought the Spacemouse
https://www.3dconnexion.com/spacemouse_wireless/ and tried OpenSCAD where
I was full of hope because of the complex properties.
But it seems to me either I don't get it to work or the developers have no
Spacemouse and have blindly coded? If the latter happened I would ask you
to buy one ( It's € ~177,-), I supported you already but I would add
something more if you respond positively.
The main issue is that the axis are not enough, also the "point of view" is
not the solution. It needs more something like "the way of watching the the
object"..
The 'Zoom Y' to Axis 1 is the right direction, but it needs still moving Y
but not directly.. (that's above my english and understanding)
here is a little demo https://photos.app.goo.gl/B8arEHk2B8eA61GJ8 showing
the main problem: it moves straightly x and y:
it starts with 'correct' alignment regarding x,y, then I rotate it 90º so
that x and y is flipped) and it moves fix on x axis while I expect to move
it y (the intention of moving with the spacemouse). The turbine is a demo
for movements. It works the same (with some speed adaptions) in Fusion360
and Prusa Slicer.
If I'm totaly wrong here please give me a hint how I get it to work or
where to post. Thank you!
I'm not sure I understand what you mean, but it sounds like
you need to assign the axis inputs to the viewport relative
selection.
