nophead wrote
adrian wrote
No, wrong direction.
You seem to want a module higher in the tree to affect a module lower in
the tree. That is the right direction for dynamic scope variables. They
are visible to all the lower modules in the tree, i.e. nearer and
including the leaves.
So instead of using color in foo you use a module that gets information
from higher in tree to set the colour.
Oh, you're right, but you can't modify based on the previous value, you can
only override th value. So, given the example I suggested, I can set, but
not *increase *or decrease. Or perhaps I could but not in a scalable way.
View this message in context: http://forum.openscad.org/Is-there-a-way-to-determine-if-doing-a-render-as-opposed-to-a-preview-tp20588p20604.html
Thanks Greg,
Forgot about that operator. Still, I need the context, so not exactly what
I'm looking for.
View this message in context: http://forum.openscad.org/Is-there-a-way-to-determine-if-doing-a-render-as-opposed-to-a-preview-tp20588p20605.html
I don't see why you can't do exactly what you want as you can pass as much
down the tree as you want, but without coding it myself I can't be sure.
On 26 February 2017 at 20:15, adrian adrianh.bsc@gmail.com wrote:
Thanks Greg,
I'm looking for.
Hi nophead,
Try doing it with the example that I posted above:
module foo(){ color([1,0,0,.5]) sphere(r=10); translate([10,0,0])
color([0,1,0,.25]) sphere(r=10);}
View this message in context: http://forum.openscad.org/Is-there-a-way-to-determine-if-doing-a-render-as-opposed-to-a-preview-tp20588p20607.html
