On my Ubuntu install, OpenSCAD version 2015.03-1, Hebrew characters do not
show unless I specify another font, not the built-in Liberation Sans. In my
case, I tried Arial and was able to get the several Hebrew letters I tried
including, \u05d0 for "alef"
http://forum.openscad.org/file/n21063/alef.png
View this message in context: http://forum.openscad.org/OpenSCAD-text-with-non-latin-characters-tp9817p21063.html
Looks like a Linux unique issue.
Alef worked on 2015.03-2,03-2, 2017.01.20 on Windows-7.
View this message in context: http://forum.openscad.org/OpenSCAD-text-with-non-latin-characters-tp9817p21064.html
OpenSCAD does not do any font or glyph substitution, so you will get
what the specified font (or to be precise the one selected by fontconfig)
has, which can be some dummy glyph if the font does not support a given
codepoint.
There are not many fonts that have good support for lots of different
languages/scripts. In some cases special font files are provided that
cover various sections of the unicode pages.
my case, I tried Arial and was able to get the several Hebrew letters I
tried including, \u05d0 for "alef"
With Liberation Sans, did you just use text() without specifying a
font/style, ie defaulted, or did you explicitly specify it?
What happens if you do/don't?
View this message in context: http://forum.openscad.org/OpenSCAD-text-with-non-latin-characters-tp9817p21067.html
Michael,
Just tested:
*text("\u05d0"); -***Produces a rectangular box character substitute.
*text("\u05d0",font="Liberation Sans"); -***Produces a rectangular box
*text("\u05d0",font="sans-serif"); - *Produces the alef character - א
text("\u05d0",font="Arial"); - produces the alef as I mentioned in an
earlier post to this thread.
The system font (in my Kubuntu 16.10) is Noto Sans. If I try Noto Sans
in OpenSCAD, I get a wider generic box character substitute, not the
same one as when I specify Liberation Sans.
Specifying Liberation Sans in LibreOffice or in Inkscape DOES produce
the alef. I do not know if OpenSCAD is using "my" installed Liberation
Sans or its own. The reading I did in the manual suggested that a
version of Liberation Sans is built into OpenSCAD to avoid problems.
While there is a possibility that there are different fonts, it's more
likely that the mentioned font substitution is going on. It certainly
is on my system (Debian / Testing).
If I select Liberation Sans as font and start typing something like
"Test" and then continue with <CTRL+SHIFT+u>5d0<RETURN> to input that
unicode character, the font box switches to FreeSans temporarily for
this character because it's not available in Liberation Sans.
a. Try* text("\u05d0",font="Liberation Sans:style=Regular");* (Prob. wont
work...)
b. Have a look at Help/Font_List, I seem to have two Liberations
http://forum.openscad.org/file/n21074/font_list_re_hebrew.png
With Windows tools I am unable to see them individually so don't know which
is used.
So I deleted the Windows one, then the Hebrew still worked in OpenSCAD.
http://forum.openscad.org/file/n21074/font_list_2_re_hebrew.png
I'm not a Linux font guru, so can't help further, but it seems the included
font does have Hebrew.
So you need to investigate other Liberations installed.
View this message in context: http://forum.openscad.org/OpenSCAD-text-with-non-latin-characters-tp9817p21074.html
