Fri, Jul 31, 2020 5:57 AM
On 7/30/2020 9:24 PM, Hans L wrote:
I've now implemented the capability for undef types to carry a reason
string.
Cool.
So if your program has an undef in its hands, is there a straightforward
way to say "what is the reason for this undef"?
I don't know whether it's necessary to have a way to retrieve the
reason, or just a way to say "hey, I don't want an undef, this is an
error, report the error with the reason for the undef".
One really simple mechanism might be to have assert(undef) report the
reason for the undef.
That would be an exception to the general rule that undef is OK in a
boolean context, but then again undef is false in a boolean context and
assert(false) is an error, so it's not stretching the rule very much.
> string.
Cool.
I don't know whether it's necessary to have a way to _retrieve_ the
Fri, Jul 31, 2020 10:36 AM
Another question: is there a way to create an undef and associate a reason,
so for example
undef("line_intersection: lines did not intersect")
string.
Cool.
so for example
>> string.
> Cool.
> Discuss@.openscad
HL
Hans L
Fri, Jul 31, 2020 7:19 PM
No I haven't added any mechanism to query or set undefined strings
programmatically from scripts, since I felt like that needed some more
thought and planning around the interface, and wanted to limit this PR to
only the least contentious changes.
Adding either of those should be fairly quick and simple to implement
though.
For displaying the string, i considered that echo() and str() could
possibly automatically show the undef strings if any. But this might end
up with more verbose messages than people would like for general cases.
Also as far as I know, echo() and str() generally work in such a way where
you could copy/paste output back into a script and it should be parsed into
the same literal values. So doing something like that should
probably require that we first lock in how the string would be set
programmatically (see below).
Having assert() handle undef as a special case might be one good way to
inspect for reason strings though.
Another possibility is that the reason string could be a "member lookup" on
undef types, so e.g. ( some_undef_value.reason ) could return a string.
But then should an undef without any string return undef for that as
well?(its undefs all the way down!)
And would ".reason" on a non-undef type also be undef, or throw an actual
error?
For setting the string, I don't think calling undef() like a function is a
good idea, since we don't want to mix up the default literal "undef"
identifier with a new builtin function(constructor basically) identifier of
the same name. But perhaps a function named undefined() would be fine, for
example.
reason,
so for example
string.
Cool.
though.
error?
example.
> reason,
> so for example
> >> string.
> > Cool.
> > _______________________________________________
> > Discuss@.openscad
> Sent from: http://forum.openscad.org/
Fri, Jul 31, 2020 9:29 PM
is a good idea, since we don't want to mix up the default literal
"undef" identifier with a new builtin function(constructor basically)
identifier of the same name.
It's a coin flip. Having the two with the same name would be in a sense
confusing, but at the same time it makes the association between them be
really strong... and it should be really strong.
Of course, you can only ask this question in a language where variable
names[*] and functions are in different namespaces. But OpenSCAD is
such a language.
[*] Yeah, yeah, they aren't variables.
really strong... and it *should* be really strong.
such a language.
Fri, Jul 31, 2020 9:43 PM
Why does it need a different name? One of things I like about OpenSCAD is
modules, functions and variables all have their own namespace and it isn't
ambiguous which one is referred to.
though.
on undef types, so e.g. ( some_undef_value.reason ) could return a string.
error?
example.
reason,
so for example
string.
Cool.
> though.
> error?
> example.
>> reason,
>> so for example
>> >> string.
>> > Cool.
>> > Discuss@.openscad
Doug Moen
Fri, Jul 31, 2020 10:19 PM
A different name for the constant and the function is useful in the context of the new feature under development for function values, wherein functions can exist in the variable namespace.
On Fri, Jul 31, 2020, at 9:43 PM, nop head wrote:
Why does it need a different name? One of things I like about OpenSCAD is modules, functions and variables all have their own namespace and it isn't ambiguous which one is referred to.
No I haven't added any mechanism to query or set undefined strings programmatically from scripts, since I felt like that needed some more thought and planning around the interface, and wanted to limit this PR to only the least contentious changes.
Adding either of those should be fairly quick and simple to implement though.
For displaying the string, i considered that echo() and str() could possibly automatically show the undef strings if any. But this might end up with more verbose messages than people would like for general cases.
Also as far as I know, echo() and str() generally work in such a way where you could copy/paste output back into a script and it should be parsed into the same literal values. So doing something like that should probably require that we first lock in how the string would be set programmatically (see below).
Having assert() handle undef as a special case might be one good way to inspect for reason strings though.
Another possibility is that the reason string could be a "member lookup" on undef types, so e.g. ( some_undef_value.reason ) could return a string. But then should an undef without any string return undef for that as well?(its undefs all the way down!)
And would ".reason" on a non-undef type also be undef, or throw an actual error?
For setting the string, I don't think calling undef() like a function is a good idea, since we don't want to mix up the default literal "undef" identifier with a new builtin function(constructor basically) identifier of the same name. But perhaps a function named undefined() would be fine, for example.
so for example
string.
Cool.
>>> so for example
>>> >> string.
>>> > Cool.
>>> > Discuss@.openscad
Fri, Jul 31, 2020 10:28 PM
What is confusing about calling undef() like a function? You say we don't
want to "mix up" the undef literal with an undef constructor, but what's the
difference really between
undef
and
undef("some reason text")
Isn't the first one basically the same as the second one only with the
argument missing, in some sense? What's the problem or consequence of
"mixing up" these two things? When there's no string associated with an
undef then what is there? Empty string? Another undef? It's a bit
unclear what the advantage is of not having a string. Shouldn't there
always be one? (undef: "list index out of bounds", undef: "variable not
set", undef: "mismatched argument types for +".) It seems like you'd want
to encourage users to supply the string any time they make an assignment.
I guess there's the question of what it means if you just write "foo=undef",
as in that case there's no string. The string could be "direct assignment"
or something like that.
To me it seems like doing
foo = undef
but
foo = undefined("some reason")
is more confusing because now I have to remember when to use undef and when
to use undefined. It looks like undef is already illegal as a function
name, so it wouldn't break any code, whereas undefined() is currently a
valid function, so using that could break code.
though.
into
on
error?
of
for
example.
reason,
so for example
string.
Cool.
undef
and
foo = undef
but
> though.
> into
> on
> error?
> of
> for
> example.
> avm4@
>> reason,
>> so for example
>> >> string.
>> > Cool.
>> straightforward
>> > Discuss@.openscad
> Discuss@.openscad
> Discuss@.openscad
HL
Hans L
Fri, Jul 31, 2020 10:44 PM
As Doug points out, the situation is more complicated if you account for
function literals, which already exist as an experimental feature.
It's not necessarily an issue at the moment, but If we ever decided to make
builtin functions accessible as literals (personally i would like to see
this), then writing: foo = undef; would be ambiguous whether you want the
function literal value or the actual undef literal.
the
undef
and
"foo=undef",
foo = undef
but
though.
into
on
error?
of
for
example.
reason,
so for example
string.
Cool.
> the
> undef
> and
> "foo=undef",
> foo = undef
> but
> > though.
> where
> > into
> > on
> > error?
> a
> > of
> > for
> > example.
> > avm4@
> >> reason,
> >> so for example
> >> >> string.
> >> > Cool.
> >> straightforward
> and
> >> > Discuss@.openscad
> > Discuss@.openscad
> > Discuss@.openscad
Fri, Jul 31, 2020 11:34 PM
I hadn't really thought about how function literals might be involved here.
But I'm a little puzzled. Suppose builtin functions can be treated as
literals as shown below. Then
foo = sin
is ambiguous about whether I mean the function "sin" or the variable "sin".
I would think that if you want to make regular functions (and built-ins)
available as literals---which is a really good idea because otherwise it
creates a confusing situation where some functions need to be redefined as
function literals for convenience---you should do something like what MATLAB
does and create a syntax for it. In MATLAB you create a function literal
(they call them handles) from (any) function using "@". So in MATLAB
foo = @sin
assigns a function literal into foo. And the call
foo(@sin,@cos)
passes two function literals into the function foo. Given how namespaces
work in OpenSCAD there's no way to assign a pre-existing function to a
variable or pass functions as literals without a new syntax that "converts"
the function into a literal.
But my point is that
foo=undef
is not any more ambiguous than
foo=sin
so it's not a problem that has to do with undef. So I still don't see any
issue with using the functional form I proposed.
foo = undef; // Plain undef without text
foo = undef("reason"); // undef with text
foo = @undef; // or whatever new syntax.... the undef function...though
why would you ever want that?
Have I missed something?
make
don't
the
undef
and
want
"foo=undef",
assignment"
foo = undef
but
when
though.
into
on
error?
of
for
example.
reason,
so for example
Cool.
foo = sin
foo = @sin
foo(@sin,@cos)
foo=undef
foo=sin
> make
> avm4@
>> don't
>> the
>> undef
>> and
>> want
>> "foo=undef",
>> assignment"
>> foo = undef
>> but
>> when
>> to
>> > though.
>> end
>> where
>> > into
>> lookup"
>> > on
>> actual
>> > error?
>> is
>> a
>> identifier
>> > of
>> > for
>> > example.
>> > avm4@
>> >> reason,
>> >> so for example
>> reason
>> >> >> string.
>> >> > Cool.
>> >> straightforward
>> the
>> and
>> much.
>> >> > Discuss@.openscad
>> > Discuss@.openscad
>> > Discuss@.openscad
> Discuss@.openscad
> Discuss@.openscad
HL
Hans L
Sat, Aug 1, 2020 12:40 AM
The difference is that undef is an already established builtin constant
value, but sin is not.
x = sin;
WARNING: Ignoring unknown variable 'sin', in file , line 1.
If builtin functions were treated as literals, then that would be fine with
no warning, and x would then hold a FunctionType value.
The user would of course be free to assign a value to their own variable
named "sin", and this would shadow our hypothetical builtin function
literal of the same name.
It would be a weird thing for the user to do, but not ambiguous.
here.
foo = sin
"sin".
MATLAB
foo = @sin
foo(@sin,@cos)
foo=undef
foo=sin
make
don't
the
undef
and
want
"foo=undef",
assignment"
foo = undef
but
when
though.
into
on
error?
of
for
example.
reason,
so for example
Cool.
The difference is that undef is an already established builtin *constant
value*, but sin is not.
x = sin;
> here.
> foo = sin
> "sin".
> MATLAB
> foo = @sin
> foo(@sin,@cos)
> foo=undef
> foo=sin
> > make
> > avm4@
> >> don't
> >> the
> >> undef
> >> and
> an
> >> want
> assignment.
> >> "foo=undef",
> >> assignment"
> >> foo = undef
> >> but
> >> when
> >> to
> >> > though.
> >> end
> cases.
> >> where
> >> > into
> to
> >> lookup"
> >> > on
> string.
> >> actual
> >> > error?
> >> is
> >> a
> >> identifier
> >> > of
> fine,
> >> > for
> >> > example.
> >> > avm4@
> >> >> reason,
> >> >> so for example
> >> reason
> >> >> >> string.
> >> >> > Cool.
> >> >> straightforward
> an
> >> the
> a
> >> and
> >> much.
> >> >> > Discuss@.openscad
> >> > Discuss@.openscad
> >> > Discuss@.openscad
> > Discuss@.openscad
> > Discuss@.openscad
