hi,
Welcome to the forum. Your post is still flagged as "This post has NOT been
accepted by the mailing list yet", so nobody gets it unless they look. You
need to subscribe to the mailing list
http://forum.openscad.org/mailing_list/MailingListOptions.jtp?forum=1 ,
and respond to the registration email.
This should get you started, note it is good to overlap things you join by a
small amount and similarly, if you difference() something you want them not
to have the same face, hence the translate([0,0,-small]), so it punches
through the bottom. (look at it without that too see).
small=0.01;
cylinder(h = 6, r1 = 7, r2 = 7);
translate([0, 0, 6-small]) cylinder(h = 7.8+small, r = 8.5);
translate([0, 0, 13.8-small]) cylinder(h = 12.5, r1 = 9.7, r2 = 9.1);
translate([0,0,-small]) cylinder(27.3, r = 5);
Newly minted Admin - PM me if you need anything, or if I've done something stupid...
View this message in context: http://forum.openscad.org/Newbie-Question-tp15297p15298.html
Not sure you got my last message. Thanks for the quick-turn on it!
So now I need to add a taper to it, and I get the overlap so it's not
printed in 3 sections, which would defeat the purpose of it being printed as
a piece.
How do I scale it to be in milimeters? This is a whole new world for me,
but it's hard for me, because I'm not a math person. This is where I pay
for not being any good at math.
View this message in context: http://forum.openscad.org/Newbie-Question-tp15297p15299.html
Other than the one with the photo? No.
as a piece.
OpenSCAD is unit-less. It is the slicing software that translates unit-less
measurements into the units of the printer. Most (?) operate in metric mm.
So if you just use r=5 than will be a circle of 10mm.
Re taper, that will be fiddly to get such a smooth flat-j curve to that
section. An approximation is possible like so: (I just guested at 8mm along
for the skinny part)
$fn=64;
small=0.01;
// approximate taper
translate([0, 0, 13.8-small]) cylinder(h = 8+small, r = 9.7,
r2=9.1); // was h=12.
translate([0, 0, 13.8+8-small]) cylinder(h=1+small, r = 9.1);
translate([0, 0, 13.8+8+1-small]) cylinder(h=4+small, r= 9.1, r2=9.7);
http://forum.openscad.org/file/n15306/n15299_fountain_pen_taper.jpg
I hope you have a very good quality printer, in my experience such small
things don't come out so good.
View this message in context: http://forum.openscad.org/Newbie-Question-tp15297p15306.html
Wow, I'm really, really new at this stuff. Thanks a million for the help. Is there a way to import this into a different CAD to mess with?But you make it look so easy.I have a FlashForge Dreamer, it is supposed to have a decent resolution for it. Haven't printed with it yet, because Santa Claus hasn't officially delivered it. But it's here.I have it also listed on Thingiverse and there's been some help on there with it. Yes, the next step as I understand is slicing. What does that do? Is that the final look and then you save it as a g file or something.
I really need adult supervision on this! This is what happens when you let people with liberal arts degrees gain access to technology. It just slows everyone else down.
View this message in context: http://forum.openscad.org/Newbie-Question-tp15297p15309.html
@laakman, You can export as an stl or obj - which turns the object into a
polygonal approximation. These two file formats are the most commonly read.
OBJ is probably the most common but 3D printer slicers usually prefer STL
files. CAD editors usually keep the files in solids form but you probably
want a polygonal editor to do further work and not a CAD based editor. YMMV.
Then you could edit it further in all kinds of polygonal editing programs.
(such as Blender, Wings3D, very large number of these).
Then re-export as an STL to send to the slicing program associated with your
printer.
I use Repetier - which uses Slic3r(default) or Cura or Skeinforge as the
slicing engines.
These generate gcode which controls the actual printer by making it move in
lines and arcs while extruding (occasionally).
There are several variants of g-code - different machines support different
sets of codes but there is a common set which works pretty well across the
board.
All slicers have to be setup for specific sized XYZ ranges, speeds, rates
etc.
Your printer will have this info and a preferred slicer. Start with that
until you're really comfortable to change it completely.... as usual YMMV
View this message in context: http://forum.openscad.org/Newbie-Question-tp15297p15316.html
I'd suggest you may want to print some calibration objects
http://www.thingiverse.com/thing:13441 first.
View this message in context: http://forum.openscad.org/Newbie-Question-tp15297p15336.html
