Apple M1 Crash
Thu, Jan 14, 2021 10:52 PM
That STL has terminal problems.
http://forum.openscad.org/file/t359/Capture-stock-bearing03.jpg
Purple = duplicate faces, orange = degenerate faces, yellow = holes (mostly
covered by others)
That STL has terminal problems. <http://forum.openscad.org/file/t359/Capture-stock-bearing03.jpg> Purple = duplicate faces, orange = degenerate faces, yellow = holes (mostly covered by others) ----- OpenSCAD Admin - email* me if you need anything, or if I've done something stupid... * on the Forum, click on my MichaelAtOz label, there is a link to email me. Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. -- Sent from: http://forum.openscad.org/
Fri, Jan 15, 2021 12:12 AM
Bit if it is just drawn as part of an assembly and not operated on does it
matter? Why does it cause a big slowdown? Normally OpenCSG doesn't care if
it is manifold, it just draws it.
covered by others)
something stupid...
Bit if it is just drawn as part of an assembly and not operated on does it matter? Why does it cause a big slowdown? Normally OpenCSG doesn't care if it is manifold, it just draws it. On Thu, 14 Jan 2021 at 22:53, MichaelAtOz <oz.at.michael@gmail.com> wrote: > That STL has terminal problems. > <http://forum.openscad.org/file/t359/Capture-stock-bearing03.jpg> > Purple = duplicate faces, orange = degenerate faces, yellow = holes (mostly > covered by others) > > > > ----- > OpenSCAD Admin - email* me if you need anything, or if I've done > something stupid... > > * on the Forum, click on my MichaelAtOz label, there is a link to email me. > > Unless specifically shown otherwise above, my contribution is in the > Public Domain; to the extent possible under law, I have waived all > copyright and related or neighbouring rights to this work. Obviously > inclusion of works of previous authors is not included in the above. > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
