i know what this is for .. lots of work in the objects of C++ and Java,
But $this in a functional language has to be more than a little funky
Could the group please brief me on PKriens PR so that i can update the page on Objects?
Isn’t it premature to worry about documenting stuff hadn’t even made it
into dev yet?
On Fri, Aug 8, 2025 at 10:42 vulcan_--- via Discuss <
https://github.com/openscad/openscad/pull/6022 so that i can update the
page on Objects?
On 8/8/2025 7:41 AM, vulcan_--- via Discuss wrote:
i know what |this| is for .. lots of work in the objects of C++ and Java,
Updating the docs is premature, since the feature isn't in yet.
The essence is the same as it is in JavaScript.
If you have an object o with a member f that is a function, and you
invoke the function as o.f(...), the function is provided with a special
variable $this that is the object. (Or that is a copy of the object;
you can't tell.)
This allows you to do things like
function rect(size) = object(
size = size,
area = function() $this.size.x * $this.size.y
r = rect([10,20]);
echo(r.area());
all i needed to read was that it is premature to document it .. mind you, i did just see the PR pass all tests so ..
all done then, and no action to take
Doesn't mean that it's in its final form. I've had several PRs pass all
of the tests and then die, or change radically, or go on hold for a long
time.
I move it out of draft and hope it gets accepted soon!
Basically a function in an object will know where it came from. The object it came from will be $this. Additionally, it can access all fields in the objects without this prefix.
o = object(
a = 42,
f1 = function() a,
f2 = function() $this.a );
assert( o.f1() == 42 );
assert( o.f2() == 42 );
The context of a method (a function from an object) is:
parent context
fields from objects + $this
parameters
local variables
The lookup is for bottom to top. So a parameter that has the same name as a field will have priority. A local variable overrides the parameter and the object field. You can always access the field with the $this variable.
Functions remain bound tot the object unless assigned to another object.
f1 = o.f1;
assert( f1() == 42 );
f = object( a=4711, f=f1 ).f;
assert( f() == 4711 );
Functions have access to themselves so you can make recursive functions like in a Y combinator:
Y = object( f=function(n) n > 1 ? n*f(n-1) : 1).f;
assert(Y(5)==120);
This will allow for objects. For example,
solid = Prism( size=[10,10,10], size2=5);
inside = box.inside(wall=4);
As an old OO guy I think it might be useful to establish some conventions around some meta data for these objects (like a class name) but that has no urgency. Maybe best to wait a bit with this until we have more experience.
I hope the PR will soon be accepted. I am not unhappy with the current solution.
Peter Kriens
On 9 Aug 2025, at 02:40, Jordan Brown via Discuss discuss@lists.openscad.org wrote:
Doesn't mean that it's in its final form. I've had several PRs pass all of the tests and then die, or change radically, or go on hold for a long time.
