How to separate a geometry having distinct objects ?
Sat, Mar 27, 2021 1:06 PM
Note I moved this to a new thread as it is heading in a different direction.
Note I moved this to a new thread as it is heading in a different direction. ----- OpenSCAD Admin - email* me if you need anything, or if I've done something stupid... * on the Forum, click on my MichaelAtOz label, there is a link to email me. Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. -- Sent from: http://forum.openscad.org/
Sat, Mar 27, 2021 1:13 PM
gilboonet wrote
Hello, I recently discovered Cascade Studio and with it I was able to make
those separation I needed.
So the subject question is now resolved.
gilboonet wrote > Hello, I recently discovered Cascade Studio and with it I was able to make > those separation I needed. So the subject question is now resolved. ----- OpenSCAD Admin - email* me if you need anything, or if I've done something stupid... * on the Forum, click on my MichaelAtOz label, there is a link to email me. Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. -- Sent from: http://forum.openscad.org/
G
gilboonet
Sat, Mar 27, 2021 1:31 PM
Indeed, I already had two working scripts, OpenJSCAD v1, and a JSCAD
(OpenJSCAD v2), this thread is about an OpenSCAD version and it's still not
possible, but I now have a Cascade Studio working script. I hope that one
day it will be possible with OpenSCAD.
Indeed, I already had two working scripts, OpenJSCAD v1, and a JSCAD (OpenJSCAD v2), this thread is about an OpenSCAD version and it's still not possible, but I now have a Cascade Studio working script. I hope that one day it will be possible with OpenSCAD. -- Sent from: http://forum.openscad.org/
G
gilboonet
Sat, Mar 27, 2021 1:47 PM
And to be more precise, with OpenJSCAD (v1 and v2 versions) I needed to write
my own function to separate distinct geometries, and with Cascade Studio
there was already a built-in function to do that (GetSolidFromCompound).
And to be more precise, with OpenJSCAD (v1 and v2 versions) I needed to write my own function to separate distinct geometries, and with Cascade Studio there was already a built-in function to do that (GetSolidFromCompound). -- Sent from: http://forum.openscad.org/
Doug Moen
Sat, Mar 27, 2021 4:40 PM
On Thu, Mar 25, 2021, at 8:46 PM, Jordan Brown wrote:
It is certainly possible to imagine a 3D design tool, even a programming language like OpenSCAD, that can do things like cut up an object and then manipulate the separate solids that result.
Many of the OpenSCAD-like programs are capable of doing this. The primary requirement is that you treat shapes as values, and that you provide programmatic access to the representation of shape values. There are two reasons OpenSCAD can't do this. One is purely about syntax: the language is designed so that it is impossible to reference a shape as a value. The other reason is cultural: the feature has been left out of the language due to concerns about performance. Although, note, the operation to get a triangle mesh out of a shape would be no slower than render().
OpenSCAD can't do that without a major overhaul, because it doesn't do any of the geometry processing until after the program has finished running.
The render() module already exists: it renders the shape into a triangle mesh before the preview runs. So that's not the problem. The "major overhaul" is to the syntax, because it is currently impossible to write a function that takes a shape as an argument and returns a value.
Given that many or most modelling languages let you query geometry, I think the remaining question is whether you can implement this kind of algorithm efficiently in the modelling language. If you are doing this in the domain of triangle meshes, then some models have hundreds of thousands, or millions, of triangles. If you are doing this in Curv, then you are doing it over a voxel grid, and there can likewise be a huge number of voxels. If the performance is superlinear in the number of triangles/voxels, then the wait time could be substantial for complex models.
I don't know about Doug's Curv - Doug?
It's theoretically possible to implement this feature in the Curv language, but the performance would be terrible, because Curv is an interpreted language.
Ideally, you would want to perform this operation in about 50 milliseconds. That would be fast enough to support animation in the customizer, if you are dragging a slider around and watching the shape change in a preview window. I think the best way to get this kind of performance is to design a shape splitting algorithm that can be implemented on the GPU using massive parallelism. Curv programs can be compiled into GPU code, but only for the purpose of rendering, not for doing compute, which is what's needed here. The next major version of Curv will also support GPU compute, because in my opinion that's the missing feature in general purpose high performance 3D modelling languages.
On Thu, Mar 25, 2021, at 8:46 PM, Jordan Brown wrote: > It is certainly possible to imagine a 3D design tool, even a programming language like OpenSCAD, that can do things like cut up an object and then manipulate the separate solids that result. Many of the OpenSCAD-like programs are capable of doing this. The primary requirement is that you treat shapes as values, and that you provide programmatic access to the representation of shape values. There are two reasons OpenSCAD can't do this. One is purely about syntax: the language is designed so that it is impossible to reference a shape as a value. The other reason is cultural: the feature has been left out of the language due to concerns about performance. Although, note, the operation to get a triangle mesh out of a shape would be no slower than render(). > OpenSCAD can't do that without a major overhaul, because it doesn't do any of the geometry processing until after the program has finished running. The render() module already exists: it renders the shape into a triangle mesh before the preview runs. So that's not the problem. The "major overhaul" is to the syntax, because it is currently impossible to write a function that takes a shape as an argument and returns a value. Given that many or most modelling languages let you query geometry, I think the remaining question is whether you can implement this kind of algorithm efficiently in the modelling language. If you are doing this in the domain of triangle meshes, then some models have hundreds of thousands, or millions, of triangles. If you are doing this in Curv, then you are doing it over a voxel grid, and there can likewise be a huge number of voxels. If the performance is superlinear in the number of triangles/voxels, then the wait time could be substantial for complex models. > I don't know about Doug's Curv - Doug? It's theoretically possible to implement this feature in the Curv language, but the performance would be terrible, because Curv is an interpreted language. Ideally, you would want to perform this operation in about 50 milliseconds. That would be fast enough to support animation in the customizer, if you are dragging a slider around and watching the shape change in a preview window. I think the best way to get this kind of performance is to design a shape splitting algorithm that can be implemented on the GPU using massive parallelism. Curv programs can be compiled into GPU code, but only for the purpose of rendering, not for doing compute, which is what's needed here. The next major version of Curv will also support GPU compute, because in my opinion that's the missing feature in general purpose high performance 3D modelling languages.
Sat, Mar 27, 2021 5:08 PM
No, or not exactly.  You have to actually do the various transforms
and operations while the program is running.
I wrote a cheesy little Python-based environment, that processes a
Python API that looks sort of like OpenSCAD.  It doesn't happen to offer
access to the "insides" of objects, but it could.  But that access won't
help here, because the "insides" are just the CSG tree.  The "insides"
of a cylinder are two radii and a height - not a triangle mesh.  Just as
in OpenSCAD, the "output" of the program is a CSG tree, that is then
processed by another program to produce previews and STL.
Yes, it's before the preview.
No, it's not before the program proper finishes executing.  render() is
just a node in the CSG tree.  It doesn't do anything until you start
processing the tree, which is after the program finishes.
Try this program:
n = 3;
m = 6;
for (i=[1:n]) {
    render() {
        for (j=[1:m])
            translate([i,j,0]) sphere(d=i+j);
    echo(i=i);
Watch the timing of the "echo" output.  Observe that the echo output
comes out instantly, and then the slow part starts.
On 3/27/2021 9:40 AM, Doug Moen wrote: > The primary requirement is that you treat shapes as values, and that > you provide programmatic access to the representation of shape values. No, or not exactly.  You have to actually *do* the various transforms and operations while the program is running. I wrote a cheesy little Python-based environment, that processes a Python API that looks sort of like OpenSCAD.  It doesn't happen to offer access to the "insides" of objects, but it could.  But that access won't help here, because the "insides" are just the CSG tree.  The "insides" of a cylinder are two radii and a height - not a triangle mesh.  Just as in OpenSCAD, the "output" of the program is a CSG tree, that is then processed by another program to produce previews and STL. > The render() module already exists: it renders the shape into a > triangle mesh before the preview runs. So that's not the problem. Yes, it's before the preview. No, it's not before the program proper finishes executing.  render() is just a node in the CSG tree.  It doesn't *do* anything until you start processing the tree, which is after the program finishes. Try this program: n = 3; m = 6; for (i=[1:n]) { render() { for (j=[1:m]) translate([i,j,0]) sphere(d=i+j); } echo(i=i); } Watch the timing of the "echo" output.  Observe that the echo output comes out instantly, and *then* the slow part starts.
G
gilboonet
Sat, Mar 27, 2021 5:46 PM
Curv seems very interesting. As I'm doing designs for cardboard crafting I
didn't thought of using it, but I will try. Some months ago, Kurt Hutten
(who is very active in the field of code-cad) wrote a post on OpenJSCAD
forum about a list of curated code cad tools, and I told that it would be a
good thing to have uses cases and see each tool efficiency, that's why I'm
now trying to make the script that made me come to this question here, with
as many design tools as possible, especially OpenSCAD that is the first of
them (even if pov-ray was the first 3d tool I used on the 90').
Curv seems very interesting. As I'm doing designs for cardboard crafting I didn't thought of using it, but I will try. Some months ago, Kurt Hutten (who is very active in the field of code-cad) wrote a post on OpenJSCAD forum about a list of curated code cad tools, and I told that it would be a good thing to have uses cases and see each tool efficiency, that's why I'm now trying to make the script that made me come to this question here, with as many design tools as possible, especially OpenSCAD that is the first of them (even if pov-ray was the first 3d tool I used on the 90'). -- Sent from: http://forum.openscad.org/
Doug Moen
Sat, Mar 27, 2021 6:03 PM
If you have programmatic access to the CSG tree, and you have a Turing equivalent programming language, then it's guaranteed that you can write an algorithm to split the tree into disjoint shapes.  To solve the general case, you'd have to tessellate primitives into triangle meshes yourself, but that is doable in OpenSCAD. Obviously it would be slow, but that's why I said that performance considerations are really important. Obviously it would be better to have an operation that returns the mesh for a shape. I don't think it's that hard to implement (except for syntax). There's already a function that converts a CSG tree to a mesh, just call this function from the interpreter, then convert the mesh to an OpenSCAD value. You don't need to restructure OpenSCAD to do this (see below), except maybe for the syntax issues I mentioned. The arguments I've heard against providing this operation have mostly been about performance: the operation would slow down the onset of preview as much as render() does, and then iterating over the triangle mesh in OpenSCAD might be slow as well (depending on the model), potentially creating even more lag before the preview is rendered.
This rejected pull request demonstrates how to evaluate geometry from inside the interpreter. It's easy:
https://github.com/openscad/openscad/pull/1713
The relevant code is
GeometryEvaluator geomEvaluator(tree);
geom=geomEvaluator.evaluateGeometry(*nc,exact);
The scary part is the syntax. You might need to do major surgery on the parser. Maybe syntax like this:
geom = evaluate_geometry( cube(10); )
or from inside a module,
geom = evaluate_geometry( children(); )
The issue is that evaluate_geometry is not a module and not a function, it is some weird new syntax wired in to the parser. The argument is an OpenSCAD statement, making it a kind of syntax that isn't currently supported.
Doug Moen.
No, or not exactly.  You have to actually do the various transforms and operations while the program is running.
No, it's not before the program proper finishes executing.  render() is just a node in the CSG tree.  It doesn't do anything until you start processing the tree, which is after the program finishes.
Try this program:
n = 3;
m = 6;
for (i=[1:n]) {
render() {
for (j=[1:m])
echo(i=i);
Watch the timing of the "echo" output.  Observe that the echo output comes out instantly, and then the slow part starts.
If you have programmatic access to the CSG tree, and you have a Turing equivalent programming language, then it's guaranteed that you can write an algorithm to split the tree into disjoint shapes. To solve the general case, you'd have to tessellate primitives into triangle meshes yourself, but that is doable in OpenSCAD. Obviously it would be slow, but that's why I said that performance considerations are really important. Obviously it would be better to have an operation that returns the mesh for a shape. I don't think it's that hard to implement (except for syntax). There's already a function that converts a CSG tree to a mesh, just call this function from the interpreter, then convert the mesh to an OpenSCAD value. You don't need to restructure OpenSCAD to do this (see below), except maybe for the syntax issues I mentioned. The arguments I've heard against providing this operation have mostly been about performance: the operation would slow down the onset of preview as much as render() does, and then iterating over the triangle mesh in OpenSCAD might be slow as well (depending on the model), potentially creating even more lag before the preview is rendered. This rejected pull request demonstrates how to evaluate geometry from inside the interpreter. It's easy: https://github.com/openscad/openscad/pull/1713 The relevant code is GeometryEvaluator geomEvaluator(tree); geom=geomEvaluator.evaluateGeometry(*nc,exact); The scary part is the syntax. You might need to do major surgery on the parser. Maybe syntax like this: geom = evaluate_geometry( cube(10); ) or from inside a module, geom = evaluate_geometry( children(); ) The issue is that evaluate_geometry is not a module and not a function, it is some weird new syntax wired in to the parser. The argument is an OpenSCAD *statement*, making it a kind of syntax that isn't currently supported. Doug Moen. On Sat, Mar 27, 2021, at 1:08 PM, Jordan Brown wrote: > On 3/27/2021 9:40 AM, Doug Moen wrote: > >> The primary requirement is that you treat shapes as values, and that you provide programmatic access to the representation of shape values. > > No, or not exactly. You have to actually *do* the various transforms and operations while the program is running. > > I wrote a cheesy little Python-based environment, that processes a Python API that looks sort of like OpenSCAD. It doesn't happen to offer access to the "insides" of objects, but it could. But that access won't help here, because the "insides" are just the CSG tree. The "insides" of a cylinder are two radii and a height - not a triangle mesh. Just as in OpenSCAD, the "output" of the program is a CSG tree, that is then processed by another program to produce previews and STL. > >> The render() module already exists: it renders the shape into a triangle mesh before the preview runs. So that's not the problem. > > Yes, it's before the preview. > > No, it's not before the program proper finishes executing. render() is just a node in the CSG tree. It doesn't *do* anything until you start processing the tree, which is after the program finishes. > > Try this program: > >> n = 3; m = 6; for (i=[1:n]) { render() { for (j=[1:m]) translate([i,j,0]) sphere(d=i+j); } echo(i=i); } >> > Watch the timing of the "echo" output. Observe that the echo output comes out instantly, and *then* the slow part starts.
