Hi, I've made this sensor holder in Autodesk Fusion 360, but now I want to
make it in OpenSCAD instead.
Do you have hints as to what approach I should take? Start with a 2D
figure, and extrude? Start with a 3D box, and cut out?
http://forum.openscad.org/file/n18813/IMG_20161027_211542.jpg
I'd do a 2D of the 'wall' profile & extrude, add the slightly raised base of
the wall as flat cube()'s then prob hull() a few circle()s to get the radius
of the curves of the base and extrude (or you could hull flat cylinder()'s)
The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out!
View this message in context: http://forum.openscad.org/Approach-to-recreate-this-in-OpenSCAD-tp18813p18814.html
<http://forum.openscad.org/file/n18813/IMG_20161027_211542.jpg>
