I've devised the attached file which can be used to recursively put
sub-dividers within a unit cube, in my case I use it with a stackable box
I'm working on, with typical usage:
StackableBox(width = 60, depth = 60, height = 15)
subdivide(a = 0, s = [1, 2, 1]) {
subdivide(a = 1, n = 2);
subdivide(a = 1, s = [1, 3, 1]);
This actually works fine - it first divides the box in three (with ratios
1:2:1) in the X axis, and then the first division is split in 2 on the Y
axis, the second division gets split with ratio 1:3:1, and since the third
division is missing it repeats the first division again:
http://forum.openscad.org/file/t2120/StackableBox-working.png
What's bugging me is that I wanted to provide utility functions like this:
module subdivideX(n = 2, s = undef) {
subdivide(a = 0, n = n, s = s) children();
but if I replace the first subdivide(a = 0, ...) call above with a call to
subdivideX the two sub-children don't work. It's as if the children()
aren't being passed correctly up the chain.
http://forum.openscad.org/file/t2120/StackableBox-broken.png
I don't get what it is about the children() module that means my little
utility wrapper functions don't work.
subdivide.scad http://forum.openscad.org/file/t2120/subdivide.scad
What you have is the implicit union problem.
Modules (and the main program level) perform a union of all the objects
rather than passing sets of objects.
There has been much discussion and nashing of teeth about it.
There, I believe, is consensus to move to a non-implicit union, but it will
break backwards compatibility, so is being planned along with other major
changes into something like OpenSCAD MkII. So don't hold your breath.
p.s. Some reading GitHub issue
https://github.com/openscad/openscad/issues/350 .
I think there are two separate issues: implicit / lazy union evaluation is
a performance thing. The fact that for and modules produce a single group
node instead of an array of children is a different thing entirely.
