Building in Win32 does not finish
jedidreyfus
Fri, Jan 30, 2015 10:42 PM
I am building a 3D shape to export it in .stl because it asked me to and it
goes to 999/1000 and stops there for 20 minutes.
Can someone please help me or tell me what's worng ?
Thank you in advance.
View this message in context: http://forum.openscad.org/Building-in-Win32-does-not-finish-tp11339.html
I am building a 3D shape to export it in .stl because it asked me to and it goes to 999/1000 and stops there for 20 minutes. Can someone please help me or tell me what's worng ? Thank you in advance. -- View this message in context: http://forum.openscad.org/Building-in-Win32-does-not-finish-tp11339.html Sent from the OpenSCAD mailing list archive at Nabble.com.
MK
Marius Kintel
Fri, Jan 30, 2015 10:57 PM
This is common. The process of merging all your individual components into one single solid shape is computationally expensive and unfortunately we use an external library which doesn’t provide much progress info,
We plan to slightly improve this, but this won’t affect the processing time: https://github.com/openscad/openscad/issues/810
Fixing the processing time issue is also in the pipeline, but it’s a larger job.
-Marius
On Jan 30, 2015, at 17:42 PM, jedidreyfus <superralph_7@hotmail.com> wrote: > I am building a 3D shape to export it in .stl because it asked me to and it > goes to 999/1000 and stops there for 20 minutes. > Can someone please help me or tell me what's worng ? This is common. The process of merging all your individual components into one single solid shape is computationally expensive and unfortunately we use an external library which doesn’t provide much progress info, We plan to slightly improve this, but this won’t affect the processing time: https://github.com/openscad/openscad/issues/810 Fixing the processing time issue is also in the pipeline, but it’s a larger job. -Marius
jedidreyfus
Fri, Jan 30, 2015 11:01 PM
Thanks man !
Date: Fri, 30 Jan 2015 15:58:22 -0700
To: superralph_7@hotmail.com
Subject: Re: Building in Win32 does not finish
-Marius
[hidden email]
	If you reply to this email, your message will be added to the discussion below:
	http://forum.openscad.org/Building-in-Win32-does-not-finish-tp11339p11342.html
	To unsubscribe from Building in Win32 does not finish, click here.
	NAML
View this message in context: http://forum.openscad.org/Building-in-Win32-does-not-finish-tp11339p11344.html
Thanks man ! Date: Fri, 30 Jan 2015 15:58:22 -0700 From: ml-node+s1091067n11342h18@n5.nabble.com To: superralph_7@hotmail.com Subject: Re: Building in Win32 does not finish On Jan 30, 2015, at 17:42 PM, jedidreyfus <[hidden email]> wrote: > I am building a 3D shape to export it in .stl because it asked me to and it > goes to 999/1000 and stops there for 20 minutes. > Can someone please help me or tell me what's worng ? This is common. The process of merging all your individual components into one single solid shape is computationally expensive and unfortunately we use an external library which doesn’t provide much progress info, We plan to slightly improve this, but this won’t affect the processing time: https://github.com/openscad/openscad/issues/810 Fixing the processing time issue is also in the pipeline, but it’s a larger job. -Marius _______________________________________________ OpenSCAD mailing list [hidden email] http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org If you reply to this email, your message will be added to the discussion below: http://forum.openscad.org/Building-in-Win32-does-not-finish-tp11339p11342.html To unsubscribe from Building in Win32 does not finish, click here. NAML -- View this message in context: http://forum.openscad.org/Building-in-Win32-does-not-finish-tp11339p11344.html Sent from the OpenSCAD mailing list archive at Nabble.com.
