// star
l=50;
d=20;
num=19;
module point(){
intersection(){
cylinder (d1=d,d2=0,h=l,$fn=3);
translate([0,-l,0])
cube(3*l);
for(j=[0:360/num:360])
rotate([0,0,j])
rotate([0,-90,0]) point();
On 14/12/2024 10:12, Shaporev, Timur via Discuss wrote:
You have got already complete solution without extra libraries,
but just in case https://www.thingiverse.com/thing:3428265
https://www.thingiverse.com/thing:3428265 :-)
From: mike.fraser.1945+osc--- via Discuss discuss@lists.openscad.org
Sent: 14 December 2024 02:11:05
Cc: mike.fraser.1945+osc@gmail.com
Subject: [OpenSCAD] 3D five point star
One of my projects has a star in the center. Using the “star” BOSL2
routine then linear extrude to produce a 3D object works but it looks
plain, i.e. flat on top. Any suggestions how to get something like the
pic below.
Thanks, Mike
I thought you wanted a flat back. If not instead of $fn=3, make it
$fn=4, maybe need to rotate it, and omit the intersection. You can alter
the 'thickness', by using scale on the point in the appropriate direction.
On 14/12/2024 11:09, Raymond West via Discuss wrote:
// star
l=50;
d=20;
num=19;
module point(){
intersection(){
translate([0,-l,0])
cube(3*l);
rotate([0,0,j])
the pic below.
Thanks, Mike
like this
// star
l=40;
d=20;
num=5;
thick=0.5;
rotate([0,0,j])
rotate([0,-90,0])
scale([thick,1,1])
cylinder (d1=d,d2=0,h=l,$fn=4);
alter the 'thickness', by using scale on the point in the appropriate
direction.
// star
l=50;
d=20;
num=19;
module point(){
intersection(){
translate([0,-l,0])
cube(3*l);
rotate([0,0,j])
looks plain, i.e. flat on top. Any suggestions how to get something
like the pic below.
Thanks, Mike
