On Nov 5, 2016, at 16:46, Benjamin benjamin@chaaawa.com wrote:
In the coming few weeks a customiser/gsoc version with this setup would be very cool. They were all built after 2016.06.25, unusable for me (and probably for others).
We’re working on merging Customizer, so stay tuned..
-Marius
I hope you will make the Customizer font smaller (or "customizable") as
well as allowing the programmer to determine the order of the values.
-Marius
On Nov 5, 2016, at 18:23, jon_bondy [via OpenSCAD] ml-node+s1091067n18952h96@n5.nabble.com wrote:
Jon,
Please follow these two issues to track that:
Value order: https://github.com/openscad/openscad/issues/1844
Font sizes: https://github.com/openscad/openscad/issues/1845
-Marius
View this message in context: http://forum.openscad.org/Cylinder-in-Hull-crashes-2016-06-25-Mac-OS-10-9-5-tp17917p18953.html
Hi Benjamin,
I’m still trying to get to the bottom of this. Would you mind testing the 4 executables in the following DMG?
http://files.openscad.org/snapshots/OpenSCAD-tests.dmg
-Marius
View this message in context: http://forum.openscad.org/Cylinder-in-Hull-crashes-2016-06-25-Mac-OS-10-9-5-tp17917p18968.html
Verdict on my machine:
xcode7-newlibs: OK
xcode7: -
xcode8-oldlibs: -
xcode8: OK
Benjamin
On 06/11/16 23:09, kintel wrote:
Hi Benjamin,
-Marius
View this message in context: Re: Cylinder in Hull crashes 2016.06.25
(Mac OS 10.9.5)
On Nov 6, 2016, at 17:53, Benjamin-2 [via OpenSCAD] ml-node+s1091067n18971h85@n5.nabble.com wrote:
xcode7-newlibs: OK
xcode7: -
xcode8-oldlibs: -
xcode8: OK
Thanks - looks like one of the libs are bad.
I might get back to you with more tests.
-Marius
View this message in context: http://forum.openscad.org/Cylinder-in-Hull-crashes-2016-06-25-Mac-OS-10-9-5-tp17917p18972.html
Hi Benjamin,
Sorry to pester you again, but thanks a lot for your tests!
In this version I’ve isolated the issue to the gmp library.
If you could verify which one of the two binaries work and which don’t that would validate my theory:
http://files.openscad.org/snapshots/OpenSCAD-tests2.dmg
-Marius
View this message in context: http://forum.openscad.org/Cylinder-in-Hull-crashes-2016-06-25-Mac-OS-10-9-5-tp17917p18975.html
xcode8-gmp works
xcode7-gmp doesn't
Happy to participate.
Benjamin
On 07/11/16 00:45, kintel wrote:
Hi Benjamin,
-Marius
(Mac OS 10.9.5)
OK,
Hopefully last try:
http://files.openscad.org/snapshots/OpenSCAD-2016.11.06.dmg
I think I fixed it in this one.
It turned out that one of the dependencies (libgmp) had been built for a newer CPU, including some instructions which are not be available on older CPUs.
-Marius
View this message in context: http://forum.openscad.org/Cylinder-in-Hull-crashes-2016-06-25-Mac-OS-10-9-5-tp17917p18978.html
2016.11.06 is fine.
Thanks for supporting old macs.
Benjamin
On 07/11/16 02:12, kintel wrote:
OK,
Hopefully last try:
older CPUs.
-Marius
(Mac OS 10.9.5)
