Difference in a module.
DV
david vanhorn
Thu, Mar 5, 2015 12:51 AM
Newbie here, I don't really know how to frame the question, but here goes:
I defined a rib to put on this clamp that I'm making.  I had already done
the clamp main body to satisfaction, and I was hoping to add these ribs in
with a union.
module Rib() {
difference (){
cylinder(h = (Clamp_X - 40), d=(Rib_Rad*2), center = true);
translate ([(Rib_Rad/2),0,0]){
cube(([(Rib_Rad2),(Rib_Rad2),(Clamp_X-39)]),center= true);
} // end of translate
} // End of difference  !! I expected the scope of the difference to end
here.
} // End of module Rib
//-- Main cube
union (){
cube([Clamp_X, 5,0.01],center=true);
translate ([0,(0 - Rib_Rad),0]){rotate (a=[0,90,0]) {Rib();}};
translate ([0,(0 + Rib_Rad),0]){rotate (a=[0,90,0]) {Rib();}};
}; // End of union
// Holes for screws
translate ([Screw1_X,0,-3]) cylinder (r = Screw_Rad, h=Screw_High,center =
false, $fn=45);
translate ([Screw2_X,0,-3]) cylinder (r = Screw_Rad, h=Screw_High,center =
false, $fn=45);
// Recesses for nuts
translate ([Screw1_X,0,Nut_Offset]) cylinder (r = Nut_Rad,
h=Nut_High,center = false, $fn=6);
translate ([Screw2_X,0,Nut_Offset]) cylinder (r = Nut_Rad,
//-- concave_corners for doing the beveling
bevel(ec1, en1, cr = 10, cres=10, l=size[1]+2);
bevel(ec2, en2, cr = 10, cres=10, l=size[1]+2);
bevel(ec3, en3, cr = 10, cres=10, l=size[0.5]);
bevel(ec4, en4, cr = 10, cres=10, l=size[0.5]);
I thought that this would work, and obviously it's not.
It looks like the differencing in the ribs is somehow applying to the body
of the clamp?
Rendering the rib separately, I am getting what I expect.
Newbie here, I don't really know how to frame the question, but here goes: I defined a rib to put on this clamp that I'm making. I had already done the clamp main body to satisfaction, and I was hoping to add these ribs in with a union. module Rib() { difference (){ cylinder(h = (Clamp_X - 40), d=(Rib_Rad*2), center = true); translate ([(Rib_Rad/2),0,0]){ cube(([(Rib_Rad*2),(Rib_Rad*2),(Clamp_X-39)]),center= true); } // end of translate } // End of difference !! I expected the scope of the difference to end here. } // End of module Rib difference() { //-- Main cube union (){ cube([Clamp_X, 5,0.01],center=true); translate ([0,(0 - Rib_Rad),0]){rotate (a=[0,90,0]) {Rib();}}; translate ([0,(0 + Rib_Rad),0]){rotate (a=[0,90,0]) {Rib();}}; }; // End of union // Holes for screws translate ([Screw1_X,0,-3]) cylinder (r = Screw_Rad, h=Screw_High,center = false, $fn=45); translate ([Screw2_X,0,-3]) cylinder (r = Screw_Rad, h=Screw_High,center = false, $fn=45); // Recesses for nuts translate ([Screw1_X,0,Nut_Offset]) cylinder (r = Nut_Rad, h=Nut_High,center = false, $fn=6); translate ([Screw2_X,0,Nut_Offset]) cylinder (r = Nut_Rad, h=Nut_High,center = false, $fn=6); //-- concave_corners for doing the beveling bevel(ec1, en1, cr = 10, cres=10, l=size[1]+2); bevel(ec2, en2, cr = 10, cres=10, l=size[1]+2); bevel(ec3, en3, cr = 10, cres=10, l=size[0.5]); bevel(ec4, en4, cr = 10, cres=10, l=size[0.5]); } I thought that this would work, and obviously it's not. It looks like the differencing in the ribs is somehow applying to the body of the clamp? Rendering the rib separately, I am getting what I expect.
Thu, Mar 5, 2015 1:26 AM
WARNING: Ignoring unknown variable 'Clamp_X'.
WARNING: Ignoring unknown variable 'Rib_Rad'.
WARNING: Ignoring unknown variable 'Screw1_X'.
WARNING: Ignoring unknown variable 'Screw_Rad'.
WARNING: Ignoring unknown variable 'Screw_High'.
WARNING: Ignoring unknown variable 'Screw2_X'.
WARNING: Ignoring unknown variable 'Nut_Offset'.
WARNING: Ignoring unknown variable 'Nut_Rad'.
WARNING: Ignoring unknown variable 'Nut_High'.
WARNING: Ignoring unknown module 'bevel'.
Please supply the variables.
The TPP is no simple “trade agreement.”  Fight it! http://www.ourfairdeal.org/
View this message in context: http://forum.openscad.org/Difference-in-a-module-tp11886p11887.html
Hi, Compiling design (CSG Tree generation)... WARNING: Ignoring unknown variable 'Clamp_X'. WARNING: Ignoring unknown variable 'Rib_Rad'. WARNING: Ignoring unknown variable 'Clamp_X'. WARNING: Ignoring unknown variable 'Rib_Rad'. WARNING: Ignoring unknown variable 'Rib_Rad'. WARNING: Ignoring unknown variable 'Rib_Rad'. WARNING: Ignoring unknown variable 'Rib_Rad'. WARNING: Ignoring unknown variable 'Clamp_X'. WARNING: Ignoring unknown variable 'Rib_Rad'. WARNING: Ignoring unknown variable 'Clamp_X'. WARNING: Ignoring unknown variable 'Rib_Rad'. WARNING: Ignoring unknown variable 'Rib_Rad'. WARNING: Ignoring unknown variable 'Rib_Rad'. WARNING: Ignoring unknown variable 'Rib_Rad'. WARNING: Ignoring unknown variable 'Clamp_X'. WARNING: Ignoring unknown variable 'Screw1_X'. WARNING: Ignoring unknown variable 'Screw_Rad'. WARNING: Ignoring unknown variable 'Screw_High'. WARNING: Ignoring unknown variable 'Screw2_X'. WARNING: Ignoring unknown variable 'Screw_Rad'. WARNING: Ignoring unknown variable 'Screw_High'. WARNING: Ignoring unknown variable 'Screw1_X'. WARNING: Ignoring unknown variable 'Nut_Offset'. WARNING: Ignoring unknown variable 'Nut_Rad'. WARNING: Ignoring unknown variable 'Nut_High'. WARNING: Ignoring unknown variable 'Screw2_X'. WARNING: Ignoring unknown variable 'Nut_Offset'. WARNING: Ignoring unknown variable 'Nut_Rad'. WARNING: Ignoring unknown variable 'Nut_High'. WARNING: Ignoring unknown module 'bevel'. WARNING: Ignoring unknown module 'bevel'. WARNING: Ignoring unknown module 'bevel'. WARNING: Ignoring unknown module 'bevel'. Compiling design (CSG Products generation)... Please supply the variables. ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/Difference-in-a-module-tp11886p11887.html Sent from the OpenSCAD mailing list archive at Nabble.com.
DV
david vanhorn
Thu, Mar 5, 2015 1:27 AM
Current state of the project:
//-- Bottom Clamp with Ridges
use <obiscad/bevel.scad>
use <obiscad/attach.scad>
Screw_Dia = 4.60 ; //mm for 8/32 screw
Nut_Flats = 8.50 ; // Measure across the flats.
Nut_Slack = 0.40 ;
Flats_Rad = Nut_Flats/2;
Nut_Rad = ((Flats_Rad / cos(30)) + Nut_Slack); // Correction factor for
size.
Nut_High = 3 ;
Nut_Offset = -3 ;
// Basic dimensions of the part
Clamp_X = 95 ; // mm length
Clamp_Y = 45 ; // mm depth
Clamp_Thick = 5 ; //
Clamp_Size=[Clamp_X,Clamp_Y,Clamp_Thick];
// Define screw last
Screw_Rad = (Screw_Dia/2) ;// mm
Screw_High = (Clamp_Thick + 2) ;// mm We will translate down by 1
Screw_Inset = 13 ; //mm from the ends
// Positions for the two screws
Screw1_X = ( 0 - ((Clamp_X/2) - Screw_Inset));
Screw2_X = (Clamp_X - ((Clamp_X/2) + Screw_Inset));
//-- Define the connectors for beveling the for top edges
//-- Top-right beveling
ec1 = [ [Clamp_Size[0]/2, 0, Clamp_Size[2]/2], [0,1,0], 0];
en1 = [ ec1[0], [1,0,1], 0];
//-- Top-left beveling
ec2 = [ [-Clamp_Size[0]/2, 0, Clamp_Size[2]/2], [0,1,0], 0];
en2 = [ ec2[0], [-1,0,1], 0];
//-- Top-front beveling
ec3 = [ [0, -Clamp_Size[1]/2, Clamp_Size[2]/2], [1,0,0], 0];
en3 = [ ec3[0], [0,-1,1], 0];
//-- Top-back beveling
ec4 = [ [0, Clamp_Size[1]/2, Clamp_Size[2]/2], [1,0,0], 0];
en4 = [ ec4[0], [0,1,1], 0];
// Ribs
Rib_Rad = 2 ;//
module Rib() {
difference (){
cylinder(h = (Clamp_X - 40), d=(Rib_Rad*2), center = true, $fs=60);
module Screw_Hole(){
} // End of module
module Nut_Recess(){
} // End of module
// Add the ribs to the box
module Clamp(){
union (){
cube([Clamp_Size],center = true);
}; // End of union
}; // End of module
Clamp();
difference () {
Clamp();
translate ([Screw1_X,0,-3]) Screw_Hole();
translate ([Screw2_X,0,-3]) Screw_Hole();
translate ([Screw1_X,0,Nut_Offset]) Nut_Recess();
translate ([Screw2_X,0,Nut_Offset]) Nut_Recess();
bevel(ec1, en1, cr = 10, cres=10, l=Clamp_Size[1]+2);
bevel(ec2, en2, cr = 10, cres=10, l=Clamp_Size[1]+2);
bevel(ec3, en3, cr = 10, cres=10, l=Clamp_Size[0.5]);
bevel(ec4, en4, cr = 10, cres=10, l=Clamp_Size[0.5]);
} // end of difference
Current state of the project: //----------------------------------------------------------------------- //-- Bottom Clamp with Ridges //----------------------------------------------------------------------- use <obiscad/bevel.scad> use <obiscad/attach.scad> Screw_Dia = 4.60 ; //mm for 8/32 screw Nut_Flats = 8.50 ; // Measure across the flats. Nut_Slack = 0.40 ; Flats_Rad = Nut_Flats/2; Nut_Rad = ((Flats_Rad / cos(30)) + Nut_Slack); // Correction factor for size. Nut_High = 3 ; Nut_Offset = -3 ; // Basic dimensions of the part Clamp_X = 95 ; // mm length Clamp_Y = 45 ; // mm depth Clamp_Thick = 5 ; // Clamp_Size=[Clamp_X,Clamp_Y,Clamp_Thick]; // Define screw last Screw_Rad = (Screw_Dia/2) ;// mm Screw_High = (Clamp_Thick + 2) ;// mm We will translate down by 1 Screw_Inset = 13 ; //mm from the ends // Positions for the two screws Screw1_X = ( 0 - ((Clamp_X/2) - Screw_Inset)); Screw2_X = (Clamp_X - ((Clamp_X/2) + Screw_Inset)); //-- Define the connectors for beveling the for top edges //-- Top-right beveling ec1 = [ [Clamp_Size[0]/2, 0, Clamp_Size[2]/2], [0,1,0], 0]; en1 = [ ec1[0], [1,0,1], 0]; //-- Top-left beveling ec2 = [ [-Clamp_Size[0]/2, 0, Clamp_Size[2]/2], [0,1,0], 0]; en2 = [ ec2[0], [-1,0,1], 0]; //-- Top-front beveling ec3 = [ [0, -Clamp_Size[1]/2, Clamp_Size[2]/2], [1,0,0], 0]; en3 = [ ec3[0], [0,-1,1], 0]; //-- Top-back beveling ec4 = [ [0, Clamp_Size[1]/2, Clamp_Size[2]/2], [1,0,0], 0]; en4 = [ ec4[0], [0,1,1], 0]; // Ribs Rib_Rad = 2 ;// module Rib() { difference (){ cylinder(h = (Clamp_X - 40), d=(Rib_Rad*2), center = true, $fs=60); translate ([(Rib_Rad/2),0,0]){ cube(([(Rib_Rad*2),(Rib_Rad*2),(Clamp_X-39)]),center= true); } // end of translate } // End of difference } // End of module Rib module Screw_Hole(){ cylinder (r = Screw_Rad, h=Screw_High,center = false, $fn=45); } // End of module module Nut_Recess(){ cylinder (r = Nut_Rad, h=Nut_High,center = false, $fn=6); } // End of module // Add the ribs to the box module Clamp(){ union (){ cube([Clamp_Size],center = true); translate ([0,(0 - Rib_Rad),0]){rotate (a=[0,90,0]) {Rib();}}; translate ([0,(0 + Rib_Rad),0]){rotate (a=[0,90,0]) {Rib();}}; }; // End of union }; // End of module Clamp(); /* difference () { Clamp(); translate ([Screw1_X,0,-3]) Screw_Hole(); translate ([Screw2_X,0,-3]) Screw_Hole(); translate ([Screw1_X,0,Nut_Offset]) Nut_Recess(); translate ([Screw2_X,0,Nut_Offset]) Nut_Recess(); bevel(ec1, en1, cr = 10, cres=10, l=Clamp_Size[1]+2); bevel(ec2, en2, cr = 10, cres=10, l=Clamp_Size[1]+2); bevel(ec3, en3, cr = 10, cres=10, l=Clamp_Size[0.5]); bevel(ec4, en4, cr = 10, cres=10, l=Clamp_Size[0.5]); } // end of difference */ On Wed, Mar 4, 2015 at 6:26 PM, MichaelAtOz <oz.at.michael@gmail.com> wrote: > Hi, > > Compiling design (CSG Tree generation)... > WARNING: Ignoring unknown variable 'Clamp_X'. > WARNING: Ignoring unknown variable 'Rib_Rad'. > WARNING: Ignoring unknown variable 'Clamp_X'. > WARNING: Ignoring unknown variable 'Rib_Rad'. > WARNING: Ignoring unknown variable 'Rib_Rad'. > WARNING: Ignoring unknown variable 'Rib_Rad'. > WARNING: Ignoring unknown variable 'Rib_Rad'. > WARNING: Ignoring unknown variable 'Clamp_X'. > WARNING: Ignoring unknown variable 'Rib_Rad'. > WARNING: Ignoring unknown variable 'Clamp_X'. > WARNING: Ignoring unknown variable 'Rib_Rad'. > WARNING: Ignoring unknown variable 'Rib_Rad'. > WARNING: Ignoring unknown variable 'Rib_Rad'. > WARNING: Ignoring unknown variable 'Rib_Rad'. > WARNING: Ignoring unknown variable 'Clamp_X'. > WARNING: Ignoring unknown variable 'Screw1_X'. > WARNING: Ignoring unknown variable 'Screw_Rad'. > WARNING: Ignoring unknown variable 'Screw_High'. > WARNING: Ignoring unknown variable 'Screw2_X'. > WARNING: Ignoring unknown variable 'Screw_Rad'. > WARNING: Ignoring unknown variable 'Screw_High'. > WARNING: Ignoring unknown variable 'Screw1_X'. > WARNING: Ignoring unknown variable 'Nut_Offset'. > WARNING: Ignoring unknown variable 'Nut_Rad'. > WARNING: Ignoring unknown variable 'Nut_High'. > WARNING: Ignoring unknown variable 'Screw2_X'. > WARNING: Ignoring unknown variable 'Nut_Offset'. > WARNING: Ignoring unknown variable 'Nut_Rad'. > WARNING: Ignoring unknown variable 'Nut_High'. > WARNING: Ignoring unknown module 'bevel'. > WARNING: Ignoring unknown module 'bevel'. > WARNING: Ignoring unknown module 'bevel'. > WARNING: Ignoring unknown module 'bevel'. > Compiling design (CSG Products generation)... > > Please supply the variables. > > > > ----- > Unless specifically shown otherwise above, my contribution is in the > Public Domain; To the extent possible under law, I have waived all > copyright and related or neighbouring rights to this work. This work is > published globally via the internet. :) Inclusion of works of previous > authors is not included in the above. > > The TPP is no simple “trade agreement.” Fight it! > http://www.ourfairdeal.org/ > -- > View this message in context: > http://forum.openscad.org/Difference-in-a-module-tp11886p11887.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
DV
david vanhorn
Thu, Mar 5, 2015 1:34 AM
At this point, I expect the two ribs to be sitting on top of a box that is
a bit larger than the ribs, and about as thick.
I commented out the differencing where I drill the screw holes, add nut
recesses, and bevel the edges.
One problem at a time.
Nut_Slack = 0.40 ;
size.
Nut_High = 3 ;
Nut_Offset = -3 ;
// Ribs
Rib_Rad = 2 ;//
module Rib() {
difference (){
} // End of module
} // End of module
module Clamp(){
union (){
}; // End of union
}; // End of module
Clamp();
difference () {
Clamp();
At this point, I expect the two ribs to be sitting on top of a box that is a bit larger than the ribs, and about as thick. I commented out the differencing where I drill the screw holes, add nut recesses, and bevel the edges. One problem at a time. On Wed, Mar 4, 2015 at 6:27 PM, david vanhorn <kc6ete@gmail.com> wrote: > Current state of the project: > > //----------------------------------------------------------------------- > > //-- Bottom Clamp with Ridges > > //----------------------------------------------------------------------- > > > use <obiscad/bevel.scad> > > use <obiscad/attach.scad> > > > Screw_Dia = 4.60 ; //mm for 8/32 screw > > Nut_Flats = 8.50 ; // Measure across the flats. > > Nut_Slack = 0.40 ; > > Flats_Rad = Nut_Flats/2; > > Nut_Rad = ((Flats_Rad / cos(30)) + Nut_Slack); // Correction factor for > size. > > Nut_High = 3 ; > > Nut_Offset = -3 ; > > > // Basic dimensions of the part > > Clamp_X = 95 ; // mm length > > Clamp_Y = 45 ; // mm depth > > Clamp_Thick = 5 ; // > > Clamp_Size=[Clamp_X,Clamp_Y,Clamp_Thick]; > > > // Define screw last > > Screw_Rad = (Screw_Dia/2) ;// mm > > Screw_High = (Clamp_Thick + 2) ;// mm We will translate down by 1 > > Screw_Inset = 13 ; //mm from the ends > > > // Positions for the two screws > > Screw1_X = ( 0 - ((Clamp_X/2) - Screw_Inset)); > > Screw2_X = (Clamp_X - ((Clamp_X/2) + Screw_Inset)); > > > //-- Define the connectors for beveling the for top edges > > > //-- Top-right beveling > > ec1 = [ [Clamp_Size[0]/2, 0, Clamp_Size[2]/2], [0,1,0], 0]; > > en1 = [ ec1[0], [1,0,1], 0]; > > > //-- Top-left beveling > > ec2 = [ [-Clamp_Size[0]/2, 0, Clamp_Size[2]/2], [0,1,0], 0]; > > en2 = [ ec2[0], [-1,0,1], 0]; > > > //-- Top-front beveling > > ec3 = [ [0, -Clamp_Size[1]/2, Clamp_Size[2]/2], [1,0,0], 0]; > > en3 = [ ec3[0], [0,-1,1], 0]; > > > //-- Top-back beveling > > ec4 = [ [0, Clamp_Size[1]/2, Clamp_Size[2]/2], [1,0,0], 0]; > > en4 = [ ec4[0], [0,1,1], 0]; > > > // Ribs > > Rib_Rad = 2 ;// > > > module Rib() { > > difference (){ > > cylinder(h = (Clamp_X - 40), d=(Rib_Rad*2), center = true, $fs=60); > > translate ([(Rib_Rad/2),0,0]){ > > cube(([(Rib_Rad*2),(Rib_Rad*2),(Clamp_X-39)]),center= true); > > } // end of translate > > } // End of difference > > } // End of module Rib > > > > module Screw_Hole(){ > > cylinder (r = Screw_Rad, h=Screw_High,center = false, $fn=45); > > } // End of module > > > module Nut_Recess(){ > > cylinder (r = Nut_Rad, h=Nut_High,center = false, $fn=6); > > } // End of module > > > // Add the ribs to the box > > module Clamp(){ > > union (){ > > cube([Clamp_Size],center = true); > > translate ([0,(0 - Rib_Rad),0]){rotate (a=[0,90,0]) {Rib();}}; > > translate ([0,(0 + Rib_Rad),0]){rotate (a=[0,90,0]) {Rib();}}; > > }; // End of union > > }; // End of module > > > Clamp(); > > > /* > > difference () { > > Clamp(); > > translate ([Screw1_X,0,-3]) Screw_Hole(); > > translate ([Screw2_X,0,-3]) Screw_Hole(); > > translate ([Screw1_X,0,Nut_Offset]) Nut_Recess(); > > translate ([Screw2_X,0,Nut_Offset]) Nut_Recess(); > > bevel(ec1, en1, cr = 10, cres=10, l=Clamp_Size[1]+2); > > bevel(ec2, en2, cr = 10, cres=10, l=Clamp_Size[1]+2); > > bevel(ec3, en3, cr = 10, cres=10, l=Clamp_Size[0.5]); > > bevel(ec4, en4, cr = 10, cres=10, l=Clamp_Size[0.5]); > > } // end of difference > > */ > > > On Wed, Mar 4, 2015 at 6:26 PM, MichaelAtOz <oz.at.michael@gmail.com> > wrote: > >> Hi, >> >> Compiling design (CSG Tree generation)... >> WARNING: Ignoring unknown variable 'Clamp_X'. >> WARNING: Ignoring unknown variable 'Rib_Rad'. >> WARNING: Ignoring unknown variable 'Clamp_X'. >> WARNING: Ignoring unknown variable 'Rib_Rad'. >> WARNING: Ignoring unknown variable 'Rib_Rad'. >> WARNING: Ignoring unknown variable 'Rib_Rad'. >> WARNING: Ignoring unknown variable 'Rib_Rad'. >> WARNING: Ignoring unknown variable 'Clamp_X'. >> WARNING: Ignoring unknown variable 'Rib_Rad'. >> WARNING: Ignoring unknown variable 'Clamp_X'. >> WARNING: Ignoring unknown variable 'Rib_Rad'. >> WARNING: Ignoring unknown variable 'Rib_Rad'. >> WARNING: Ignoring unknown variable 'Rib_Rad'. >> WARNING: Ignoring unknown variable 'Rib_Rad'. >> WARNING: Ignoring unknown variable 'Clamp_X'. >> WARNING: Ignoring unknown variable 'Screw1_X'. >> WARNING: Ignoring unknown variable 'Screw_Rad'. >> WARNING: Ignoring unknown variable 'Screw_High'. >> WARNING: Ignoring unknown variable 'Screw2_X'. >> WARNING: Ignoring unknown variable 'Screw_Rad'. >> WARNING: Ignoring unknown variable 'Screw_High'. >> WARNING: Ignoring unknown variable 'Screw1_X'. >> WARNING: Ignoring unknown variable 'Nut_Offset'. >> WARNING: Ignoring unknown variable 'Nut_Rad'. >> WARNING: Ignoring unknown variable 'Nut_High'. >> WARNING: Ignoring unknown variable 'Screw2_X'. >> WARNING: Ignoring unknown variable 'Nut_Offset'. >> WARNING: Ignoring unknown variable 'Nut_Rad'. >> WARNING: Ignoring unknown variable 'Nut_High'. >> WARNING: Ignoring unknown module 'bevel'. >> WARNING: Ignoring unknown module 'bevel'. >> WARNING: Ignoring unknown module 'bevel'. >> WARNING: Ignoring unknown module 'bevel'. >> Compiling design (CSG Products generation)... >> >> Please supply the variables. >> >> >> >> ----- >> Unless specifically shown otherwise above, my contribution is in the >> Public Domain; To the extent possible under law, I have waived all >> copyright and related or neighbouring rights to this work. This work is >> published globally via the internet. :) Inclusion of works of previous >> authors is not included in the above. >> >> The TPP is no simple “trade agreement.” Fight it! >> http://www.ourfairdeal.org/ >> -- >> View this message in context: >> http://forum.openscad.org/Difference-in-a-module-tp11886p11887.html >> Sent from the OpenSCAD mailing list archive at Nabble.com. >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> > >
Thu, Mar 5, 2015 1:36 AM
WARNING: Can't open library 'obiscad/bevel.scad'.
WARNING: Can't open library 'obiscad/attach.scad'.
Where can I get those?
View this message in context: http://forum.openscad.org/Difference-in-a-module-tp11886p11890.html
WARNING: Can't open library 'obiscad/bevel.scad'. WARNING: Can't open library 'obiscad/attach.scad'. Where can I get those? ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/Difference-in-a-module-tp11886p11890.html Sent from the OpenSCAD mailing list archive at Nabble.com.
DV
david vanhorn
Thu, Mar 5, 2015 1:38 AM
I think I figured it out..    Thanks.
This is a lot like Povray, but different enough that it keeps tripping me
up.
I found those here:  http://www.thingiverse.com/thing:30336
I think I figured it out.. Thanks. This is a lot like Povray, but different enough that it keeps tripping me up. I found those here: http://www.thingiverse.com/thing:30336 On Wed, Mar 4, 2015 at 6:36 PM, MichaelAtOz <oz.at.michael@gmail.com> wrote: > WARNING: Can't open library 'obiscad/bevel.scad'. > WARNING: Can't open library 'obiscad/attach.scad'. > > Where can I get those? > > > > ----- > Unless specifically shown otherwise above, my contribution is in the > Public Domain; To the extent possible under law, I have waived all > copyright and related or neighbouring rights to this work. This work is > published globally via the internet. :) Inclusion of works of previous > authors is not included in the above. > > The TPP is no simple “trade agreement.” Fight it! > http://www.ourfairdeal.org/ > -- > View this message in context: > http://forum.openscad.org/Difference-in-a-module-tp11886p11890.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
