Thx. Looking at fonts.scad and example023.scad, I can see why search() is
needed :)
clothbot wrote
Yeah, when I wrote search() the two primary use modes I focused on were
basic character(s)-in-string and searching for matches in list-of-lists.
Have a look at my old example23.scad (see
https://github.com/openscad/openscad/blob/master/examples/Old/example023.scad
<https://github.com/openscad/openscad/blob/master/examples/Old/example023.scad>)
and how I structured MCAD/fonts.scad (see
https://github.com/openscad/MCAD/blob/master/fonts.scad
<https://github.com/openscad/MCAD/blob/master/fonts.scad>) to get
some insight into how I wanted to (ab)use it.
Andrew.
$ Runsun Pan, PhD
$ -- OpenScad_DocTest: doc and unit test ( Github , Thingiverse )
$ -- hash parameter model: here , here
$ -- Linux Mint 17.1 Rebecca x64 + OpenSCAD 2015.03.15/2015.04.01.nightly
View this message in context: http://forum.openscad.org/Can-I-get-some-code-review-up-in-here-tp12341p12363.html
Also see my GFan Lib Thing http://www.thingiverse.com/thing:111187 for
further examples.
View this message in context: http://forum.openscad.org/Can-I-get-some-code-review-up-in-here-tp12341p12365.html
Cool. Very similar to my approach. I suppose your Fan Lib (matching integers
using lookup) will run faster than my hash model (matching string via
recursive scanning).
MichaelAtOz wrote
Also see my
for further examples.
$ Runsun Pan, PhD
View this message in context: http://forum.openscad.org/Can-I-get-some-code-review-up-in-here-tp12341p12370.html
Marius has pulled my fixes to search and my updates to example023.scad (removing the deprecated use of assign()). Anything built from today (April 16th) onward should be good to go!
Andrew.
needed :)
Andrew.
$ Runsun Pan, PhD
hi all,
hey, does anyone know where a "ramp" symbol could be found?
the "ramp" symbol is whatcha see on euro volume controls, you know, it's
a "triangle" that's thin on the left, the top slopes up and to the
right, and it's thick on the right.
it's for a dimmer, and i'm trying to be "language independent". so i'm
trying to write() the symbol on the dimmer cover.
can we write() bitmaps?
thanks!
yvette
polygon (points=[[0,0],[10,0],[10,3]]);
Sent from my iPhone
On Apr 17, 2015, at 10:50 AM, "Yvette S. Hirth, CCP, CDP" yvette@dbtgroup.com wrote:
hi all,
the "ramp" symbol is whatcha see on euro volume controls, you know, it's a "triangle" that's thin on the left, the top slopes up and to the right, and it's thick on the right.
it's for a dimmer, and i'm trying to be "language independent". so i'm trying to write() the symbol on the dimmer cover.
thanks!
yvette
thanks!
yvette
