Hi, gentlemen,
Would somebody explain to me why this piece of code doesnt do what I am expecting?
p=0;
for(n=[1:1:10]){
p=1-p;
echo(p);
P is the parity of n. I expect 1,0,1,0… but I obtain 1,1,1…
In my mind it is a simple “global variable”. I should be able to modify it anywhere.
How can I get the parity by an other mean?
Thanks for any clue on the subject.
OpenScad doesn't allow changing the value of p. Others will explain better
than I.
Here's a solution:
for (n=[1:10]){
p = n%2;
echo(p);
Dan
On Thu, Oct 23, 2025 at 10:46 AM jpm2nice-tech--- via Discuss <
Hi, gentlemen,
expecting?
p=0;
for(n=[1:1:10]){
p=1-p;
echo(p);
anywhere.
On Thu, Oct 23, 2025 at 09:46:19AM +0000, jpm2nice-tech--- via Discuss wrote:
Hi, gentlemen,
p=0;
for(n=[1:1:10]){
p=1-p;
echo(p);
You cannot modify a variable. You can declare a new variable inside
a different scope.
For us humans it is confusing to have two different variables called
"p" but the computer/openscad knows what it's doing. So what you're
actually writing is:
p1 = 0;
for(n=[1:1:10]){
p2 = 1-p1; (*)
echo(p2);
In your code you are on that line creating a new variable "p" that is
used in the rest of that scope and it's value is used if you mention
"p". On THAT line you can still use the OLD (outer) version of "p".
In openscad you can NEVER reassign a new value to a variable.
** Verl. Spiegelmakerstraat 37 2645 LZ Delfgauw, The Netherlands.
** KVK: 27239233 **
** 'a' for accelleration.
Thanks a lot to you all.
I understand now a few problems I had in the past!
Jean-Pierre
P is the parity of N? You do not reference n?
As others have said, inside the for(), p= males a new scope for p, which will always be p= (1-(p the outer cope p==0) = 1 - 0 = 1
Think of for() as making a tree structure of sub-objects, in each of your 10 sub-tree-branches, p=outside-p=0, inside-p=1-outside-p=1-0=1.
Each sub-tree-branch has a different n 1..10.
Do:
p=0;
for(n=[1:1:10]){
p=1-p;
echo(p,n);
translate([n*3,n,0])
cube([p,p,n]);
[Hopefully that survives formatting...]
Then do F5 & Design/CSG-tree, it will show you the components that for() makes.
From: jpm2nice-tech--- via Discuss [mailto:discuss@lists.openscad.org]
Sent: Thursday, October 23, 2025 8:46 PM
Cc: jpm2nice-tech@yahoo.fr
Subject: [OpenSCAD] Variable range in a FOR loop (?)
Hi, gentlemen,
p=0;
for(n=[1:1:10]){
p=1-p;
echo(p);
There's an FAQ entry:
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/FAQ#Why_am_I_getting_an_error_when_writing_a_=a+_1?
See also the first page of the manual:
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/General#Variables_cannot_be_changed
The is one exception to that no changes rule. what ever you use for the
for(n=[ in a for loop, the n is a variable that can be used within the
scope of the for's { code list loop } which can even include another
"for" loop. I do that every time I render a threaded bolt.
Technically the variable does not change even in a FOR loop. Each iteration
is a new scope.
On Thu, Oct 23, 2025 at 11:28 AM gene heskett via Discuss <
for(n=[ in a for loop, the n is a variable that can be used within the scope
of the for's { code list loop } which can even include another "for" loop. I
It is not really an exception.
for (n=[1,2,3]) {
// something
loop creates three contexts with the contents of what's inside the
braces. With thee different n variables and a different value....
** KVK: 27239233 **
is a new scope.
which I assume then allocates more memory. Which could explain why, at
around a couple hundred renders as I write new code, things get funkity
& I have to save and restart OpenSCAD. I've only 32Gigs of main memory.
I've wondered why, now I know. Thank you. Must be time to get a new
main board and more memory. . .
- Louis D. Brandeis
