How should color() work?
CC
Cory Cross
Fri, Oct 24, 2025 5:37 PM
Hello Everyone,
Over on Github there's a great discussion going about how color() should
work in the next release. We're trying to write a specification using
the language of RFC 2119 https://datatracker.ietf.org/doc/html/rfc2119
and approaching the end.
If you'd like a sneak preview, please read the first comment at
https://github.com/openscad/openscad/issues/6309
Usage examples:
https://github.com/openscad/openscad/issues/6289#issuecomment-3425784290
If you want to weigh in, please at least skim/search the predecessor
issues and read all comments of the current issue, because a number of
things have already discussed:
  1. https://github.com/openscad/openscad/issues/5966
  2. https://github.com/openscad/openscad/issues/6289
Thank you,
Cory Cross
Hello Everyone, Over on Github there's a great discussion going about how color() should work in the next release. We're trying to write a specification using the language of RFC 2119 <https://datatracker.ietf.org/doc/html/rfc2119> and approaching the end. If you'd like a sneak preview, please read the first comment at https://github.com/openscad/openscad/issues/6309 Usage examples: https://github.com/openscad/openscad/issues/6289#issuecomment-3425784290 If you want to weigh in, please at least skim/search the predecessor issues and read all comments of the current issue, because a number of things have already discussed: 1. https://github.com/openscad/openscad/issues/5966 2. https://github.com/openscad/openscad/issues/6289 Thank you, Cory Cross
Fri, Oct 24, 2025 7:51 PM
On 10/24/2025 10:37 AM, Cory Cross via Discuss wrote:
Hello Everyone,
https://datatracker.ietf.org/doc/html/rfc2119 and approaching the end.
Usage examples:
But I think the capsule summary is:
  • Color and transparency would be settable independently, so that
    color("red") color(alpha=0.5) cube(), in either order, would yield a
    transparent red cube.  In theory this is incompatible, if you were
    previously creating a transparent object and then forcing it back to
    opaque by setting its color.  Workaround:  explicitly set the alpha
    to 1.
  • Some error cases (supplying fewer than 3 or more than 5 values)
    might get new warnings.
  • Behavior in error cases (invalid RGB values, type errors, et cetera)
    might change.
On 10/24/2025 10:37 AM, Cory Cross via Discuss wrote: > Hello Everyone, > > Over on Github there's a great discussion going about how color() > should work in the next release. We're trying to write a specification > using the language of RFC 2119 > <https://datatracker.ietf.org/doc/html/rfc2119> and approaching the end. > > If you'd like a sneak preview, please read the first comment at > https://github.com/openscad/openscad/issues/6309 > Usage examples: > https://github.com/openscad/openscad/issues/6289#issuecomment-3425784290 > > If you want to weigh in, please at least skim/search the predecessor > issues and read all comments of the current issue, because a number of > things have already discussed: > > 1. https://github.com/openscad/openscad/issues/5966 > 2. https://github.com/openscad/openscad/issues/6289 > > But I think the capsule summary is: * Color and transparency would be settable independently, so that color("red") color(alpha=0.5) cube(), in either order, would yield a transparent red cube.  In theory this is incompatible, if you were previously creating a transparent object and then forcing it back to opaque by setting its color.  Workaround:  explicitly set the alpha to 1. * Some error cases (supplying fewer than 3 or more than 5 values) might get new warnings. * Behavior in error cases (invalid RGB values, type errors, et cetera) might change.
Fri, Oct 24, 2025 10:02 PM
On 10/24/25 13:37, Cory Cross via Discuss wrote:
Hello Everyone,
Usage examples:
As a broadcast engineer since 1962, this seems to equate, using
different words I am not familiar with, language evolution related I
suspect given the English speakers propensity to invent new words when
the current model is deemed insufficient to convey the meaning, to
something that seems to resemble NTSC.  There, when colorimetry experts
were working on it, the alpha channel was translated by summing the RGB
values and became the monochrome or brightness signal. But based on the
perceived brightness, the summing network was adjusted so that the
perceived brightness of each color corresponded to how the average
person with good color vision saw its brightness.  So solid blue
contributed only 11% of the brightness weight in the summed monochrome
signal. And I'll confess to having forgotten the % of the red & green
from the cameras. The crt displays at the time all used additive colors
but the phosphors used in the screens had wildly different efficiencies
so it took the tv makers several years to develop better phosphors &
they are still playing with it.
Color printers OTOH, are stuck by generally white paper, and use inks of
complementary colors some makers haven't fully grokked yet altho Epson
and Brother seemed to have that optimized pretty good. complementary
colors there are magenta(reflecting red+blue & absorbing green)
yellow(reflecting red+green & absorbing blue) and cyan(reflecting
green+blue & absorbing red). It took the printer makers nearly 40 years
to get those inks somewhere near right. And none are archival quality
yet.  Light fades them, each color at a different rate. Not our problem.
Even the Mona Lisa is kept in the dark when there is no one in the room.
What I'm trying to say is that doing it NTSC style allows us to use a
well developed std we used in broadcasting from 1962 to 2008 when we
went digital.  Much of that math has already been done and prolifically
documented. Its public domain stuffs.  Digital is basically an 8 level
signal, giving an rrddbbaa but encoded such that the average power
output measured by calories of heat it generates in a dummy load, is
held at a 50% average value. NTSC didn't do that with a black pix using
a lot more power than a white pix.
Just an old engineers 2 cents.
Cheers, Gene Heskett, CET.
  • Louis D. Brandeis
On 10/24/25 13:37, Cory Cross via Discuss wrote: > Hello Everyone, > > Over on Github there's a great discussion going about how color() > should work in the next release. We're trying to write a specification > using the language of RFC 2119 > <https://datatracker.ietf.org/doc/html/rfc2119> and approaching the end. > > If you'd like a sneak preview, please read the first comment at > https://github.com/openscad/openscad/issues/6309 > Usage examples: > https://github.com/openscad/openscad/issues/6289#issuecomment-3425784290 > > If you want to weigh in, please at least skim/search the predecessor > issues and read all comments of the current issue, because a number of > things have already discussed: > > 1. https://github.com/openscad/openscad/issues/5966 As a broadcast engineer since 1962, this seems to equate, using different words I am not familiar with, language evolution related I suspect given the English speakers propensity to invent new words when the current model is deemed insufficient to convey the meaning, to something that seems to resemble NTSC.  There, when colorimetry experts were working on it, the alpha channel was translated by summing the RGB values and became the monochrome or brightness signal. But based on the perceived brightness, the summing network was adjusted so that the perceived brightness of each color corresponded to how the average person with good color vision saw its brightness.  So solid blue contributed only 11% of the brightness weight in the summed monochrome signal. And I'll confess to having forgotten the % of the red & green from the cameras. The crt displays at the time all used additive colors but the phosphors used in the screens had wildly different efficiencies so it took the tv makers several years to develop better phosphors & they are still playing with it. Color printers OTOH, are stuck by generally white paper, and use inks of complementary colors some makers haven't fully grokked yet altho Epson and Brother seemed to have that optimized pretty good. complementary colors there are magenta(reflecting red+blue & absorbing green) yellow(reflecting red+green & absorbing blue) and cyan(reflecting green+blue & absorbing red). It took the printer makers nearly 40 years to get those inks somewhere near right. And none are archival quality yet.  Light fades them, each color at a different rate. Not our problem. Even the Mona Lisa is kept in the dark when there is no one in the room. What I'm trying to say is that doing it NTSC style allows us to use a well developed std we used in broadcasting from 1962 to 2008 when we went digital.  Much of that math has already been done and prolifically documented. Its public domain stuffs.  Digital is basically an 8 level signal, giving an rrddbbaa but encoded such that the average power output measured by calories of heat it generates in a dummy load, is held at a 50% average value. NTSC didn't do that with a black pix using a lot more power than a white pix. > 2. https://github.com/openscad/openscad/issues/6289 > > > Thank you, > Cory Cross > Just an old engineers 2 cents. > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org Cheers, Gene Heskett, CET. -- "There are four boxes to be used in defense of liberty: soap, ballot, jury, and ammo. Please use in that order." -Ed Howdershelt (Author, 1940) If we desire respect for the law, we must first make the law respectable. - Louis D. Brandeis Don't poison our oceans, interdict drugs at the src.
